Originally posted by tlow98
With any adjustable damper, people often equate higher rebound settings to better handling. They crank up the rebound not realizing they have now put the damper's reaction against the spring's tension outside the performance envelope of the spring. Once compressed, the spring wants to return to a neutral state at a certain rate of speed, but the high rebound setting on the damper prevents that from happening, hence a stiff ride.
DA dampers make this situation even worse as now you can adjust both rebound and compression, which, if adjusted incorrectly, can really make the ride quality suffer.
Remember, a damper is intended to control the motion of the spring, not necessarily to make the car lean less in the corners, that's what sway bars and stiffer springs are for.
In most cases a rough ride is usually caused by mis-matched springs and dampers.
1) Spring rates too high or too low relative to damper valving.
2) Damper stroke too long for spring length (i.e. lowering spring) resulting in the damper bottoming out internally.
