Porsche Brembo 996 BBK Conversion-- let's figure out how to fix the dust boots/seals
Nobody has heard of Frenkit? If their claim is true 300 C seems pretty stout - how hot do the pistons get?
I started going back through this topic from the beginning. For context I followed Ian's link to Ohio Performance Solutions, and it looks like something has changed in the last year. Anyone ever heard of this manufacturer? https://www.ohioperformancesolutions...-rebuild-partsLast edited by D-O; 08-07-2024, 06:21 PM.
Originally posted by Obioban View PostUpdate: High temp silicon seals held up!
(https://racingbrake.com/bp-404bs/)
Car was doing double duty, running in instructor and advanced group, back to back, all day. He was not running backing plates.
Disclaimers; 50-60 deg ambient and summit point raceway (not that hard on pads), so not WORST case scenario-- but I'm stoked. Will be installing this winter.
Originally posted by George Hill View PostDo the Porsche guys have this problem? If so, what do they do?
Originally posted by D-O View PostIs the current consensus that there is no boot that will stand up to the heat and I may as well remove them when installing track pads?
Also - how about a recommendation for track pads. First track day in the M3, but I know the Akebono ceramics are not going to cut it.
Pads, that's a can of worms. PFC08 were loved by a lot of folks. If using FCP, Pagid29 Yellow or DTC60 (some people are allergic to these because they theoretically destroy wheels if they get wet, although not my experience, even running in heavy rain).
Originally posted by BigRussia View PostUpdate: new Racing Brake high temp blue dust boots still didnt hold up even with ti heatshields and vorshlag brake cooling deflectors (though the deflectors were installed after the boots had gone through two track sessions and without yet cutting away the rotor dust shields). IMO these dust boots are useless and not worth the premium, i think their flaw at least for the Rebault Megane calipers is that they dont sit flush enough, theyre cracking due to being too thick/raised and touching the pad backing plates/ti heatshields. I have them pressed in as far as possible, even pushing them in with a punch but thats the lowest they seat (see pics).
I ordered a single caliper set of basic Girodisc dustboots, going to install them and see if they sit better. Theyre not high temp rated but theyre cheaper and want to see if them sitting flush like oem brembos boots will make them last longer. The rear 996 calipers' 20yr old factory dustboots are still holding up without any wear, but granted the rears dont see anywhere near the same heat or abuse
In your setup the Vorshlag deflectors are not doing much. With trimmed shields you will get much better benefit (i saw better results going from hoses to Vorshlag scoops but i trimmed my shield to allow more of that air to hit the rotor vs hitting the dust shield). They are not channeling much air into a single small opening in the shield in front of the hub most of the time (as the wheel turns, etc). They are a bit of a shotgun approach vs a rifle, so they need more open area to hit. If you want to keep the dustshields you will benefit much more from something that concentrates air flow into that hub opening, either hoses or Bryson's design (connect with him).
Vorshlag shovels need to be modified slightly to run with non drilled rotors, so I bent the last part of them (bottom that is closest to rotor) so it doesn't hit the inner disc surface as much. With drilled/csl it was ok as holes let some of the air through (and prob do better than veins/hat), but for solid/slotted like Girodisc you need to really channel into the hat and let the veins do the work.
For your dustboot problems, I think I read a while back in a different thread that you ran 2 pad thicknesses and thicker one is really problematic, is the thinner one also compressing the pistons all the way when new? To be fair, none of the boots sit perfectly flush in the bores.
Just a thought. Rust (inside the vanes) is a pretty good thermal insulator. Maybe we could experiment with passivating rotor internal surfaces with citric acid? It’s pretty easy to DIY passivate.
I ordered a single caliper set of basic Girodisc dustboots, going to install them and see if they sit better. Theyre not high temp rated but theyre cheaper and want to see if them sitting flush like oem brembos boots will make them last longer. The rear 996 calipers’ 20yr old factory dustboots are still holding up without any wear, but granted the rears dont see anywhere near the same heat or abuse
Originally posted by Nate047 View PostInteresting, I don’t have INPA and I don’t really know anything about that subject. If there is a good thread with info vs me asking a bunch of dumb questions, I’d be grateful to read and get up to speed!
