Originally posted by Sprp85
How involved? remove vanos, EX hub, EX cam sprocket. But before that, look to see if the tip broke off or not, then carefully fish it out and don't let it fall down into the oil pan -- means the vanos needs retiming after. This has nothing relate with rod bearing process, but if the broken tip already fell down in the pan.
If the tip broke off, the lower guide -- which the chain tensioner presses on -- will wear out faster as it now pushing the chain at a sharper angle. At very high rpm, lacking a functional upper guide, the chain could jump on the EX sprocket and engine damaged.
