Interior refresh questions
  • Daniel
    If you want to change the color of your carpet, just do it right and actually swap in the replacement color carpet. I can't imagine the dye looking or feeling very good. It's not hard to swap, just time consuming. I spent ~half a day doing mine & I was taking my time.
  • heinzboehmer
    You convinced me!
    Will try the zip tie method. Carpet is coming out.
    That dude in the video you linked is hilarious. I thought I was the only one that wacked the crap out of my head all the time, ha! I ended up watching most of that vid. Pretty good stuff. Not sure why I find watching someone else wire up there seats for power so interesting... but I apparently do!
    Oh man you're missing out. That whole channel is great. What's not to like about watching others bring old cars back to life?
  • Casa de Mesa
    I cut my carpet and no one would ever know, and I mean it is absolutely impossible for anyone to have any idea it has been cut. There are wires under the carpet so be very very careful.
    Casa de Mesa If you want some added rigidity, you can always "recombine" the carpet with the piece under the dash using some zip ties. Or even sew them back together.
    Zip tie method: https://youtu.be/w-rn0GcyhMs?t=2356
    You convinced me!
  • heinzboehmer
  • oceansize
  • Casa de Mesa
    That is the only short cut, you basically cut it out around the hvac unit and then tuck it up. If you want to have a complete uncut carpet like I did, you need to remove the hvac/steering column/dash support bar. It's not hard, just a pita. I ended up having to pull the intake manifold to get to the two water lines which go into the hvac box, and of course, to pull out the hvac you need to drain the A/C of coolant. Hard, naw, time consuming, very.
    You can see a little bit of dove carpet under the hvac in this picture:
    And another angle here:
    Once you finally remove the hvac unit, here is the piece of carpet that is under it
    Dredging up an old thread. I have a couple questions related to pulling the HVAC and carpet.
    I'm repainting my car, trying to get as much out of the way for the paint shop as possible. The car currently looks like the photos in THIS POST except the rear carpet is gone, as are side head airbags, and few other things.
    I'm trying to weigh, A. pulling the front section of the carpet in order to provide as much uninhibited access for the body shop as possible and reduce risk of them damaging the carpet unintentionally (overspray) against B. the complexity of the job and risk of introducing a rattle, breaking something or whatever. So my questions are:
    1. If the carpet is cut as show in liam821 's photos above, does that affect the carpet's ability to stay in place once you reinstall the carpet? It seems like cutting the carpet under the HVAC stack in the center of the dash (above the tranny) is a MUCH EASIER way to get the carpet out, but I'm worried that I'll run into sagging carpet down the road. I know the carpet has a bit of structure to it but... ?
    2. If it turns out cutting the carpet is a bad idea, what really has to be removed to pull the carpet? The HVAC and center dash support bars (the near-vertical bars framing the HVAC) I see have to come out for sure, but does the steering column have to come out as well?
    Here is a better shot of the car at the moment. Rear carpet out:
    Engine bay wiring pulled back into the passenger compartment. You can see the carpet can be pulled away from the rocker panel here (for paint), but it's soooo close to having all of the carpet gone. Still, I'm not sure it's worth the extra effort or not.:
  • liam821
    I worked pretty hard to stay organized throughout the process, was bagging and tagging all bolts etc, but in the end, after everything was back together and working, I discovered two longish bolts that were removed at some point of the tear down and didn't get back in during reassembly. I have no idea where they belong. Everything felt and sounded good, and everything felt solidly secured, no rattles, so, I made peace with it -- maybe I'll figure it out if I ever go back in there but I sure hope not.
    You did better than I did. I literally just dumped all the screws into a giant bucket... yolo. Everything seemed to work out okay in the end. haha
  • ATB88
    I double and triple checked everything as I put it all back together. Because if you forget something, you're gonna have to do the whole thing over again to get to that missing plug or whatever. I was so thankful when the hvac unit and all the controls worked normally.
  • liam821
    Damn. I replaced the dash on my E39 and thought that was in the territory of “this thing is never going back together” but this is a new level
    Yeah this is giving me flashes of the time I pulled the dash to replace the AC evaporator. What a nightmare, never again.
  • ATB88
  • repoman89
  • Bigo1087
    Replace the carpet... Its very little extra work...once you get the dash out. Just have to make a few cuts right under the dash and matchup the new carpet to it.
    You'll prob spend more time.. dying the carpet over swapping it.
  • Bostonbruck
    Found carpet for sale.
  • Apex_80
    Quarantine also has me thinking of this, I think I will dye the dash but carpet seems best just to replace
  • liam821
    Originally posted by Inizes View Post
    liam821 might have a solution? I’m not sure the extent of his swap. In my opinion, I don’t think there are any shortcuts with carpet. You could try dying it and see what happens and if you’re happy? If you don’t like it put in the work and rip it out.
    Originally posted by s54wagon View Post
    If you cut around the hvac/heater core area high enough behind the trim it's only a matter of removing the center console, door sill trim, and the seats
