Originally posted by Tbonem3
New Software Utility for the E39 M5 & E46 M3 by ECUWorx
Essentially they're knock adaptions. Negative numbers means that much timing is pulled, positive numbers mean that much timing is added to whatever the final calculated desired spark advance is.
The battery light comes on with the key in position 1.Originally posted by terra View Post
Next time you drive the car just see if the battery light comes on with the engine off. Based on what you PM'd me it probably does.
Next time you drive the car just see if the battery light comes on with the engine off. Based on what you PM'd me it probably does.Originally posted by OneSwellFoop View Post
Messaged you for contact info. I don't know for certain whether my battery light works as I don't recall it ever coming on. My car was manufactured in September of 2003.
Messaged you for contact info. I don't know for certain whether my battery light works as I don't recall it ever coming on. My car was manufactured in September of 2003.Originally posted by terra View Post
You'll need a hex editor. For now, maybe it'll be best to send me your tune and I'll just make the changes for you - you can read up on how offsets and binary changes work when you have some time.
Does your battery light currently work? If so, you can leave it alone. If not, then it'll probably be best to make the changes. To my recollection, 04.5 and newer M3s are what use the CAN-bus for the alternator light from the factory.
You'll need a hex editor. For now, maybe it'll be best to send me your tune and I'll just make the changes for you - you can read up on how offsets and binary changes work when you have some time.Originally posted by OneSwellFoop View PostProgram is flashed and tune is read and saved to desktop. What program should be used to edit it? Notepad and Wordpad just show a garbled file and "0xE002" cannot be found in a search.
In regards to triggering the alternator light over the CAN-bus, would you recommend this change? I haven't done any wiring changes and merely installed the tune and such on my otherwise stock SMG M3.
Try this: https://nam3forum.com/forums/filedata/fetch?id=12984
Flash only the program - leave your tune as is (the tune built into the file above is just a standard CSL tune).
Now read off your tune and change 0xE002 from 00 to 01, then flash that tune to your car.
That program also has the changes to trigger the alternator light over the CAN-bus. To enable that, you'd set 0x5968 to 01 05 0A and enable "GENERATOR_UEBER_CAN" in your instrument cluster. If you already have the direct wiring done, then you could leave it alone and things will function like they did before.
If you could upload the binaries that would be fantastic! I'm using the CSL tune from the MSSFlasher website and cannot read my error codes. Interestingly, I have no issue reading error codes for the transmission.Originally posted by terra View Post
The binaries on MSSFlasher do omit a change that might be causing that issue. I hadn't spoken up too much about it in the past since people were seemingly using it without issue. I could upload binaries that do make the change
My odyssey is as follows: Posted on here yesterday about issues reading the codes. Had the convertible top error light start flashing, later on, dash lights start flashing even when there's no key in the car. Figuring it might be a low battery causing the issues, I hook it up to a trickle charger for 4-5 hours. Following that, only three lights on the dash would light up at all, no response whatsoever when I turned the key, and driver's side window was stuck partially down and would not budge.
Took the battery to Autozone to be tested, they said it was too dead to test, but that they'd charge it then test it. I go back 4-5 hours later to have them test it and it picked up no charge at all. Battery is dead as a doornail. Got a new battery, dropped that in, no more flashy lights and all electrics appear to be working fine, except for the fact that I now have a cog light on (error code is 97, spannungsversorgung ubatt, and I think just related to the low voltage and bad battery..
So, that's one issue tackled but, after all that, I still can't read my engine error codes.Last edited by OneSwellFoop; 05-07-2020, 12:32 PM.
That would be awesome as it is quite annoying to have to get a different cable to pull codes.Originally posted by terra View Post
The binaries on MSSFlasher do omit a change that might be causing that issue. I hadn't spoken up too much about it in the past since people were seemingly using it without issue. I could upload binaries that do make the changeOriginally posted by Steve View Post
It’s the modified version that is available on the mssflasher site. I recently got an additional obd2 reader for another brand of car that can also do basic code pulling on any make, I’ll have to try it out to see if it can pull codes.
It’s the modified version that is available on the mssflasher site. I recently got an additional obd2 reader for another brand of car that can also do basic code pulling on any make, I’ll have to try it out to see if it can pull codes.Originally posted by terra View Post
Interesting. Is yours running the true CSL bootloader or the version modified to work with the stock one? If the latter, where did you get the modified binary?
Interesting. Is yours running the true CSL bootloader or the version modified to work with the stock one? If the latter, where did you get the modified binary?Originally posted by Steve View Post
Mine does this too and has done it every since I went to the CSL software. INPA does the same but my BT cable can read them without issue. If I clear the faults without reading them first, the program will run correctly and then tell me, of course, that there are zero faults.
Mine does this too and has done it every since I went to the CSL software. INPA does the same but my BT cable can read them without issue. If I clear the faults without reading them first, the program will run correctly and then tell me, of course, that there are zero faults.Originally posted by OneSwellFoop View PostHow long should it take to read the faults? I hit Read Faults and the program does nothing then crashes and I've got to kill it in task manager.
Well, it appears that I may have larger issues. I noticed that the convertible top light was flashing even though the top is and has been fully closed. I figured it might be because of a low battery issue, since a low battery can make our cars do all sorts of wacky stuff and it's been sitting for about 3 weeks. My charger shows the battery as fully charged, but it's very old, and the car didn't want to turn over when I tried to crank it as a test.
I've got it on a trickle charge, so hopefully that will correct the convertible top error and my inability to read the errors properly. Ah, the odd pleasures of owning a 16 year old BMW!
