New Software Utility for the E39 M5 & E46 M3 by ECUWorx
  • ac427
    Does the ECUWorx tool work on Windows XP ?
  • terra
    Originally posted by Zekarus View Post
    maybe you can open a thread about this issue or tell us what the problem with the mssflasher csl files is? I also remember a thread about the alternator problem with csl ecu software and your troubleshooting about this issue. would be really nice to recreate that thread. can't find it on google cash. thanks in advance.
    As per the title I've just put together a new utility for you guys that can do a few basics on the DME. Click image for larger version Name: DME_Utility-Release.png Views: 0 Size: 30.8 KB ID: 20329 Click image for larger version Name: DME_Utility-Release-Codes.png Views: 0 Size: 17.7 KB ID: 20330 The software can be used
  • Zekarus
    The binaries on MSSFlasher do omit a change that might be causing that issue. I hadn't spoken up too much about it in the past since people were seemingly using it without issue. I could upload binaries that do make the change
  • Martyn
    Adjusting the vanos offsets will obviously allow you a little more advance/retard depending what you are shooting for.
  • Anri
    Per cam. +/- 8º is the DME's adaption limit.
    That does suggest that the VANOS adjustment limit could theoretically be increased by a good bit messing with the software, but in that situation if you don't get it spot on, you would increase the risk of bending a valve.
    Terra,
    Vanos adjustments are good via the software and playing with the
    timing is good to set the desired curve/power.
    Thinking of how good std car with mild tune and cat back feels in the
    lower rpm/s. Exhaust system is part of the vanos/power curve.
    The factory piston to valve clearance has good margin. I have another
    S54 engine for re-fresh and will Clay the pistons and set the timing via
    degree wheel and see were the limit is when the camshaft is off from
    the factory spec of course using the std 260 cams. Ehh will see if I get
    enthusiastic about that....that is a lot of work for just to find where the
    limits are on the intake and exhaust timing with std cams.
    With large cams and lift that is a must to find the limits
    Regards,
    Anri
  • terra
  • Anri
    As long as the timing is within +/- 8º of the targe
    Hi Terra,
    Do you mean 8 Degrees combined or per cam ?
    When I set the timing on S54 I do use the Double pin tool
    meaning both cams must be aligned perfect or other wise
    the second pin will never ever ever slip in but again I do
    the timing on S54 the way that both pins drop in on its own
    weight. So basically the timing is within ~1+/- or less.
    I believe the reason the OEM tool uses Single pin is to
    allow for not perfect timing meaning exact spot on with-in less
    than a 1 or 2 max combined but rather up to few degrees apart
    and if Check engine code show Vanos off range then Technician
    must re-adjsut the timing.
    My personal taste is 8 degrees is waay to much off but I assume
    the DME adaptation works this out...and who cares so long
    as the check engine light is Off..No wander one car feels
    different than other one...
    Regards,
    Anri.
  • terra
    Ha, this is why in my line of work they say not to order a test unless you're specifically looking for something.
    The VANOS adaption is just how much the DME needs to adjust the cam by to get the timing right. If the timing was 100% perfect, the adaptions would be zero. But getting it 100% perfect is pretty rare - there are tolerances built into all this. As long as the timing is within +/- 8º of the target, the DME can adapt to it. If everything is driving fine, and there are no errors suggesting the vanos isn't able to adapt, then there's nothing to worry about.
  • Ahmed.Alghoul
    Originally posted by Ahmed.Alghoul View Post
    Here's my readout
    We welcome any useful information about my readings, vanos have never been worked on. and do not have any issues on car running
    Click image for larger version  Name:	20200511_231456.jpg Views:	0 Size:	154.1 KB ID:	23630
    did reset adaptation
    I took the car for half-hour driving and re-read the adaptation
    Click image for larger version  Name:	after vanos readaptation .jpg Views:	0 Size:	83.9 KB ID:	23981
    Martyn,​
    I hope you'll give us minutes of your time with thanks to explaining the best Vanos values ​​to us, and when we can say that we have Vanos issue
  • Ahmed.Alghoul
ID:	23982 Here's my readout
  • dl.m3
    Here's my readout. Anybody knowledgeable care to comment on the Vanos adaptation values? Vanos overhaul has not been done on this car. The ignition retard is unfortunate, but i didn't expect much because Canadian gas here sucks anyway.
  • OneSwellFoop
    For anyone following my saga, the new tune worked and I was able to read my codes! MSSFlasher was an outstanding value for a CSL tune when I first bought it for my car and now is even more so. I could have been told that it was my problem and to go pound sand or buy a new tune, but Terra dropped a new tune that solved my problem.
    Now to look up these error codes and to get my engine running right!
  • Tbonem3
    Are there any obvious ranges for them to be in or differences between values on cylinders that point to potential issues?
    Like compression? Good question.
  • ATB88
    Essentially they're knock adaptions. Negative numbers means that much timing is pulled, positive numbers mean that much timing is added to whatever the final calculated desired spark advance is.
  • Tbonem3
    What can we do with that info though, or is it something we give to our tuners for them to make changes?
