Time for a cooling system refresh - OEM radiator still the way to go?
  • bigjae46
    Y'all getting a bit worried about summers in Atlanta etc always makes me laugh..... Come to Bahrain....125f and up to100% humidity to drown you too. Yipppeeee
    Yeah, I thought 140 degrees and dry in Baghdad was bad. Those Persian Gulf countries are on a whole other level.
  • D-O
    Touche
  • chris719
    Originally posted by dukeofchen View Post
    Based on what I've gathered from others here Modine is now NRF, and purchasing an OE gets you the same revised NRF unit. So unless that's incorrect, finding an old stock or going used would seem to be the only ways to get the original design.
    Either way, time will tell whether I'm in for the same headache getting it installed, but I figure it'll be better than the crusty old one I have in there. As you said, summer is coming and the couple days of 90F+ we had over the weekend already saw my temp gauge creeping up again.
    I just bought a genuine Z4M rad and it was still Modine identical to the 2006 part it replaced.
  • 0-60motorsports
  • Ricky_Mac35
    I've been having the same looking splatter ever since I replaced my original water pump with a Geba water pump / and oem gasket. Should I maybe replace the new water pump with a bmw one or just re check the fitment?
  • D-O
    ​I love these as back to back posts.​
    Summer is coming :P
    Indeed. Summer in Atlanta, no less. I have track day scheduled at Road Atlanta in June. I will report back on how it goes.
  • dukeofchen
  • Obioban
    To close on this I ended up fitting the NRF unit. I had to add rubber washer/spacers between the upper driver side radiator and bracket/chassis side mount hole. Others seem to not have had this issue, but I fought it for hours, even dremeled different spots to try and buy more space and swear it wouldn't line up otherwise.
    One more thing about the NRF, the fins are laughably softer than genuine so be careful.
    If I could go back I would just have ordered the genuine.
    FYI just ordered this unit advertised as NRF from eBay.
    For the price, worth it for a flier.
    Update:
    Two track days on top of regular use and the Koyo is still going strong. Zero problems.
    Summer is coming :P
  • D-O
    Update:
  • dukeofchen
  • bavarian3
    We need to make an official sticky thread with which parts on these cars that need to be Original BMW and what you can use Rein/Febi/etc for. I’ve heard from a couple people that these rad hoses are a must be Original situation.
    Yeah so about the hose, I ended up trimming mine. Apparently with the rein hoses the o-rings suck too. I changed mine with the Viton kit sold on here.
    The lower rad hose fit fine fwiw.
  • Cronenberged
    I kinda did that with the best bushings thread, I don't mind to contribute but it would be a side project and take some time. Also, would be good to add list the + items in order of greatest to least like CSL boxes, reinforcements, so forth.
  • Nate047
  • bavarian3
    correction on the upper rad hose fitment. the radiator isn't the issue. the rein hose is. with the two hoses lined up on the thermostat housing this is how the hose ends up.
    rein on top
    genuine on bottom. genuine fits with minimal tension.
    this still leaves the issue of the upper mounting hole not lining up. this seems to be due to the sliding bracket on the radiator. can't quite pinpoint what's wrong, but something is offf.
  • Cronenberged
    I purchased a Modine from FCP and was sent one of these. After fighting the thing for an hour due to misaligned top mounting screw hole, I measured it next to the genuine piece and turns out it's taller.
    Did you have any issues with fitment? Not sure where to go from here.
    also tagging Cronenberged
    Really wish FCP would use the information I provided them that Modine doesn't produce our radiators anymore.
    Sounds like you just got the wrong one, would definitely just exchange it for another one. NRF is BMWs new radiator manufacturer, but 2 of their 3 production plants are in China so maybe it's just a mis labeled product. I didn't have any fitment issues with mine though.
