Time for a cooling system refresh - OEM radiator still the way to go?
I am hunting down a radiator as well. Spoke to someone in dealer parts yesterday who said Germany has approx. 500 radiators in stock. One is headed my way, so orders can be placed / filled now with some certainty. My ETA is 3 weeks.
No worries appreciate you checking, I'll see if the dealer has an ETA.
Seems like several went out of stock. Some of this didn't indicate out of stock, but I'm not 100% sure.Originally posted by CrookedCommie View Post
Can you share? Quick google search shows sites out of stock
Notably they we're in stock a few months back. Apologize if I teased you.
Can you share? Quick google search shows sites out of stockOriginally posted by Cronenberged View Post
I've found the Modine on several other sites in stock.
I've found the Modine on several other sites in stock.Originally posted by CrookedCommie View PostOE works great on track, just need them back in stock
That’s exactly what I’ve been looking into. Vorshlag built something for one of their LS swaps. I’ve also been looking at something like Chase Bays tucked radiator which is a tad smaller.Originally posted by mrgizmo04 View PostTry to tilt the front of the radiator forward so it sits more at an angle and build a shroud in back to send air up through the front hood vent. Potentially requires manipulation of hose attachments depending on how steep the angle is.
But then custom ducting in the front. As Obioban mentioned, I’m a stickler for weight. All of this might add more weight.
Try to tilt the front of the radiator forward so it sits more at an angle and build a shroud in back to send air up through the front hood vent. Potentially requires manipulation of hose attachments depending on how steep the angle is.Originally posted by bigjae46 View Post
I've been re-thinking my radiator/oil cooler setup. I'm exploring ways to improve airflow through the coolers, primarily behind the radiator. So far, I'm confident that I can go with a lower capacity radiator and a larger single oil cooler and achieve similar water temps and better oil temps. The problem is ducting air flow out through the hood. If I can push the radiator forward a couple of inches then I'd have enough room.
Lol...you're absolutely right!Originally posted by Obioban View Post
I'm surprised you're running that, as the most weight obsessed person I know of. Extra weight, at the worst possible point, with no benefit in exchange...
Not sure if it's worth the effort. Probably will just throw in an OE radiator in with a large oil cooler attached in place of the AC condenser.
I'm surprised you're running that, as the most weight obsessed person I know of. Extra weight, at the worst possible point, with no benefit in exchange...Originally posted by bigjae46 View PostI have a CSF on a track car, no issues and it cools quite well even when I beat on it pretty hard. I've also coded out some fault codes related to the AC and temp sensor in the lower hose, deleted the heater core loop, deleted all fans, and relocated the expansion tank to the drug bin so not sure if that all helps with odd coolant readings.
With that said, the CSF really doesn't offer much of a benefit over the OE radiator if any. No reason to with anything other than BMW or Modine.
1. E46 did have a problem with cracking radiators, but only non-m, because they have more plastics and their expansion tank is attached to the radiator on the driver side.
2. Nothing is "better" than actually maintaining your radiator. Better done if off car - blow it out (using air or water) once in a while to get the rocks/bugs/feathers/dirt off (in direction opposite to airflow) to restore cooling efficiency. If your fins are bent, unbend them with a jeweler's screwdriver, or there are actually "comb" kits available. The radiator needs air flowing through it to exchange heat. Same as above applies to oil coolers, blow them out.
3. More importantly for why you might be having cooling issues and looking to replace the radiator, is not the radiator, but the AC condenser. AC condenser sits in front of the radiator and if its veins are blocked with crap, your radiator is not getting proper airflow. So first I'd be looking at the condition of the condenser, not the radiator. Similarly blow it out, unbend the fins. At some point you might have caught a big enough rock in it that smashes enough fins to warrant a replacement instead. Bigger job since you need to refill the refrigerant, harder to get to/off the car, but bigger bang for the buck in terms of keeping your oil temps low. So AC condenser should be part of cooling system refresh.
