comment : Status Schubabschaltung
mean fuel cut during deceleration (throttle pedal 0%).
Can you read,
STATUS_ADAPTIONSBLOCK_06
STATUS_ADAPTIONSBLOCK_16
STATUS_ADAPTIONSBLOCK_26 and
STATUS_ADAPTIONSBLOCK_83
and post results in a text file by copy-ing the results from the results screen?
Vanos Rebuild Start Hesitation
I don't suppose anyone has the translations for the results of the Tool32 STATUS_DIGITAL job?
I have a rolling log with some suspect graphs, but I'm not sure what the datapoints translate to. STAT_SA_EIN for example. https://datazap.me/u/jamesfoley/e46-...?log=0&data=42
Correct, it’s never happened just leaving the car to idle. It also doesn’t seem to happen when the car is cruising at a fixed RPM. Only when there is a change in RPM.Originally posted by sapote View Post
So not during idling?
So not during idling?Originally posted by jamesfoley View Post
Not sure anything has changed, looking through all of my logs I get fuel status 8's at all sorts of RPM, its never been just high RPM. Just seems to be when coming off throttle, so even little throttle inputs cause it.
Not sure anything has changed, looking through all of my logs I get fuel status 8's at all sorts of RPM, its never been just high RPM. Just seems to be when coming off throttle, so even little throttle inputs cause it.Originally posted by sapote View Postwhat had been done to cause it no longer shows up at idle now?
“Edit: Looking back at older logs I can see fuel system status 8 at 850 rpm, so I guess it's just happening all the time”
Can't get any air past the fuel tank breather, so assuming its normally closed until engine is up to temp it must be fine. Unless of course its intermittently sticky where sometimes its stuck open, but that might be a bit of a long shot.
I agree that it might be unrelated, but the fuel system status and O2 sensors read like its misfiring, and EVAP issues can cause hard starts and misfires so figured it was worth checking. Logs also have the fuel system status of 8 at 1600 rpm so not just high rpmOriginally posted by sapote View PostI doubt these issues can lead to fuel system status 8 during high rpm as you have.
Starting to wonder if I'm trying too hard to blame something complicated. Wonder if it's just a bad spark plug, or perhaps head gasket which I've been trying to avoid blaming.
Edit 2:
Just incase this is of any use, I took the car out on my usual test route with GT1/DIS hooked up for the misfire counter, got 0 on all cylinders 🤷♂️
Here is all the data from the DIS Diagnostics screen after the drive, might be useful for someone:
Code:Diagnosis DIAGNOSIS REQUESTS (MISFIRES) Misfire counter: ACTIVE Current Cyl. driving cycle: 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 Note: Current driving cycle: number of detected misfires since engine start Diagnosis DIAGNOSIS REQUESTS (THROTTLE POSITION) Potentiometer, throttle position: 0% Potentiometer, servomotor position: 0% Voltage, potentiometer, at throttle: 0.35 V Voltage, potentiometer, at servomotor: 4.37 V EDK actuator, duty factor: 8.1 % Control factor, charge controller: 0.996 EDK specification by DME: 0% Diagnosis DIAGNOSIS REQUESTS (EDK ADAPTATION) Adaptations: Rise, pot. at throttle: 28.7 %/V Rise, pot. at servomotor: 27.6 %/V Throttle, leakage air: 2.6 kg/h Pot. at throttle, zero stop: 0.34 V Pot. at servomotor, zero stop 4.20 V Maximum deviation between specified and actual values of throttle position: 2.8 % Counter, increased EDK duty factor: 0 Counter, controller activation: 17 Counter, controller deactivation: 2 Diagnosis DIAGNOSIS REQUESTS (SENSOR-GEAR ADAPTATION) Adaptation, sensor gear, crankshaft: 1: 0 °/oo 2: -0.18 °/oo 3: -1.29 °/oo 4: -0.30 °/oo 5: 0.27 °/oo 6: -1.08 °/oo Counter,adapt 'n,sensorgear,crankshaft: 65535 Diagnosis DIAGNOSIS REQUESTS (ROADSPEED) Road speed: 0 km/h Vehicle speed via CAN: 0 km/h Cruise control: NOT ACTUATED Engine speed: 887 rpm Engine load: 22% Power supply: 13.7 V Ambient pressure (sensor in CM): 1013 mbar Air mass: 22.25 kg/h Relative opening cross-section from throttle and idle opening: 0.225 % Duty factor, tank-venting valve: 12.7 % Diagnosis DIAGNOSIS REQUESTS (BASIC QUANTITIES) Duty factor, electric fan: 65 % Clocking, electric fuel pump: 8.329 ms Oil level: 104 mm Tank fill level: 23 1 Diagnosis DIAGNOSIS REQUESTS (HFS) Voltage value, air-mass flow sensor: 1.14 V Air mass: 22.25 kg/h Diagnosis DIAGNOSIS REQUESTS (AIR CONDITIONING) Enable signal for A/C compressor: ON A/C-compressor request: ON Switch, air conditioning: ON Air-conditioning system: INSTALLED Diagnosis DIAGNOSIS REQUESTS (KNOCK ADAPTATION) Knock adaptation, cylinder 1: -2.03 °cr Knock adaptation, cylinder 2: -1.65 °cr Knock adaptation, cylinder 3: -0.59 °cr Knock adaptation, cylinder 4: 0.58 °cr Knock adaptation, cylinder 5: -1.37 °cr Knock adaptation, cylinder 6: -1.29 °cr Diagnosis DIAGNOSIS REQUESTS (OXYGEN-SENSOR CONTROL) Oxygen-sensor controller, cyl.1-3, control factor: 1.005 Oxygen-sensor controller, cyl.4-6, control factor: 0.992 Oxygen-sensor control cyl. 1-3: ACTIVE Oxygen-sensor control cyl. 4-6: ACTIVE Additive mixture adaptation (idle) cyl. 1-3: -0.068 ms Additive mixture adaptation (idle) cyl. 4-6: -0.112 ms Multiplicative mixture adaptation (part load) cyl.1-3 -2.04 % Multiplicative mixture adaptation (part load) cyl. 4-6 -3.26 % Note: Values lower than 0% mean mixture leaning Values higher then 0% mean mixture enrichment Tank-ventilation adaptation, cyl. 1-3: 0.96 Tank-ventilation adaptation, cyl. 4-6: 0.97 Weighting factor, diagnosis Fuel system, cyl.1-3: 1.00 Fuel system, cyl.4-6: 1.01 Diagnosis DIAGNOSIS:REQUESTS (IDLE SPEED CONTROL Specified idle speed: 870 rpm Idle controller: ACTIVE Idle-speed control valve, duty factor: 36.18 % Idle controller: -6.4 Nm Adaptation, idle controller: 12.3 Nm Adaptation, idle controller (A/C on): 3.6 Nm Diagnosis DIAGNOSIS REQUESTS (OXYGEN SENSOR HEATER) Shunt voltage, oxygen-sensor heater, before cat., cyl. 1-3: 3.559 V Shunt voltage, oxygen-sensor heater before cat., cyl. 4-6: 3.569 V Shunt voltage, oxygen-sensor heater after cat. cyl.1-3: 3.676 V Shunt voltage, oxygen-sensor heater after cat., cyl.4-6: 3.676 V Oxygen-sensor voltage before cat., cyl.1-3: 0.127 V Oxygen-sensor voltage before cat., cyl.4-6: 0.695 V Oxygen-sensor voltage after cat., cyl.1-3: 0.718 V Oxvaen-sensor voltage after cat., cyl.4-6: 0.752 V Diagnosis DIAGNOSIS REQUESTS (PEDAL-TRAVEL SENSOR) Pedal-travel sensor, potentiometer 1: Pedal-travel sensor, potentiometer 2: Adaptation, pedal-travel sensor 1 zero position: 684 mV Adaptation, pedal-travel sensor 2 zero position: 344 mV Voltage, pedal-travel sensor 1: 693 mV Voltage, pedal-travel sensor 2: 351 mV Diagnosis DIAGNOSIS REQUESTS (STATUS) Engine operating state: IDLE Inertia fuel shutoff: NOT ACTIVE Ignition-lock position 2: ON Ignition-lock position 3: OFF Brake-light switch: OFF Detection, adhesion (gear engaged, clutch not actuated): NO Fuel pump: ON Secondary-air pump: OFF Secondary-air valve: OFF DME enabling by EWS follows: YES Air-conditioning system: INSTALLED Diagnosis DIAGNOSIS REQUESTS (TEMPERATURE SENSOR) Engine oil temperature: 91 °C Outside temperature: 26 °c E46: via CAN from instrument cluster E36/7: from secondary control unit Exhaust temperature: 192 °C Intake-air temperature: 50 °C Coolant temperature, engine outlet: 91 °C Coolant temperature, radiator outlet: 76 °C Voltage, temperature sensor, intake air: 2. 28 mV Voltage, temperature sensor, engine outlet: 0.86 V Voltage, temperature sensor, radiator outlet: 1.23 mV Max. DME temperature: 63 °C Diagnosis DIAGNOSIS REQUESTS (VANOS) Inlet VANOS, actual value: 59.1 °cr Inlet VANOS, pilot control by DME: 60 °cr Inlet VANOS, adaptation: -4.4 °cr Inlet VANOS, status, adaptation: ADAPTED Exhaust VANOS, actual value: 1.6 °cr Exhaust VANS, pilot control by DME: 2 °cr Exhaust VANOS, adaptation: 4.2 °cr ExhaustVANOS, status, adaptation: ADAPTED Diagnosis DIAGNOSIS REQUESTS (SMOOTH RUNNING) Cyl. Smooth running (raw data) 1: -637 us 2: 835 us 3: 516 us 4: -353 us 5: 248 us 6: -133 us Diagnosis DIAGNOSIS REQUESTS (INJECTION) Diagnosis DIAGNOSIS REQUESTS (INJECTION) No. of deactivated cyls: 0 No. of deactivated cyls. DME spec.: 0 Cyl. duration of injection 1: 2.161 ms 2: 2.038 ms 3: 2.354 ms 4: 2.081 ms 5: 1.976 ms 6: 2.098 ms Diagnosis DIAGNOSIS REQUESTS (IGNITION) Cyl. ignition angle 1: 21.5 °cr 2: 21.5 °cr 3: 21.5 °cr 4: 21.5 °cr 5: 21.5 °cr 6: 21.5 °cr Diagnosis DIAGNOSIS REQUESTS (ADAPTATION IDLE SYNCH.) Adaptation Idle Cyl. synchronisation 1: -20 µs 2: -128 µs 3: 150 µs 4: 26 µs 5: -66 µs 6: 41 µs
"Did just have another thought though, I don't suppose it could be EVAP related seeing as basically everyone I take it to said it sounds like fuel? I've seen the DMTL pump mentioned in some threads but as far as I know my car doesn't have this, just the activated charcoal filter. There is the fuel tank breather valve though that connects to the same pipes as the ICV..."
Why check everything again when you can do it with a VANOS test I made for Tool32?
I'm trying to do a vanos test using INPA but it seems like it's missing that and some other functions. I can connect to the car and get error codes and engine data like rpm, temperature, etc. but it doesn't appear to be fully functional. I've tried two different DCAN cables with the same results. I've reinstalled INPA several
Also, reading the ECU with a small program won't affect your laptop. But we do can check if the calibration is untouched or modified.
For the DMTL/EVAP. If these valves leak when closed, fuel fumes could enter the manifold when standing still and have bad starting issues as a result.
Appreciate the offer. My laptop just about runs INPA without dying, so trusting it to flash my DME with someone logged in remotely is a big ask 😅Originally posted by Tomba View PostI can flash your DME remotely if you want. We can make a copy first and then flash latest software to begin with.
Car is hopefully getting booked back in for another VANOS timing triple check, I have an oil leak from where the VANOS meets the head so it needs to come off to change that seal anyways.
I'll look into picking up a better laptop I can use and then maybe hit you up Tomba
Issue I have with buying a new DME is that they're expensive to begin with, and then I need to find someone to either clone my DME, or do an EWS delete. So overall it would be an expensive experimentOriginally posted by sapote View Post“guess the only issue I have is that the DME doesn't seem to like throwing codes for anything 😅”
I suggested to reflash or replace the Dme before.
I figured it might have been for engines with multiple inlet/exhaust cams. Only reason I ask is the Exhaust bank 2 has an actual value that changes? Where it gets that reading from I have no idea...Originally posted by Tomba View Post
MSS54 is near to equal as MSS52 (used for S62) As S62 is V8 engine and has 2 banks and double VANOS these are used.
You have TestO, do you also have Tool32?
I have EDIABAS ToolSet 32, assuming that's the same thing?
