Prepping for rod bearing replacement on 01 M3 with replacement engine through BMW
  • Arith2
    Seems like a waste of parts, time and $. With regular oil changes and warm up procedure, these bearings easily see 80-100k with non-track use. On the post above, that is pretty standard wear and nothing was failing even at ~100k miles, which is double the miles you are suggesting. Almost every bearing replacement done now won't need another replacement until the entire engine needs a full rebuild.
    To me, I'd rather replace a good bearing rather than a worn one. When bearings wear, material goes throughout the engine. The oil filter does it's job well however there's oil passageways and other bearings that could be affected. The oil pump also is before the filter. Why wait until there's copper? The goal is prevention, and quite frankly, bearings are cheap compared to the $5000 engine I had to put in because I had bearings fails. Oil analysis is a scam. The only true way to know the health of the bearing is to look at and that's what I intend to do.
  • bigjae46
    Originally posted by Amos View Post
    Just to be clear, that was 150k kilometers, not miles. I do agree with you, 100k miles seems like a good interval
    5 years ago, I’d be OK with that with S54 prices being relatively low.
    Now, prices are just going up. I probably wouldn’t take the chance and do them before 60k. The oil pan gasket likely won’t survive that long anyway.
  • sapote
    Here are the pictures of the road bearings they took out, glad I decided to get these done.
    These bearings still have 60 to 70% life, with 0% as showing copper.
  • Slideways
    Ah, didn't see KM. The few that I have seen at that 100k mark look like that with the uppers just getting into the copper. Really depends on how the previous owner(s) used the car, but under current ownership, the bearings might fair better.
  • Amos
    Seems like a waste of parts, time and $. With regular oil changes and warm up procedure, these bearings easily see 80-100k with non-track use. On the post above, that is pretty standard wear and nothing was failing even at 150k miles, which is triple the miles you are suggesting. Almost every bearing replacement done now won't need another replacement until the entire engine needs a full rebuild.
  • Amos
    Originally posted by tlow98 View Post
    Ha, that’s crazy. Hard to tell from the pics, but do I see copper?
    Not sure, it is a bit hard to tell. Can definitely see lead wearing. All I know is that both lead and copper have been trending up slowly over the past 5 years, I'll post the analysis in the big rod bearing thread once I get the latest results back.
  • SQ13
    My 01 with about 50k on the rod bearings and lots of track days. I try to stay under 3k rpm until the temp needle reaches the first dot, then under 4k rpm until fully warmed up (needle at ~11 o’clock). Guess what I’ve been doing is working just fine.
  • Slideways
    This is why I'm sticking to a 50k mile rod bearing service interval. Or every oil pan gasket leak. Whichever is first.
  • Arith2
  • tlow98
  • Amos
    So the shop said I had the old style bolts. Not sure how that makes sense, I have the service record from BMW showing an engine replacement in 2004 but who knows?
    Engine was replaced at 70,000 KM due to rod bearing recall
    Car currently has 220,000 KM (so 150k on the engine/rod bearings)
  • Tbonem3
    You'll have M10
  • Amos
    So I'm in the exact same situation, my 2001 engine was replaced back in 2004 so I'm not sure which bolts I have.
    I'm taking my car in for rod bearing replacement tomorrow, I'm curious what they will find
  • tlow98
    M10 motor.
    not really a big deal tho. Order the M10 and bearings ahead of time and if for some odd reason it’s M11 the bearings will still work and you’ll just reuse your old bolts.
  • bmwfnatic
    Switch from M11 to M10 was one particular day in December 2002, so you would have M10 for certain.
