Vanos Rebuild Start Hesitation
  • sapote
    Originally posted by jamesfoley View Post
    I kind of guessed that would be the case, but figured a new TPS wouldn’t hurt even if it was just an experiment.
    Just can’t understand what’s going on with this to be honest, the car thinks everything is fine but clearly something isn’t happy
    Is your main concern about the status 8, or other problems? Mine also has fuel status 8 ocationally but I think my engine is normal.
  • jamesfoley
    If no codes related to TPS then they are working fine.
    Just can’t understand what’s going on with this to be honest, the car thinks everything is fine but clearly something isn’t happy…
  • sapote
    New sensor gives me 0.53v closed, and 4.07v open on the DIS diag page. BMW technical documents kind of suggest both the throttle and actuator sensors should be opposite, so the throttle TPS when open should match the actuator TPS when closed, but mine don't seem to. I don't know if that suggests the throttle isn't opening as much as the DME thinks it is?
  • jamesfoley
    Replaced the front TPS with a Hella 6PX 008 476-271, part seems identical to the original other than the BMW logo has been removed.
    I do realise the MSS54 adapts both the closed and open points, so chances are this wouldn't change anything. Either way, new sensor is in and all adaptations cleared in DIS. Throttle position adaptations were still present after an adaptation reset in DIS though, so unsure if its just reset fuel, ignition, and VANOS adaptations, and it leaves the throttle to continue to adapt on the pre and post drive checks.
    First drive made no changes to how it reports a fuel system status of 8 when off throttle, but not sure I care about this anymore as it seems to be normal: https://datazap.me/u/jamesfoley/e46-...g=0&data=1-2-3
    Will just see what the starting characteristics are like over the next couple of days I guess.​
  • jamesfoley
    Just want to get some clarification on something.
    MSS54 documentation says that the throttle body TPS should be 0.5v closed and 4.5v open, with the TPS on the actuator flipped at 4.5v closed and 0.5v open.
    Pulling TPS values from DIS I have 0.39v closed and 3.94v open on the throttle body, then 4.35v closed and 0.57v open on the actuator.
    Actual throttle positions are going 0-100% so I'm guessing it adapts to the open and closed position values.
    Is it possible that either of those are worth replacing?
  • jamesfoley
    Mine also has status 8 sometimes; never see 8 on M52 or M54 engines.
    It has stock Dme firmware
    Was just wondering if its an early software version thing really. if yours was also as old as mine it might be, though if yours is more recent then its doubtful.
    If fuel return hose blocked, you would run out of fuel with half capacity show on gauge due to suction pump not working to transfer left to right tank
    Fair point, all return is done through the same line that the regulator bleeds through.
  • sapote
  • jamesfoley
    Postcat sensors don't control DME, but they indicate the rich condition of mixture (unless they are old and bad that don't function properly). IOW, they smell too much fuel and switching as the precat instead of staying at high level most of the time.
    ICV is ok.
    bad purge valve should pop the error code, so I think it's fine
    fuel return hose can't be blocked.
    measure the fuel pressure anywhere between regulator output and fuel rail.
    here is the log:
    https://datazap.me/u/sapote/e46-m3?log=0&data=10
    I mean, looking at that log you do have the same open loop fault readings that make me think its normal for the MSS54 to do that for some reason? Out of curiosity whats the software version on your DME?
    The fuel return idea came about because a previous owner has done the RACP work, which means the fuel tank has been out before. More so wondering if the fuel return was pinched or damaged rather than physically blocked.
  • sapote
    ICV is ok.
    here is the log:
  • jamesfoley
    As about the fuel pressure, just verify this with a P gauge at different rpm. Also check injectors condition.
    Is the pressure from the valve on the regulator what I should be seeing at the rail, or just from the pump?
    Sort of tempted to get the Radium rail installed just for the pressure gauge on the end of the rail. Would also be kind of nice to get a digital fuel pressure gauge just because it'd be somewhat useful.
    I looked up my M3 log, it did have a few status 8 during deceleration, but the total fuel trim is around 3.2 at hot idle; yours shows rich with negative fuel trim and switching postcat sensors.
    Any chance you could post the log for me to take a look at?
    Post-cat sensors do nothing fuel map wise though right, they just monitor the efficiency of the cat itself, so worst case is it'd just fail emissions due to worn cats.
    I can't think of any way the car can be accidentally too rich that I haven't already covered...
    ICV not opening enough at idle so its getting less air than it thinks it is? I cleaned this already so it'd be a faulty ICV if anything.
    Injectors were replaced with a known good (cleaned and flow tested) set with no change, so they shouldn't be leaking.
    FPR is new so I shouldn't be enriching anything through the vacuum line.
    Purge valve could be stuck open, but this would be a vacuum leak more than anything right? Certainly shouldn't be enough vapour to make it rich all the time unless my carbon canister is saturated or something...
    Fuel return being blocked so injectors are seeing full pressure all the time would be a reasonable cause for the car to pull fuel all the time. It should read less pressure at idle compared to when the engine has a load right?
  • sapote
    [/LIST]Along with anything in the list above being the culprit, two other thoughts are:
    • DME running software that isn’t stock
    • Fuel pressure isn’t being bled off by the regulator, pressure too high at idle / closed throttle. Possible issue with fuel return.
    your MAF looks fine.
    The post cat sensors in the log show they couldn't treat the exhaust gas properly during driving -- both followed the precat sensors; could be old tired cats or rich mixture that couldn't be treated. I think the mixture are rich is the issue.
  • jamesfoley
    should provide total fuel trim, ltft alone is not enough. This sounds rich mixture which is very unusual, and the little high idle also supports the theory.
    You should check the MAF rate even if it's new. Low reported MAF can cause rich running.
    We had proved it wasn’t MAF related, here is a warm no accessories log from a while back: https://datazap.me/u/jamesfoley/e46-...no-accessories
    Worth mentioning that the car does still sputter for a second or two when it starts, but it’s very intermittent.
    Also the car sometimes starts too quickly. The engine barely rotated before it catches and starts, as if it starts as soon as the key is turned. Not like this is an issue, but it’s just weird to have it instantly start up.
    There are still a handful of parts I’ve not replaced:
    • Intake camshaft sensor
    • Exhaust camshaft sensor
    • TPS under intake
    • TPS next to oil filter
    • Throttle pedal
    • Fuel tank purge valve
    • Idle air control valve (though I did clean it)
  • sapote
    Hot idle LTFT’s sit around -5% both banks, give or take a couple of percent depending on how the car feels.
    Idle rpm seems to hover between 870 to 890.
  • jamesfoley
    IF Evap leaking then you sure have a code.
    I don't think ICV at issue, as this should cause bad idling but you have steady idle rpm at around 850, do you?
    Had you posted fuel trims at hot idle before?
  • sapote
    I mean I guess it’s possible the ICV isn’t letting enough air through, or too much through for what’s being commanded? Another thought is an issue with the EVAP purge valve leaking and enriching the mixture causing it to run richer than expected?
    MAF is brand new from BMW and rates were fine last time they were checked.
