Stumbled across another data point for the stock harmonic balancer: see mention of spinning it to 8,700 “without any problems.”
Raising the rev limiter on a stock S54
Hassan tuned my car. Raised the rev to 8250. I have headers & exhaust. He’s been very informative and did a great job with my car. Mentioned when racing to basically redline. Not sure if it’s the same with a fully stock s54. Btw, if anyone’s looking to get tuned, he’s the guy. Looks like many others in this community also agree.
might be worth reaching out to ATI to see what RPM their camper can handle.Originally posted by bigjae46 View PostI’d be ok with 8400.
RRT knows their stuff-- sounds like 8400 is as high as you should go.Originally posted by jbfrancis3 View PostA local shop to me, RRT, once mentioned that the stock harmonic balancer is a primary consideration to raising redline and that it cannot exceed 8,400rpm
... especially if you have a light weight flywheel, making the harmonic balancers life harder...
Mine is set at 8400, have cams/airbox/2.5" exhaust so peak power is right at redline.
Wow 8700?!? Do you know how that was determined?Originally posted by Obioban View PostSeems like 8700rpm is around where the stock valve train starts to not keep up. The issues will be that...
-s54 rev limiter isn't great at retaining RPM, so you might rev over the set redline and have issues
-stock, you're losing power after 7900rpm-- so may make you slower than shifting. Idk what your power mod situation is
-rod bearings will become much more routine maintenance.
Along with rod bearings might be a good idea to make sure the bottom end is balanced and your harmonic damper is in good condition.
If I can get a few more revs I can use shorter gearing without an upshift. I’m on 3.73, want to go up to 3.91.Originally posted by Tbonem3 View PostChange your gearing?
I know there is an argument that taller gears are better but data from my experiment tells a different story. If I compare data to someone with a 4.10, they have a distance time delta and speed gain advantage when the car straightens and under full throttle. 4-5mph at some points. RPMs are slightly higher, more accurate and precise throttle steerIng.
Real world, I only really catch him through turns. Most cars I run down in turns. I’ve driven E46s with 3.91s, it’s faster. Can be more of a handful but I’m OK with that.
Really don’t need a power increase, just more room to rev.
Ya, you probably need a holistic approach like you would with modding the car in general. Useless without a csl airbox, cams, port & polish, 2.5" exh...
What's there to be gained after about 7900 on a stock motor? Look at the dyno thread, particularly the baselines.
Even with mine @ 8200, with stepped headers and airbox, I still shift at 8k.
Valve float will be at like 9k I think. It's more a question of "why?" Imo. You're just wasting time you could be shifting and getting back in the meat of the torque no?
IIRC, I read many years ago that the stock valve train was good to 9K, maybe even a little higher, but the stock head is outta breath past the low 8's.
