Vanos Rebuild Start Hesitation
  • jamesfoley
    Variances are common even after adaptations and the command vs actual is fine to mismatch while driving. 98% of the time the variances are within two degrees on my car. Get spikes where they can be greater.
    The commanded values at idle should be:
    intake: 60
    exhaust: 0
    Are mismatches expected at idle though? Inlet cam was rock solid 60 degrees with no variance, exhaust was flickering around a couple of degrees constantly almost like it was trying to adapt for the difference between commanded and actual but never being able to get them equal.
    Is TestO the only tool I can graph the cam positions? Pretty sure the guys I saw used an Autel scanner which could graph stuff, but they're expensive it seems
  • oceansize
    Originally posted by jamesfoley View Post
    I think they were more saying that even after adaptation, the DME requested position never matched the actual position. So even though it it was requesting 0 degrees, actual position was coming back as 1 degree. I thought the adaptation values were meant to correct errors in requested vs actual to make them match?
    Both intake requested and actual positions are exactly the same to the decimal place, so kind of assumed exhaust would be the same too. Wondered if it was this that was confusing the DME where the exhaust side of the VANOS is not left in the position it is expecting it to be when the engine is turned off, giving me the extremely random start hesitation depending on where the cam position is.
    intake: 60
    exhaust: 0
  • jamesfoley
    No issues, can be off by as much as eight degrees so you are fine.
  • oceansize
    Intake cam actual position compared to requested are exactly the same, but my exhaust cam actual vs requested are out by a degree. Exhaust values jump around all over the place and are never in sync.
    Can 1 degree on the exhaust cam be the cause of the issues?
    This was picked up by another specialist after confirming fuel pressure was good.
  • jamesfoley
  • jamesfoley
    these could be the key to the mystery -- DME program code is corrupted. Try to reflash the code or change to another working DME.
    For what it’s worth these codes only appear together with no other codes present, and P.A.Soft BMW Scanner is the only tool that shows me these. I get nothing in INPA or DIS/GT1.
  • sapote
    63 [099] Internal fault
    59 [089] Internal fault
  • jamesfoley
    E6 DME: Electric throttle: setpoint/actual value deviation
    ​This should cause the limp mode, and you didn't see the engine light turning on?
    "Codes cleared and have been replaced with two Internal Fault codes that do not clear 🤷‍♂️"
    What does this mean?
    Shadow codes could be just a momentary.
    Nope, no limp mode or lights on the dash, figured it was just because I removed the plug for the throttle position sensor at the front of the engine.
    As for faults I’m always left with:
    Went for a 70 mile drive and have the log: https://datazap.me/u/jamesfoley/e46-...0&data=1-2-3-4
    Looks the same as all the others. It didn’t throw any other codes after that other than the two internal faults.
  • sapote
  • jamesfoley
    Can confirm injectors did not change anything, still the same intermittent crank no start, or intermittent hesitation starting.
    Pulled these codes:
    Click image for larger version  Name:	nSdKrf2.png Views:	0 Size:	709.6 KB ID:	220865
    I can understand injector and throttle position sensor codes as I had to unplug them to remove the injector harness.
    The crankshaft sensor code however seems to have come back? I replaced the crankshaft sensor already so not sure why I am seeing this again...
    Looking at the OBD graph, are the O2 sensor readings and fuel system faults actually misfires?
  • jamesfoley
    Bit of a boring update.
    Got hold of a second hand set of injectors and had them cleaned. Fitted them today (which was a royal pain in the arse), reset all adaptations, and the car seems to run well. So far it has started first time every time with zero hesitation.
    However, looking at a log I still have a butt load of points where fuel system status hits "8", and the fuel trims are creeping back into the negative again. I really hoped that this would have fixed it 😞
    Here is a new log with clean injectors: https://datazap.me/u/jamesfoley/e46-...0&data=1-2-6-8
    Still zero reported faults through generic OBD reader and INPA.
    What was weird is that when I fitted the injectors, I removed the fuel pump fuse and cranked the engine to remove residual pressure. However it didn't start leading me to think it had zero pressure after sitting?
  • jamesfoley
    1. The mixture was on the rich side most of the time and this is why you have negative fuel trim, so maybe during status 8 moment the open loop injected fuel (based on the default look up table) was less than what the combustion needed, and so the exhaust gas was lean (0v o2 sensor). IOW, open loop is leaner than closed loop in your case.
    Only reason I feel its weird is because isn't the range of the O2 sensors 0.1v to 1.0v? I didn't think they were supposed to go to 0v, but this is just me going off what I've read around the web. The graph makes it look like it's going open loop beacuse the O2 sensors are at 0v, however there are a handful of times where the fuel status is 8 and the O2 sensors are reading higher values.
    3. I don't think so, as if it's then the injector should be weak with lean code. Also, the starter should be cranking weak or fails to crank.
    That's a fair point, the car cranks fine every time and it's never failed to crank.
    Also found this thread which you've replied to sapote which is extremely similar if not the same as what I am dealing with https://www.e46fanatics.com/threads/...sults.1304746/
  • sapote
    1. Again, O2 sensors seem to just go to 0v during those sections,
    2. not sure if they just report 0v when in open loop?
    3. but could I be having a engine ground issue
    2. No, DME doesn't force o2 value to 0v during open loop, as you can see the value changed during cold start open loop with SAP running.
  • jamesfoley
    Your money can buy a better USB based scope as it reuses many function of the PC already has, as opposed to standalone unit.
    I guess the downside here is I'll need a reasonable laptop, the one I use currently is pretty terrible.
    Just wanted to add this log which has some chunky sections where the fuel status was 8 for a bit longer. Again, O2 sensors seem to just go to 0v during those sections, not sure if they just report 0v when in open loop? Its both sensors as well so can't be a wiring issue surely?
    https://datazap.me/u/jamesfoley/e46-...0&data=1-2-4-5
    Might be a silly question, but could I be having a engine ground issue or would I have more issues than what I have currently?
  • sapote
    Originally posted by Shonky View Post
    Owon HDS242(S) (and also 272, 2102, 2202) are quite capable self contained scopes starting around USD120. Might be a bit easier than a laptop + USB scope.
    Most portable standalone scope with screen too small and also lack many good features, and this is why I suggest to have a PC USB based scope. The Pico I use can decode many different serial buses such as CAN, USB, I2C, SPI, rs232, UART, etc. With the PC bigger screen and better resolution, the signal waveform is easier to analyze, and the waveform can be saved and shared. Portable scope is good for working on the field.
