Originally posted by nuc1
Upgrading OEM HID Headlights, what are the options available??
I did a retrofit a few years ago on mine using items from retrofit source, ups low (bi-led with laser fog light) and high side is a morimoto led high beam. Wiring was run to a 12 pin Deutsch bulkhead fitting. Saved a few lbs and freed up some space that was needed for other items. Unfortunately I haven't actually tried them yetbuild may have snow balled a little, hopefully soon.
Few pics from the build.
Originally posted by bmw m3 s50 View Post
I am guessing Caesar at Lightwerkz is the way to go to upgrade from all the comments in this thread.
Originally posted by bmw m3 s50 View PostAnyone have pics to post of their upgraded headlight outputs to get an idea of what they look like?
From earlier in the thread – Lightwerkz is probably the best bet and people have been going to them for years. I DIY'd it but that was more to save money, it requires a good amount of shaving the inner housing and tweaking to get things aligned right.
Originally posted by thegenius46m View PostLightwerkz g5brt conversion with oem shrouds is oem+ and a substantial upgrade. This is my sedan but I just had the same setup built for my M3. All low beams pictured for output
Originally posted by toy4to View PostPlease contact Caesar at Lightwerkz. I had mine done over 10 years ago and I'm sure prices have changed since then. You won't be disappointed with the results, I'm sure of that.
Originally posted by jrgatfh View Post
What’s the approximate cost for something like that?
maw1124 - service provider? You don't want to DIY the bulb swap? Also the Philips XV2 beat the Nightbreaker by almost 100 lumens.
And a follow on stupid question to save me some reading… for an ‘05 car can I just tell my service provider to “install Osram Night Breaker bulbs” and be done with it. I’m hoping the answer is Yes here, as I have 3 cars between ‘04 and ‘06 with factory xenon headlights.
Love this thread by the way. Thanks Gents. So far, for my next service visit, I’m up to: Osram Nightbreakers, Koni Yellow fronts, refinished center console from TexaM3, Imola leather armrest, SS brake lines (don’t know how that didn’t get done sooner, actually), CSL 255 tune, new tires (235/265) and maybe refurbished rims (if I can make a buy and swap make sense) — all learned and gained from this site.
Cheers, and cheers again!! 🍻
maw
Originally posted by Gools View Post
Are the Osram Night Breakers reusable for projector upgrade? Or does lightwerks suggest other bulbs for G5BRT?
mawLast edited by maw1124; 09-24-2022, 06:28 AM.
Originally posted by Obioban View PostI'm also running a lightworks setup. There's no upgrade like good projectors, for light output.
I later did 55w and better bulbs, which was nice, but nothing like the improvement from the projector upgrade.
So are the spec sheets for these bulbs meaningless? I just bought regular Philips 85122 bulbs for my E39 M5 as a first step to fixing its light output because they were the cheapest (~$70 for two) and the luminance spec is 3200lm .. exactly the same as the Nightbreakers. What is the difference here?
