3D Printed Carbon Fiber Polycarbonate Intake (Louder intake noise)
  • Flow
    Just ordered an intake with the AFE filter.
    I want to see what sound it makes as I love intake sound more than exhaust
  • TeddybearCup
    I never got my hands on an Eventuri to compare. The K&N shield does not work. The placement and hole size are very different.
  • dHam_Slow.46M
    Planning on swapping out my K&N for another intake and its toss up btwn this and an eventuri. Was there ever a comparison video/sound clip of the 2?
    Also, would the K&N heatshield work with this horn?
  • TeddybearCup
    Been a long time since I've posted. I've mostly been busy setting up and tuning a turbo 2ZZ swapped MR2 spyder. But over the last couple of months, I've gotten a batch of my heat shields in black and also, found an even stiffer, stronger filament than polycarbonate CF: PPA-CF.
    I had a few intakes get damaged in shipping or install and wanted to make them a bit more durable. This filament costs twice as much as the PC CF, and it a major pain to print with. It's so stiff, I have to be really careful setting it up since it can poke into my PTFE tubes and get stuck, or break if I try to force it too much into the printer. It's also a pain to work with after printing. But the results so far have been really promising.
    Anyway, people have asked about a heat shield for a long time. This serves two purposes for me. 1. I like the support it adds, taking load off the elbow. 2. It slightly lowers IATs. I still stand by the fact that temps drop quickly once moving even without a heat shield, but this seems to slow down IAT creep a bit when stopped.
    I have one used heat shield in raw aluminum I took off my car, plus 3 new ones on hand in black for anyone looking to get one and had an original kit without a heat shield. Just message me your order details so I can make sure it'll fit your car. It only fits E46s, and I've only run it with the oem elbow so far.
  • BigRussia
    Hey all, I'm actually selling a lightly used silicone elbow version of the 3D Printed Intake here:
    https://nam3forum.com/forums/forum/c...dward-printing
  • Johnvu
    Originally posted by TeddybearCup View Post
    Been well overdue on an update, really sorry for missing my estimates over the last few months. I started spending more time with family for the Thanksgiving and Christmas holidays and didn't work much on 3d printing related projects. Got another family vacation coming up, but have had a few inquiries over email on the heat shield.
    First production version of heat shields are in, and I got packaging figured out (big 14" box!) as well as trim, a mix of fat rubber D loop seal and a 3d printed insert so there's not metal to intake contact during install.
    Initial shields will be raw aluminum, because Sendcutsend charges an arm and a leg to anodize or powder coat, and it's below freezing here so I can't paint them myself. So early adopters will need to DIY paint if you want them black.
    It mounts through a single screw on the bottom, and the whole piece has some flex, to reduce strain on the intake and elbow from engine movement on power. I
    nstall IS a bit of a puzzle: You will need to have the intake, filter, and shield all loosely together, the elbow off the manifold, and be careful moving the shield and intake combo in. You might be able to get away with the shield in first and then assemble the intake and filter from either side of the shield, but it basically doubles install time.
    I'll have these up on my site by end of the month, but priority will go to people who already bought an intake.
    Hell yeah! I will be ordering whenever these go live! Thank you!
  • TeddybearCup
  • TeddybearCup
    Originally posted by nikh23 View Post
    following for updates on the shield. just picked up one of your pieces locally and interested in purchasing the shield when you're ready to retail it.
    Also saw this while perusing Vortex's website. Any thoughts if it would potentially fit your unit?
    This doesn't fit, not enough space by the filter area, and hole isn't quite in the right spot either. The shield needs to slant inwards to provide the room necessary. I bought one way long ago to see if it was an easy adaptation. Vortex does make an aftermarket scoop! It's also very affordable.
  • Kdubski
    Off topic but does anyone produce an aftermarket eventuri style brake duct air scoop?
  • nikh23
  • TeddybearCup
    Originally posted by Albino09 View Post
    Sounds great! Just as an FYI, some of us do not have Xenon headlights and I see you had to trim your shield to fit within the available space. If you look at the Turner version above, they get around headlight variation by running the shield against the strut tower. I understand the volumes you'll be talking about here do not need to accommodate everyone, but just something to keep in mind as you offer these to the public.
    Oh, didn't realize that was a variation to account for! Thanks for making me aware.
    I may go ahead and release this tweaked version and print an insert to fill in the gap without the casing in place. That way, I can get higher volumes made to save on cost and just add the insert for people who need it.
  • Albino09
    Update:
    I've had the first functional prototype on the car for the last week or so. (delay after I messed up which way the bends had to go) Had to cut a bit extra for a plastic pipe my scanner didn't pick up but otherwise, gaps are on point after adding in the loop end seal and it follows the chassis sheetmetal very closely on the right. The scanner came in clutch for that.
    Sound hasn't been muffled, possibly improved a bit, from having a bit less strain on the intake. That might be placebo though.
    Currently back to driving the car each day to and from work, and it's still a blast to drive.
    Personal thoughts on the design:
    I really like how the shield design ended up. Unlike the Eventuri shield, it actually captures the airflow from the front duct and the bottom duct really well, and it goes higher up and actually does a decent job sealing against the hood. It's not airtight, but it's a whole lot better than the Eventuri shield.
    Having had the K&N, having this style of rubber trim is much more effective than the stupid rubber that came on K&N's shielding. That thing barely held on to the shield, much less pressed against anything.
    For the stock elbow, having the shield sit on the filter rubber means it's not going to add strain to the plastic intake or mess with reverberations there.
    My only concern is owners with silicone boots. Silicone boots have different angles and lengths and I can't account for all their placements. The way I have this shield designed and mounted means it can move around a bit and flex as needed (I deemed this necessary because engines move under load and I don't want to add strain to the system from a super firm setup. This flex might be enough for some variations in mounting with silicone elbows.
  • TeddybearCup
    Update:
    What's next:
    It's been a busy time in life for me, though it's finally starting to ramp down. I just sold my E36 M3, picking up another car, and wrapping up the track season here in Wisconsin this month.
    My wife and I have been playing a whole lot of Baldur's Gate 3 and I'm troubleshooting some fueling issues with my Z, but should have a revision to account for a few tweaks to the shape and some production runs ready later this month.
    Those will be black, because raw aluminum looks too out of place in the engine bay. I will be playing with a few edge trim options for the pass through hole.
    Availability:
    Estimating I'll have the heat shields available around the end of this month. I'll be offering them first to existing intake owners, though expect I'll quickly just have them available overall.
  • Albino09
    I would be happy to buy one when you have the complete kit finalized.
    Second!
  • TeddybearCup
    (1) E46 M3 at BHF, 1:21.65 - YouTube
    Posting the latest track day, where it ran great.
    Car was going faster at the end of the front straight compared to last year. Looked to be about 8 mph faster at the end. 1.4 second lap time improvement (previous best at the same track was 1:23.05 with me coaching a bit from the passenger seat), on end-of-life tires too. Would say a lot of the change was due to the driver, but I do believe the switch from K&N to this intake made the car run better on track.
    I am pretty hopeful in getting a heat shield I can sell sometime in september.
    EDIT:
    Got a prototype sheet metal piece in finally and the bends were made in the opposite direction from what I needed. Sets me back a week or so, but getting close to being able to confirm a design.
