S54 Stroker build
map is only used as correction on these cars, so you will be running alpha-n. with a well adjusted tune the map is mostly unneeded, so don’t stress too much
is there a detailed CSL Airbox conversion thread?
I dont want alpha N
VANOS completely done already 5k vanos job when I had the carOriginally posted by Slideways View PostDid the OP ever state the budget for his build?
I did some quick maths on my ideal S54 engine build and it comes out to roughly 11.5k minus labor and a refresh with OE internal parts such as rings, valve seals, bearings, cam followers and machining work.
Parts list:
CSL Intake with MAP
Full SS V1 2.5" catted exhaust
Schrick 280/272 cams
Beisan VANOS refurb
DINAN Throttle Bodies
PCS Tune
I have a corsa 2.5" cat back already
I won't be going DINAN CA Technologies International and their shaftless throttle bodies I may go for
Its gonna be like 15k for the engine
i don't want to state a budget because Ill get told yes or no, I want to see how far I can go the point of this thread is to see how far i can actually push this engine without making a race one
it just needs to be in a car by December
wow thats great info, thank you diggerOriginally posted by digger View Post
i would do twin system all the way only because i prefer the sound, look of a dual system and addiotinal clearance (though not always an issue) and easier to keep quiet and emmisions clean. Once you merge the two collector pipes (using X, H or Y) at the appropriate location then its basically about just about total pipe area and minimising back pressure so the single vs dual is 6 of one of half a dozen of the other. The single has a theortical benefit to reducing back pressure for a given flow area but its going to be pretty small to negligible IMO
ill just stick with my corsa cat back and Ill look into collector pipes and just stay ssv1. I agree I want to keep stock looksLast edited by M/Anthony; 05-02-2020, 08:16 PM.
Parts list:
CSL Intake with MAP
Beisan VANOS refurb
PCS TuneLast edited by Slideways; 05-02-2020, 07:49 PM.
i would do twin system all the way only because i prefer the sound, look of a dual system and addiotinal clearance (though not always an issue) and easier to keep quiet and emmisions clean. Once you merge the two collector pipes (using X, H or Y) at the appropriate location then its basically about just about total pipe area and minimising back pressure so the single vs dual is 6 of one of half a dozen of the other. The single has a theortical benefit to reducing back pressure for a given flow area but its going to be pretty small to negligible IMOOriginally posted by M/Anthony View Post
Match that with a 3.5" single exit exhaust or go with 2.5" all the way backLast edited by digger; 05-02-2020, 07:43 PM.
Match that with a 3.5" single exit exhaust or go with 2.5" all the way backOriginally posted by digger View Postit'd be pretty hard to go past SS stepped headers with the big bore SS mid section piping etc. any system that improves over it in a particular area is also probably likely to come with some other compromises
the question is now with a stroker build like mikes and carbahn whats the best exhaut setup and headers
3392cc 93mm crank 12:5:1 according to their websiteOriginally posted by jbfrancis3 View PostMtherfcker no I didn't calc right, forgot to up the denominator for greater displacement.
440nm = 15.8 BMEP with raised CR. Sorry Teufelswerk wherever you are.
What's the Carbahn's displacement?
Mikes: Lang racing Stoker, 3.42L, a tab bit over 12:1 compression 296/284 14.0 and 14.5mm lift, 87.5mm bore vanos retained 390whp 280 wtqLast edited by M/Anthony; 05-02-2020, 04:55 PM.
