Originally posted by Mainman857
But it's actually not so straightforward for you or your mechanic to fully assess if "everything is working and not broken now" for the other bits like seals and solenoids. In addition to exhibiting "hard" failures that would make it obvious that there's something wrong (very noticeable lack of power and/or VANOS related fault codes), they also exhibit "soft" failure where things won't be performing as well as they should, but things aren't going wrong enough for the engine to notive and throw a fault code. The car will still be performing "well enough" for you not to think there's something wrong, but it could be doing better if everything was fresh. I'd be surprised if a 15 year old 129k VANOS didn't see some improvement in response time in the VANOS test and feel better to drive after a full refresh.
So, even if your VANOS seems fine, I would still strongly recommend you get seals done, replace your solenoid pack, and also have your solenoid valve body thoroughly cleaned. This will likely improve your VANOS function, and even if it doesn't, it's just a matter of time before you'd really be forced to do these things anyway. Then you have to pay someone to dive back in there all over again. If you're doing the pump disc anyway, it really shouldn't be much more labor to do these things.
Timing chain guide is known to wear and break by your mileage. If yours is still hanging on, then it'll probably be gone soon. From my understanding, this won't cause big problems for your engine, but could produce an annoying rattle? Someone else should probably chime in here. In any case, definitely do it if you're going to have the cam bolts done.
I strongly suggest you read up on some good information compiled here: https://nam3forum.com/forums/forum/m...os-info-thread , and ask if you have questions.
