Originally posted by r4dr
Newbie Rotor Question
Originally posted by r4dr View PostYou don't want drilled rotors anywhere near a track car, but I'll leave that up to you.
StopTech just bumped their prices up as of today, and the MAP on the rings are eye-watering.
Just heard back from girodisc, the don’t do drilled unfortunately.
I’ll check out the above links for stoptech filled rings.
Originally posted by mrgizmo04 View PostGirodisc makes 355x32 https://www.girodisc.com/355x32mm-Ro...Ks_p_6580.html
Quick note on caliper rebuild kits (really only matters if the car is tracked). While Centric is the parent company and owns Stoptech, Stoptech sells unique higher temp pressure seal kits. Make sure the parts you get come in Stoptech rather than Centric packages. Another way to tell is the dust boots from Stoptech are gray in color and are made of high temp resistant silicone, vs Centric's black/rubber. Again, for street car Centric rubber kits are good enough.
Drilled 355mm with new pads
Left Drilled - 31.737.1201.99
THMotorsport - https://thmotorsports.com/2683193-st...ch-aero-rotors
Amazon - https://www.amazon.com/StopTech-31-7...e%2C101&sr=1-2
Right Drilled - 31.737.1202.99Last edited by Slideways; 02-07-2022, 08:16 AM.
Are you looking for slotted or drilled?
Originally posted by zzyzx85 View PostI still need to rebuild my ST40s but i bought most of the rebuild parts from Zeckhausen (https://www.zeckhausen.com/catalog/index.php?cPath=24)
Originally posted by Advorsor View Post
Girodisc I think
Not sure if girodisc does 355mm replacement rotor rings for an ST40 kit…..or do they?
Originally posted by 0-60motorsports View PostBumping this up instead of starting a new thread. I need to replace my 355 Dt40 kit rotors and pads as well because they are almost at minimum>
Any suggestions on nonstop tech replacement options and if No, best place to buy stoptech rotors and they should ship outside the states. Thanks.
