Choose the right ZB version for my MSS65
    Hello everyone I would like to restore my MSS65 DME with WINKFP, only I don't know which ZB version number to choose, can you help me please, I think this is it,
    what do you think? thank you guys
    use the number you entered (ZUSB 7842639). And flash it. It will then restore that that specific software.
      Thanks and does that remove the RSA bypass if I restore with winkfp?
        Normally it will only write the maps (Data) if the previous program is equal. To enforce a full reprogram I suspect you need to do this by Expert Mode.
          Ok thank you
            Hi
            Is it possible to flash one of these versions just to test and watch for my personal research ?
              Hi
              As long as the hardware accepts it yes. If not, WinKFP comes up with a warning.
              What is your goal of your research? You could also figure out which *.0da file matches and search for the differences.
                Just to compare the files to see the differences between them
                  I would advice you to look in the *.0da files rather than flashing your ECU multiple times.
                    Do you read .ODA with win0ls or is there other software?
                      Yes, that is possible.
                      What software do you prefer to use?
                        Win0ls
