THE M3 IS GETTING THE ANRI BUILD TREATMENT - Blown headgasket to build thread
  • ChapterM3
    Only the person that had removed the rocker rods (to replace the rockers)
    That's the thing - in my ownership I've never had anyone touch the rockers - so what's worse, a shop forgetting to replace them? or shops not catching they were missing in the past 5 years of my ownership? πŸ€¦β€β™‚οΈ
  • bigjae46
    A very simple mantra to follow is "if it ain't broke don't fix it". With time all those bullshit ass "upgrades" come to light as being shit ass upgrades. Take the radiator for example, with people wasting their money on csf garbage only to discover their car overheats and paying for the privilege of it doing so. No wrong has ever been done by sticking with oe parts. Conversely look how much it costs people who cheap out on parts to save a buck and it causes long term damage to their engines unknowingly, or, eventually knowingly after the fact the damage has been discovered. Even cubieman had an issue with a beisan oil pimp disc which was a 30+ page thread in and of itself.
    I’ve had to learn this lesson a couple of timesβ€¦πŸ€£
    And it’s possible the radiator was one of those lessons. And the worst part is it even costs more than the OE part.
  • bigjae46
    I don't disagree with the above, my point was that the issues of the plastic impellers, that was resolved 20yrs ago, still pushes people to be scared of plastic impellers to this day.
    And a BMW pump has a limited lifetime warranty through BMW. Covers the cost of the part for the life it it fails.
  • EthanolTurbo
    Yeah and the stupid CSF radiator adds 5 lbs of front weight on a car where you want every lb of weight off the front.
  • sapote
    Back in 2000 I had a shop (in Reseda, CA) rebuilt my 1974 E9 3.0CSi engine and some work on the 4 sp tranny for a total $5000. I selected him because I saw him working on E9, Ferrari, Maserati. Anyway I reminded him that the oil spray pipe above the cam was not symetrical and so make sure don't install it wrong way to cause the oil spray not at the cam lobes. He said "I know what I'm doing."
    When I got my car back, I removed the valve cover to make sure, and the pipe was installed the wrong way. That was the last time I paid someone to work on my cars. It's hard to find a good mechanic.
  • sapote
    Originally posted by ChapterM3 View Post
    For these set screws I really couldn't say at this point - The valve cover has been opened by a couple of shops, so no telling what happened here. All I know is no one caught this until Anri just flagged it - so unless these magically disappeared, I've had it like this since the last 25k+ miles
  • ChapterM3
    Wow, without the set screws to lock the rod in place, if they just slide off a little then the cams bearings would be starved with no oil as the EX rod oil holes have to lined up to the cam saddles to feed the oil to both cams. Who had worked on this engine before with two extra set screws in his pocket?
    I can't disagree with you! Well said.​
  • Anri
    Hi Sapote,
    I will share worst I have seen very similar scenario.
    I received 91' E34M5 for some work. From the service history
    I sow the M5 had engine rebuild at Andre in Burbank I met the
    guy few times 15 years ago in his shop.
    Took the valve cover off re-lashed the valves and checked the
    cam timing and what do I see he dialed the cams so fucking
    wrong to be exact 120/120, poor engine was so slow it was not
    even funny it will pick up at 6500rpm and up...
    I took the intake and exhaust cam gear off to move the cams
    back to 110/110 stock, (I have much better timing for mid range
    but customer wanted all stock) anyway, when I sow the cam snout
    the oil plug caps were missing !!!
    If you dont know the S38 camshaft are hallow and the oil
    is pushed inside to lubricate the bearings/cams and will splash oil
    to the shims and lobes.
    During gun-drilling machining process at the end a small cap is installed
    each end of the camshaft to hold the oil otherwise the camshaft oil will
    bleed in the chain guide area.
    The camshaft lobes and shims and caps had 0 damage. From the
    papers I can see when the engine was rebuild driven 3-4 years like
    20-30k miles or so. It the same exact scenario here.
    The single reason these caps were removed is to clean the camshaft but
    Machine shops are careless (not all but most) and they forgot to put
    New one back in.
    Moving forward.
    Regards
    Anri
  • jet_dogg
    Anri - This is getting out of hand - another thing that's wrong with my engine!? I mean I replaced that pump thinking I was doing the right thing with a metal impeller 15k ago, and this is, in addition to the fan clutch is what caused the HG to go?! F&@#. I'm beyond upset to read this, I have spent thousands trying to stay ahead of maintenance and not have the car break on me and all that it seems that I've paid for are parts that need to be replaced very soon after being installed. I mean I've researched these things, asked opinions of people, shops, and the shop that installed these as making the decision that I was doing OEM+ replacements: ARP bolts for the rod bearings, "better" aftermarket water pump with a metal impeller, etc. but this was clearly wrong. Damn it man I've been trying to do the right thing but clearly there needs to be some updates to the opinions out there. I'll document this on the first page to help people hopefully catch these things to not make the same mistakes I did. πŸ˜“πŸ€¬
  • sapote
    πŸ€¦β€β™‚οΈ Add it to the list. Thank god this thing is going to be Anri-approved after this build πŸ™Œ
  • ChapterM3
    Happy Friday.
    I was in a process of taking the rocker shafts and
    found both M10x1 allan screws missing..
    Someone previously had the shaft removed and
    forgot to put the locking screws back in, scary..
  • Anri
    Head is now clean and ready for assemble.
    Moving forward.
    Vapor honing process is good but its knife with 2 edges..
    Regards,
    Anri
  • Anri
    Happy Friday.
  • ChapterM3
    I wouldn't beat yourself up, it happens all the time, everyone's got something to learn (myself included). Best thing you can do is and move forward, ask lots of questions and don't be afraid to trust, but also verify.
    And when in doubt use factory original parts.
    It's really hard not to considering how I've been thinking I've been doing the right things for maintenance this whole time only to find out that most major components need to be re-done. Learnings, all good learnings. Thanks for your post though, I appreciate it
  • George Hill
    I get that. I wondering to myself how could I have better done that so this wouldn't have happened?
    There are many shops that know what they are doing, but there are MANY MANY more that don't and are just slapping parts on and talk a good game. I wouldn't beat yourself up, it happens all the time, everyone's got something to learn (myself included). Best thing you can do is and move forward, ask lots of questions and don't be afraid to trust, but also verify.
