Referral Request: Gauge Cluster Repair Service
  • AWE46M3
    Originally posted by DI46LO View Post
    FYI/Update - Looks like Circuit Board Medics are no longer offering services for us. I gave them a call when I noticed they pulled the listing from their site. The rep stated they decided against it because "too many were corroded and the motors are hard to source". I'll try the automotive circuit solutions.
    Damn - that's unfortunate. I've lagged out on fixing my gauge and should probably do this sooner rather than letter. Please let me know who you end up going with.
  • DI46LO
  • AWE46M3
    Originally posted by Grke46m3 View Post
    What cluster issues is everyone experiencing? I noticed my coolant temp gauge hardly sits in the middle anymore. Hovers between first dot and center I changed both sensors twice and my thermostat once. Maybe it's a cluster issue?
    It most definitely is. The stepper motor sticks and the needle doesn’t get to perform its proper sweep. It is also known to not return to zero, making you think your car is overheating when it performs it’s sweep to reach what it thinks is the center line which is in fact the middle dot between center and red 🤣
    I’m having the issue you’re having now where my needle is getting stuck half way to middle
    You can put the car in test mode and verify the actual temps if you’re concerned.
  • Grke46m3
  • mikeetastic
    ^^ yep they are very easy, i suggest get a cheap non m3 cluster and practice or even those cellphone shops can solder it really quick.
  • Riley
    I have replaced cluster stepper motors before on other e46 clusters, it is very easy to do. I bought new motors off of ebay. As long as you are able to solder this is an easy diy.
  • maw1124
    Wish I had a business endeavor where I could treat [potential] customers this way 🤣
    Not really… but I hear you… the rest of us would be homeless and he may be soon.
    I used to have an upholstery guy like that. He did amazing work at super cheap prices but you’d damn near need to come burning incense with a fatted calf to get him to do work. I wonder if he’s still in business. IDK because I just use someone else.
    maw
  • AWE46M3
    Originally posted by bran.stum View Post
    There's a guy that does this in SoCal. He wasn't pleasant to work with and there was a bunch of dust on the inside of my cluster when I got it back. He was the cheapest I could find at the time ($200~ total), so may or may not be worth it for you if you can deal with the personality and know how to disassemble the cluster slightly to clean.
    hahaha Scott from GM5. I spoke to him yesterday - I figured he had so much business he could give a shit if I sent him my cluster or not. Wish I had a business endeavor where I could treat protective customers this way 🤣
  • AWE46M3
    Hit up this guy, he's cheap and competent. He does everything.
    Fixels, Charlotte, North Carolina. 12,916 likes · 1 talking about this. Fixels is a company that focuses on repairing automotive electronic modules, mostly from BMW currently. The biggest repair is...
    Palo Alto Speedometer did my cluster, but they don't normally work on BMW clusters.
    This guy in San Diego has been doing clusters for 20+ years.
    http://www.foreignspeedoinc.com/
    Thanks for both of those recommendations. Glad one is relatively close to mitigate damage to and from the vendor. Appreciate your input.
    Originally posted by nahvkolaj View Post
    Automotive Circuit Solutions was $200 + shipping 1-way (from me to them).
    Another one for Automotive Circuit Solutions - thank you. What did you have them fix for you?
  • bran.stum
    Originally posted by ejendow View Post
    You talking about this guy? https://www.bmwgm5.com/default_right.htm
    was very unpleasant to work with when I had him fix mine haha
    That's the one lol. He copped an attitude right after I sent my cluster out, so I just had to deal with it.
  • nahvkolaj
    Found the receipt for the service I mentioned above. Automotive Circuit Solutions was $200 + shipping 1-way (from me to them).
    Edit: clarity
  • ejendow
  • bran.stum
  • 9kracing
    Speedometer and Tachometer Repair
  • AWE46M3
    Another option is just swapping clusters. It's super easy to pull the EEPROM chip which holds the mileage/vin/programming off and hot-air solder the chip to another cluster. My daughter's e46 cluster stopped working and I was able to swap the chip to another cluster and popped it back into the car and everything worked perfectly as expected. No coding is needed.
    Thanks for mentioning that, Liam! I looked into a spare cluster and believe the price to get it repaired could be comparable with no guarantees the used cluster could hold up for another 20+ years. Hoping to refresh the cluster so line new internals to reset the clock on those needles doing their thing.
    Originally posted by BMWE46M3 View Post
    I used Circuit Board Medics and would recommend them.
    Got my initial recommendation from a thread you commented in. You sent you cluster off to them for your coolant needle, right? I did the cluster reset but the needle keeps migrating to the right after a few drive cycles. Time to fix it for good!
