Thunking after subframe reinforcement and new subframe bushings?
  • sammyf
    So the car went through an pretty extensive refresh (Engine Mounts, Tranny Mounts, Guibo, AND now CSB as well which are ALL BMW). I noticed it mostly in high gear on the freeway; sport mode on, in 6th gear and would punch it to pass and THUNK. But my buddy says he notices the same thunk in every gear. We did retorque sub-frame bushings... I'll check the diff bushings as well.
  • old///MFanatic
    Originally posted by sammyf View Post
    Now, when I am in the car (especially in sport mode) when I punch the throttle in a higher gear (6spd manual), I get a pretty noticeable "thunk" coming from the back. We actually had the car on the lift in the air and are able to hear it inside the car, but when we are looking around outside underneath, we can NOT hear/see anything.
    That suggests it’s leaning towards something bolted directly to the chassis. Cause noise through the chassis.
    So we replaced the center bearing with factory part...UNFORTUNATELY, the thunk is still there. Any other ideas? Again it only happens during initial acceleration.
    Thought you said guibo before, I directly asked and questioned. You also said it’s in high gear. Now seems saying it’s on initial acceleration. Initial acceleration sounds like the subframe bushings. It takes up the initial torque impact, OEM bushings are designed just to alleviate a lot of this. Poly move less and by design remove the initial impact factory design buffers. So it will cause a thudded impact on the four bolts/studs that hold the subframe. So it could certainly be the poly subframe mounts. I’m not saying that’s what it is without examining but certainly could be. I’ve seen rear diff bolts torqued wrong and also cause thuds, so there’s more things to check. Are the new motor and trans mounts OEM or poly?
  • sammyf
    Here's the bushing setup in the rear. Diff bushings are all BMW (BRAND NEW NOSE and ORIGINAL REARS). We have video evidence that the DIFF is NOT moving under load.
Name:	Screen Shot 2021-12-21 at 8.53.18 AM.png
  • Tbonem3
    It's really bad? It's not just the natural clunkiness of the driveline?
    Poly bushes will exacerbate noises.
  • sammyf
Name:	Screen Shot 2021-12-21 at 8.43.57 AM.png
  • jet_dogg
    Will never understand why people exchange US currency for polyurethane bushings.
  • SteelGreyM
    Oh no I just installed powerflex poly diff bushings. Not liking what I’m reading.
  • old///MFanatic
    lvm3sm46 We took a camera and it looks like there might be a crack around flex disc. Will replace and report back:
    Click image for larger version  Name:	Screen Shot 2021-12-14 at 2.21.33 PM.jpg Views:	15 Size:	133.6 KB ID:	141759
    You sure that’s the flex disc? Almost looks more like top side of a motor mount.
  • Tbonem3
    Pre-load the CSB
  • Arith2
    Solid suffrage bushings plus ploy diff bushings aren't for the faint of heart. It stresses me out to hear my diff chatter sometimes. I also have a lightweight flywheel so that really changes things. You'd be amazed at how much a stock flywheel actually dampens.
  • sammyf
  • sammyf
    Its a brand new front BMW diff bushing but the rears are original as they didn't look bad on inspection. Car is 2002 with 112k miles.
  • lvm3sm46
    Drive shaft support and bearing. Replace that. It solved my clunk
  • sapote
    Higher gear as 5th or 6th? Or 1st?
    I asked because the rear end is under higher load with 1st or 2nd than 5th or 6th.
  • maw1124
    +1 on non-OE diff bushings... seems like almost 100% when people use nonOE diff bushings, yes?
    maw
