Originally posted by Altaran
This is all on standalone ECUs. The S54 knock sensors are very good and any decent standalone ECU will have no problem using them for knock feedback and can get you a safe tune that is also riding right on the edge of MBT/knock. This cannot be said for all types of engines or ECUs. I find there are few people actually doing proper tuning on the factory DME, and it seems overly sensitive to knock noise if knock base levels are not adjusted properly, so you must take any sort of tuning related information done with factory DMEs with a grain of salt.
For your original question, your theoretical 13.44:1 is likely still going to be too high for any sort of pump gas. If you can assemble that engine with those specs without valve-valve or valve-piston contact, and with full Vanos range, it will be a fantastic E85 (or 105++ RON) engine.
