Best Transmission Fluid
Well crooked commie, I tend to disagree with your opinion ,FWIW , which we all have one ,so far my tranny has gone over 50,000 miles with the redline d4atf....
for street. Works great...
Putting Redline D4ATF in your transmission is great for shifting, since you'll be getting a new one shortly after.
- Likes 3
75w90 is too heavy for a street car except maybe one that lives in the desert or gets run hard. I would go to a straight 75w (mtf3) or OEM (bmw or pentosin) 75w80 mtf 2.
Originally posted by Tbonem3 View PostFirst link is a conventional (non synthetic) gl5 lube (rear end). We want full synth gl4 tranny lube
Second link is DCT fluid that pentosin says is backwards compatible with the gl4 spec. I don't quite trust them.
I used royal purple because it was at the shop and it's really notchy. I guess I should go to OE and see if it helps.
Did Pentosin start making it again? For a while everyone was out of stock of even the BMW branded stuff.
Originally posted by bigjae46 View PostI use redline MT90 but I don't drive it on the street. Works good when the trans is warm. I've used D4ATF in the past. It feels good for a couple of weeks and then its really difficult to rev-match downshift.
The best bet is OE fluid. Which is now DCTF? Anyone tried that?
Followup: Last night I changed out the Redline D4 ATF which had about 2000 miles on it for some Pentosin MTF-2. When I first bought the car, all 1-2 shifts and most 2-3 shifts were impossible without double clutching for the first few minutes of driving in colder weather. Changing to Redline D4 ATF helped significantly to where shifting was always possible but I had to be delicate for a few minutes until things warmed up to avoid crunchy no good sounds and feels.
This morning is a cold morning (35 F) and the cold performance is better than D4 ATF. Im sure the performance and smoothness will drop off after a couple hundred miles like it always seems to but the Pentosin has things running much better. The shift quality is almost decent.
I give the Pentosin MTF-2 a big thumbs up
