Subframe Dropped and cracks found
I would like to see a solution that can be added without making such extreme modifications to the existing sheet metal, other than maybe a few drill holes. Is it possible?
Originally posted by pawelgawel View PostI understand the issues and theory behind all of this... if i had the space and time to let the car sit on jacks for weeks, Id probably do this as well just for the sake of doing it and knowing I have a "brace" vs anything else. In all honesty, what is the life span of the structural foam? if done properly, it fills in the cavity and joints both sheets and the sides together creating a single solid entity. How strong is this in long term? has anyone recorded failure after doing this properly? and what type of abuse did it go through?
Simply put, the RACP will still pull away from the rest of the chassis when foamed. So the lifespan of the foam really is not of any great significance.
The foam was a cheap way for BMW to push the problem in front of them long enough to get out of the class action lawsuit. Nothing more, nothing less.
In short, the foam only delays RACP failure IMHO. I wouldn't go near it - particularly as it makes proper topside reinforcement more difficult (the foam puts off toxic fumes when welding). I strongly suspect it was simply the cheapest way for BMW to make an RACP with minor cracks last out the 10 year period agreed to when they settled the US class action.
And here are two sketches that I made back in 2015 when originally explaining the issue and the VinceBar design. This is viewing the left rear subframe from the back, looking forward
- Likes 3
Following up on the previous post, for anyone wanting this in text and pictures rather than the videos.
I’d like to share a few pictures that I believe very clearly illustrates the underlying design flaw that causes the dreaded so called ”subframe failure” on the E46’s.
In the first picture I’ve exposed the topside of the tear left subframe mount. And this view of it shows a couple of the key spot weld that have “popped”.
The aforementioned spot welds are to the left and right of the subframe mount (which in turn has the “T” cut and partly flattened on top of it) The popped spot welds have been drilled out in this picture.
In the second picture you can see how the load (the downwards pointing arrow) is transferred to the chassis leg (the thin red lines), and what a detour that path is.
Furthermore the last part of that path is taken through a single layer of sheet metal.
Needless to say there’s a lot of flexing going on there, and the RACP i unnecessarily exposed to a load that could/should have gone directly to the chassis leg where theres just a large gap. (This gap is BTW closed by the end plates of the VinceBar)
So, the load is transferred to those poor spot welds in front, and behind, the subframe mount. The front ones are also just connected to the inner wall of the chassis leg.
The outer wall of the chassis leg (the wheel well) is reached via the part of the RACP that runs in under the inner wall of the RACP as seen in the third and forth pictures.
In those last pictures please note how the RACP profile slats not only downwards, but also upwards (look at the left side) ending in a (you guessed it) single layer of sheet metal thats spot welded to the wheel well. Again resulting in a fair amount of flexing.
This is where the separation shown in the fifth picture occurs.
- Likes 3
Originally posted by pawelgawel View Postall you guys going that extra mile and do the bars up front and rear with plates... impressive, honestly! You guys must be tracking and beating on these cars like no tomorrow... I can't imagine having issues after doing the plates and the welds up top with structural foam in the cavities for normal spirited driving once in a while. I think, in reality, the car will be driven to the ground before the floor rips after having that done.
The damage is the result of metal fatigue due to a design that allows for way too much flexing. The flexing is in turn the result of a design flaw (production/cost related I believe) that has the floor panel (RACP) very poorly connected to the chassis legs. The load path from the subframe to the chassis legs is long and passes through several weak/hot spots.
The good news is that it’s fairly easy to address and eliminate this design flaw by coupling the subframe mounts directly to the chassis legs. This is however NOT done with just plats and structural foam (the foam was BTW just a cheap fix BMW did to get out of the class action law suit in 2008/2009).
To pretty much unload the RACP some sort of cross bar is needed. And at the top of the front mounts there needs to be both vertical and lateral additional support.
That said, I agree that there are some solutions that are crazy over dimensioned, and way more clunky and space claiming than necessary.
Please have a look at these videos (particularly the first one) for more details.
It’s actually TiAg, but the lighting does make it look silver grey.
I used an epoxy paint that is super close to the color of the factory e-coat.
First the epoxy paint, then seam sealer, the epoxy paint again, and finally I tattle canned it TiAG because it was already rattle canned TiAg before I installed the VinceBar kit. Otherwise I would have strived to replicate the e-coat with slight overspray of TiAg.
Towards the end in this folder you can find lots of pictures of the surface treatment process
Originally posted by VinceSE2 View Post
The VinceBar, both the original “stealth” and the newer “simplified” designs are completely hidden under the interior and out of the way.
Here’s the simplified design pictured
What products do you recommend as far as seam sealer/paint? Mine is Silver Grey Metallic like the photo, did you have some paint mixed up for you or did you source that somewhere?
Originally posted by scotty737 View Postlook at post #45 I posted the instructions of this whole part...
Originally posted by Albino09 View Post
Interesting. So for the rear mounts, it is transferring the stud from the internal sheet metal and welding it to the reinforcement plate instead?
No bolt like the vincebar or cmp. You drill through the spot welds in the cavity on either side and plug weld to the reinforcemnt plate underneat around the threaded portion of the rear mounts. The front mount, they just wanted teh factory mig welds ground down and rewelded and cracked repaired there.
