THE M3 IS GETTING THE ANRI BUILD TREATMENT - Blown headgasket to build thread
No real update to report - took it out in the canyons a couple weekends ago, coolant temp was at 72 degrees the whole time, car f*cking rips. Went to Staples the other day, came out and just love my car, so I took this picture. There's something going on with one of the brake sensors I think under the ABS module, got code 5E265 Control Unit: voltage supply, sensors - and my DSC and BRAKE light are on, but then they go off sometimes. It'll get figured out but for now, I'm just loving my M3 and thought to share. Sometimes I think about what new car would I get besides this? And the answer is, I wouldn't. There simply is no replacement for this amazing vehicle, I love this platform so much. Happy Monday guys!
- Likes 7
Could sometimes be possibly running in certain specific situations if the correct parameters were met at some point in time.
OP said "and 78 C degrees while driving. "
[QUOTE=George Hill;n275033]
My concern is that spreading false information as fact (whether on purpose or not) does a disservice to the community and some members may not realize and then regurgitate it as fact.
[/QUOTE]
Sorry, had to bold your thought.Last edited by Anri; 08-12-2024, 05:26 PM.
I see what you did there, lol.
*Edit, this is my last post on the thread though. I'm super glad that this has turned out favorable for the OP, that is not always the case anymore.
*Edit, this is my last post on the thread though. I'm super glad that this has turned out favorable for the OP, that is not always the case anymore.Last edited by George Hill; 08-10-2024, 12:14 PM.
- Likes 3
Alright y'all, that was fun - I'm gunna do what the Olympics announcer guy did at the beach volleyball court when things got heated to clear the air
Yes, you are wrong to say that. You do not know which fan was running. You literally said he's wrong and you are right even though you aren't there while he is. Just because the A/C is on doesn't mean the e-fan is on. /thread.
Hahahaha
Also we are not sure what OP said about hearing the clutch fan running with AC turned on -- was he idling, in traffic jam, or driving at high speed. I don't think the clutch fan is audible at 850rpm idling even if it is total locked up. But I'm sure we all care hear the efan running at high speed with AC on in the hot summer.Last edited by sapote; 08-09-2024, 12:13 PM.
Originally posted by sapote View PostHe wrote: "- with the Sachs fan clutch you can hear with the windows closed with A/C on"
No one saw the clutch fan spinning fast while seating inside with window closed. And with the AC on, I'm sure the efan was running fast and so how one be able to say the it is the noise from the clutch fan.
Here is what I wrote in response to OP: "What you heard is the efan running and not the clutch fan. "
Am I wrong to say the efan was running with that noise and not the clutch fan?
Originally posted by George Hill View PostAnd without data to back an opinion up its silly to say someone is wrong in what they actually witnessed, lol.
The IHKA will command the e-fan on based on a number of factors, one of those is system pressure, the other is it will always come on when set to max cooling (temp and fan speed).
The other way is the e-fan is commanded on by the DME when the radiator outlet temp is too high. I don't know what that temp is but I assume its between 90-95*c. Essentially the DME is expecting the radiator to do its job with just air flow or when the clutch fan is locked up. IF those can't keep up the outlet temp will increase and then the DME kicks the e-fan on to supplement.
Originally posted by digger View PostDoesn't the fan just come on based on the temp switch assuming the A/C is not running? it doesn't matter the increased flow (which is lower temp) but the actual temp of the fluid. What is the temp rating of the switch?
Anri's Tstat and associated fan clutch should keep the engine at a lower temp. So if the radiator drops (as an example) 15* from the inlet to outlet then Anri's setup should have even more room before the e-fan would turn on because it started at a lower temp as well *in theory. BUT all of this is conjecture as we don't have any data. And without data to back an opinion up its silly to say someone is wrong in what they actually witnessed, lol.
