Steering wheel jerk while applying brake
  • Mattn1192
    What brand were they?
  • sev
    Poly = trash. Check the passenger side FCAB. Likely melted.
    trash trash trash! i had my passenger side one melt on the second session of my last track day
  • FBloggs
    It’s installed backwards. The insert is flanged and should face the front of the car or the control arm. The flange prevents the under from being pushed through the outer bushing.
    The flange is on the back so the insert is being pushed through the bushing and will likely come off the control at some point. Handling will be very interesting at that point.
    lol! You can imagine what the faithful rear axle is going through as it tries to follow what the dodgy front is up to under the brakes.
  • bigjae46
    It’s installed backwards. The insert is flanged and should face the front of the car or the control arm. The flange prevents the insert from being pushed through the outer bushing.
  • Mattn1192
    This is the one I bought
  • FBloggs
    Good ol' powerflex.
    Those bushings were purchased within the last 18 months?
    Buyers of Their FLCAB/mount kits would be wise to double check the parts for correct assembly before installation.
  • bigjae46
    OE rubber is compliant, quiet but will wear out.
    Solid/spherical needs maintenance, not compliant, but will last a long time if maintained.
    Poly is compliant, noisy, and will wear out…if the passenger side doesn’t burn up and disintegrate.
    OE - get kicked in the left ball, Spherical - get kicked in the right ball. Poly - get kicked in both balls.
  • Mattn1192
    $323 for FCAB seems extremely expensive.
  • Mattn1192
    What’s wrong with poly bushings? I’ve always thought highly of bushings from AKG.
  • jbfrancis3
    Good opportunity to put non-poly's in. You may consider monoballs such as Turner's - I'm biased and have them but if you search you can understand other preferences. To get back on track quickly, and if DIY, consider the option already pressed into housings.
  • Mattn1192
    This sure blows.
  • bigjae46
    Pretty sure the bushings are pressed in backwards.
  • Mattn1192
    Both sides
  • Mattn1192
    Found the problem. The inner part of the bushing fell out. Don’t know how that happened. Driver side fell out, passenger side is still in.
  • bigjae46
