Originally posted by bigjae46
S6-37 6mt swap info (broken off from junk yard thread)
Wait til you see that sock tan line! lol. Only so much time before the scale times out and turns off, ha.
- Likes 3
We know the internet puts M3 differentials in non-M 6spd cars so this should work for Bryson's setup as well. But I don't always believe everything on the internet, except they are correct in this instance. The GS6-37 is 2.5mm longer than the 420G and they both use a 96mm guibo, note IIRC the M3 guibo is "thicker" than the non-M the M3 should be used either way.
One of the things I was hoping for in the idea of the 420g to ZF swap would be some weight savings but the weight savings is literally 0lbs, lol.
GS6-37
420G
- Likes 3
I'll let George Hill have the official honors but he measured the bell housing to flange difference of both gearboxes today and found the ZF to be 2.5mm longer than the Getrag. Wanted to make sure this number didn't get lost!
What kit is this, can you share the pn#?Originally posted by xUltra View Postwith 330 Valeo Single Mass Flywheel Clutch kit and it's been great. .
The ZF in the 330 was the most enjoyable manual transmission experience I have ever had! I'd describe it as crisp and precise yet smooth. It won't let you miss a gear. The 420g and E9X M3 had a rubbery and vague trait. The F and G chassis have the same shitty feeling which is why I don't understand the desire to keep a manual. The experience is bad and I don't see any effort to make it better. BMW just does it to shut the old people up.Originally posted by xUltra View PostPermission to revive an old thread..
I've had the 330 ZF GS6-37 in the M3 for several years now with 330 Valeo Single Mass Flywheel Clutch kit and it's been great. Love the notchy-ness. Drives and shifts amazingly well.
I've had the 330 ZF GS6-37 in the M3 for several years now with 330 Valeo Single Mass Flywheel Clutch kit and it's been great. Love the notchy-ness. Drives and shifts amazingly well.Originally posted by e46IX View Post
In my case it was just a question of what we had lying around, he bought the Z4MR as a lightly hit car that was being parted out, it was sold to us as a rolling shell with no powertrain and we put the car together on a budget with spare parts we had kicking around. I'll get him to report on how the car holds up to aggressive driving, give him a week or 2.
Yes, the Z4M ZF GS6-37 does have a slightly longer input shaft than the 330i variant, the rest of the transmission is 100% identical (minus the shifter but that doesn't matter they can be swapped out for each other).
I will be using the Z4M version of the GS6-37 for my personal E46 M3. It will be mated to the original S54 flywheel and a Z4M clutch kit. I got Ronald to sell me one of his 330i 6MT SSK.
The only part I need to figure out next is the transmission cross brace, as I heard the cross brace for the ZF gearboxes interferes with the stock M3 mid-pipe. I'll see for myself once I'm putting everything together and decide what the best course of action is. Seems like most guys get an exhaust shop to modify the mid-pipe but personally i'd rather cut and well the transmission cross brace itself otherwise it will always be a headache to change exhaust components on the M3.
The only issue I've had is the cross brace touching the midpipes.
I have had the cross member shaved off enough without structurally compromising it's strength and was able to clear it. Now the car runs an aftermarket exhaust and has slightly less clearance than the stock exhaust unfortunately. The midpipes expand with heat and slightly hit the cross member causing a slight vibration / metallic noise which is mostly audible during higher revs.
An idea I had recently was to use a bit of exhaust wrap in that section to reduce or possibly eliminate the vibration and noise.
Curious, what kind of solution did you come up with for your swap?
Regarding all the comments and questions around the potential grinding that can occur during aggressive 1st to 2nd shifts:
I did notice some grinding when aggressively shifting from 1-2 in the early days of the swap. It's been a long time since i've had that happen ever since I slightly adjusted the ZHP shift knob and angled it toward the driver seat. Once I seated knob toward the driver seat and made sure to always shift 1-2 against the wall, it's never been a problem. This is with a UUC 330 SSK, which i'm honestly not a huge fan of. I run Motul Competition gear oil in the transmission. Just make sure to take it easy when its cold from 1-2. Autosolutions will probably be my next upgrade since the UUC SSK is very mediocre at best.
I have zero problems with my new (older!) one. I actually can't reproduce it. My 2008 car would do it even on reasonably fast shifts. My shifting technique hasn't changed so I was shocked to find that some of these ZF boxes don't do it.Originally posted by Slideways View Post
The E9X M3 ZF box does the same thing on a really aggressive 1-2 shift. They just are not designed for this hard 1-2 shift you see in drags races and in F&F movies. Even automotive journalists grind second gear when try to get the fastest 0-60 times out of the test cars.
I have noticed that backhanding 2nd gear makes it a much smoother change if you want to give that a try.
The E9X M3 ZF box does the same thing on a really aggressive 1-2 shift. They just are not designed for this hard 1-2 shift you see in drags races and in F&F movies. Even automotive journalists grind second gear when try to get the fastest 0-60 times out of the test cars.Originally posted by chris719 View Post
I’ve had two Z4M, one brand new (2008) and one used (2006) and somehow my 2006 with 90k miles does not grind at all at high RPM. It’s a little crunchy at low revs on shifts because I’m not sure the fluid was ever changed before me but it somehow shifts far better at high RPM than my brand new 2008 car I had for 25k miles. My 2008 car would grind randomly on fast shifts into second with a strange buzz / zipper / drill noise and not actually end up in gear. I have never had that happen on the 2006 yet. If that buzzy grind is what you’re talking about, I wonder if some of these gearboxes are sort of defective. Had I known you could have one without that grind I’d have made BMW replace that trans under warranty.
I’ve had two Z4M, one brand new (2008) and one used (2006) and somehow my 2006 with 90k miles does not grind at all at high RPM. It’s a little crunchy at low revs on shifts because I’m not sure the fluid was ever changed before me but it somehow shifts far better at high RPM than my brand new 2008 car I had for 25k miles. My 2008 car would grind randomly on fast shifts into second with a strange buzz / zipper / drill noise and not actually end up in gear. I have never had that happen on the 2006 yet. If that buzzy grind is what you’re talking about, I wonder if some of these gearboxes are sort of defective. Had I known you could have one without that grind I’d have made BMW replace that trans under warranty.Originally posted by e46IX View PostAs for the redline shift grind, yes its a real thing even on my own personal low-mileage (50,000 km's) M Coupe. I normally hesitate for a second going from 1st to 2nd on a redline WOT pull otherwise it will grind, can't just slam it into gear. Although to be honest I recently changed the trans mounts out for the Rogue Engineering solid rubber ones and I think there is some improvement there, I may try going to slightly stiffer engine mounts and see if limiting the movement in the drivetrain will help solve that grind.
Little OT, but anyone know why the 330i/Z4, 330xi, and M3/Z4M use different clutch hardlines between the softline and the slave? That's 21526774230, 21526753015, and 21522229675 respectively.
If the M3 (420G) and Z4M (GS6-37) both use the same-P/N shortest-path hardline, and the hardline-to-transmission support bracket follows the trans (21526774227 and 21522229699,) and all cars use the same slave (21526785966,) then I think the hardline endpoints have to be in the same location in all configurations, so why do the non-S54 cars use different hardlines?
The softline is different for Z4s, but that makes sense since the length of the run differs with the chassis. Even the clutch pedals are the same across all E46s (35311163870). Is BMW controlling pedal feel and damping vibrations in the hardline? How could that work if it's well-bled - fluid volume? Bend radii producing resistance?
Thanks guys.Last edited by ethan; 09-05-2025, 06:59 PM.
for which driveshaft to use, that is dictated by which rear differential you are using.
if you are running S54 and ZF 6speed transmission from e46 zhps and have the M3 3.62 diff in place then you use the M3 drive shaft.
if you are running S54 and ZF 6 speed transmission from e46 zhps and have the non M 3.07 differential, then you use the ZHP matching drive shaft that came with the transmission.
the difference is the input shaft on the diff, the M3 one is around 1.5 inches longer than the NON M one. if you put the M3 driveshaft next to the ZHP one, the M3 one is shorter to accommodate the longer m3 diff input flange
one one of my old previously sold S54 tourings had a S54 swap with the e46 ZF 6 speed transmission
in this picture i have 3 driveshafts.
left is e46 ZHP Auto trans
middle is e46 ZHP 6MT
right is e46 M3 6MT driveshaft
you can see the M3 DS is shorter than the ZHP 6MT one to make up for the longer input shaft flange on the 3.62 diff.
my final setup was:
S54
e46 ZF 6mt trans
e46 ZF 6mt clutch, Pressure Plate, Flywheel (for flywheel mounted pilot bearing)
e46 ZHP trans bracket
e46 M3 driveshaft
e46 M3 rear subframe with 3.62 differential
had no issues no vibrations or anything of the sort didn't have to make anything fit it all just bolted up and worked.
did have to do some coding in the M3 DME to remove the Gear position sensor and gear position sensor DTC codes similar to SMG to 6MT conversions. and on real m3s you will have to direct wire clutch switch to x60002 or take your GPS connector on the trans harness and short the wires together to complete the signal.1 PhotoLast edited by nextelbuddy; 07-22-2025, 10:36 AM.
- Likes 5
Yeah it's a fair question. I think it just comes down to *technically* the dual mass flywheel should be relatively matched to the engine's characteristics. And I guess it was cheaper for them to make a few transmissions with a longer input shaft than making and perpetually stocking a Z4M-specific flywheel.Originally posted by Slideways View Post
Gotcha, so the Z4M has the longer input shaft as it has to reach the end of the crankshaft and the 330i is shorter since the bearing is on the flywheel. Now I'm curious why BMW wanted to use a specific flywheel for the M3 and Z4M rather than use the clutch assembly and transmission from the 330i in the Z4M.
In my mind it should be feasible to build some sort of spacer that sits in the crankshaft and spaces out the pilot bearing to where it should be for the shorter inputshaft while using the S54 flywheel. But the machining would need to be spot on.
- Likes 3
Thanks for sharing, much appreciated!
There's another forum member on here who was looking to replace his 330i GS6 with a 420G and he was using a customer made cross brace - he recently posted in the classifieds looking to swap his GS6 with a 420G so it should be easy to find him if you want to see what his custom cross brace looks like, I'm sure he'll be happy to share.
