Vanos Rebuild Start Hesitation
  • Tomba
    Crank and camshaft sensors new and OEM?
  • jamesfoley
    Originally posted by Tomba View Post
    Fuel fumes would enter the manifold/plenum over time and cause rich mixture during starting.
    I have read a butt load of stuff on the DMTL system, but not 100% sure that matches my symptoms is all.
    Car can start perfectly fine in the morning and drive around with zero issues. I'll then come home, turn the engine off and take the key out, wait like 2 seconds, put they key in and try to start and it will struggle, or stall. Key out and in again and it starts fine as if nothing happened.
    However it will also randomly have issues on the first start in the morning too, key out and in and it starts as normal.
    It's super random, and now with the VANOS sorted but not resolving this I'm back throwing parts at the car and crossing my fingers.
    The rich condition sapote raised feels like the first time I might actually have some evidence its air / fuel related.
  • Tomba
    Wasn't there a thread on starting issues which pointed to the DMTL system? Fuel fumes would enter the manifold/plenum over time and cause rich mixture during starting. Check these valves and the one from the canister valve. I would personally remove them and plug them off at the manifold for testing purposes.
  • jamesfoley
    Yeah I mean it's been ~3 years for me at this point and I've learned to live with it. Doesn't affect performance, driveability, or reliability, is just annoying to know it doesn't have to be like this lol. I did try replacing the DME, no luck -- same behaviour on stock MSS54 DME and MSS54HP DME (with and without CSL airbox and associated tune). Also did FPR and vacuum line, and for injectors I initially tried cleaning, and then tried a totally fresh set since OEM Bosch was still available cheap back then. I hope you have a different experience, and/or somehow figure out something that I didn't!
    I don't suppose you know the length of the vacuum hose needed to go from the air rail to the fuel regulator do you? I've tried to pick this up but BMW want to sell it in metres. Same for the "Corrugated metal tube"
  • jamesfoley
    DME doesn't can't tell if MAF is over-reporting or not.
    "I assumed post cat values were based on the condition of my cats?". Could be but I think it could be due to the rich mixture.
    Use DATAzap https://datazap.me/ to convert your CSV file and post the link. It's easy for others to analyze the log data. Here is an example of the warm idle data:https://datazap.me/u/declamondo/log-...?log=0&data=10
    Here are some Datazap links:
    The fastest, easiest way to visualize, analyze, and share your automotive datalogs: for everyone from weekend hobbyists to pro tuners.
    The "More Town Driving" log does have a load of idle time at the start if thats of any use. Can always grab a longer log of needed.
  • sapote
  • jamesfoley
    1. It's better to have MAF in g/s instead of lbs/min, and temp in *C and not *F. At 860rpm your MAF=4.9g/s which is high or over-reported value. This can cause too rich mixture. MAF should be around 4.2.
    2. Your fuel trims show it's too rich - could be due to the MAF or leaking injectors. Leaking injectors can cause rich mixture during starting and hard start.
    3. Pre cat O2 seem to be ok, but post cat o2 switched to low a few times; it should be mostly around 0.8
    The log file was in view mode only and not allows me to insert graphs from the data. Change the protection or post it as CSV file type. I copied and changed to CSV but then the file was displayed as garbage data.
    But, if it was the MAF wouldn't the DME tell me something was up? I guess at least it might be an easy swap, but the amount of cash I've thrown at this problem now is getting silly.
    Injectors has been a suspect only because its the only thing the DME can't really report an error for. Its also been last on my list as the car is my daily and pulling the injectors and sending them away is a bit of a pain in the arse.
    I've attached the logs as a zip as I can't upload CSV files directly it seems. Alternatively if you request edit to the Google sheet I can grant you access, I just didn't want to make it publicly editable is all.
  • sapote
    Originally posted by jamesfoley View Post
    sapote Not sure if this is of any use? Pulled this using OBDWiz and my OBDLink SX cable as I figured it might be a little more reliable than bluetooth.
  • jamesfoley
    That spreadsheet has 3 sheets in it. The first is the car setting off after faffing with the logs and some town driving. The second is just pure warm engine idle. The third is town driving again after leaving the car for 45 minutes.
    Annoyingly it didn't suffer from any start hesitation, just started as normal. No idea why it goes through bouts of being fine, and then bouts of being upset. Sort of wondering if it's directly related to the weather with it being more temperamental when it's cold outside.
    If I can pull any more logs which might be of use let me know.
  • jamesfoley
    You should call the shop manager on this -- either they lack the skill or lazy to verify their work. They set the Intake off by about 8* too retard. This means you never can have the full intake advance at higher rpm and so engine was low performance. Did you find the IN was too retard by one spline?
    If the vanos timing was verified good, then the issue of hard cold starting maybe related to other things. Get a Veepeak OBD reader on Amazon ($31) and OBD Fusion app for phone ($15), then read the data in a log file with these data: MAF, engine temp, intake air temp, rpm, fuel bank status, stft and ltft, O2 sensor pre and post cat.
    Do a log at hot engine idling and post it here.
    To be honest I'm not sure I can be bothered with the hassle bringing it back up with them. What's done is done, I'm dealing with another specialist now and there was no physical harm done, so just going to move on. Engine was indeed down on power and after having the timing sorted its all back, turns out exhaust rasp is about half as quiet with the VANOS not working.
    I have a Scantool OBDLink MX+ along with the OBDLink app on my iPhone I can use to log, alternatively I could pick up a cheap Android tablet and use OBD Fusion or Torque Pro which I might do. I also have a laptop with INPA, DIS, P.A.Soft BMW Scanner, and TestO, so plenty of things to pull logs from. I can log what you've suggested without any issue but I'm not sure it'll flag anything, mainly because once the car is actually running it runs perfectly. The hesitation it has is purely when cranking the engine, and it can happen both cold or hot.
    Either way I'll post some logs once I have them 👍
  • sapote
    VANOS was done at a well recommended shop that does them frequently which is what makes this a bit fuzzy. They've also taken the car back and checked timing and told me everything is fine, however DIS is saying the inlet cam is out, so I'm not really sure who to trust at this point.
    Adaptation values in DIS for the VANOS come back with a DME commanded 52.5 degrees to reach an actual 59.9 degrees on the inlet, and the test fails with the inlet retard position at 69.4 degrees.
    Just as an update, I had the VANOS re-timed and the intake was a spline out which I guess was enough to put it out of spec. Car pulls so much better now that the VANOS is actually doing something.
  • ATB88
    I have come across your thread a couple of times and it has made me worry that this will never be solvable. From what I can remember the car never did this before I had the VANOS rebuilt, however I didn't have the car long before having it done as it was always the plan to get everything sorted as soon as I could. It is 100% possible that I bought the car with the issue and it just wasn't presenting itself at the time, which would be a little unfortunate. It can go a few days and start straight away first time, and then it will go a few days of consistently being upset about starting.
    There are still a couple of bits I've been advised to change which its booked in for, the fuel pressure regulator and the vacuum line up to the air rail. If that doesn't work then I'll also schedule a clean of the injectors. Being a 2001 car with 120k on the clock there are a lot of rubber parts that are just falling apart, so I totally expect something to need replacing somewhere.
    Out of curiosity did you try another DME?
  • jamesfoley
    My car adopted a hesitant start after I re-timed my VANOS. Runs perfectly, absolutely no errors, but hesitates to start in a way that it never did before I did the VANOS, and once every few months it will fail to start just once (and then start perfectly on next attempt).
    I have replaced *ABSOLUTELY EVERYTHING* that could be related -- every sensor, every ignition part, everything in the fuel system, never fixed it. I wonder if we've got the same ghost?
  • ATB88
  • jamesfoley
    If it was off by a spline then there should be an error code as one spline is more than 10 degrees error.
    Only error it ever threw was an inlet adaptation error, nothing else, and even then it took a while for the error to appear after clearing it.
