Originally posted by Gt4
Questions About Recaro Sportster CS Seats
EAS sells a bracket for the oe receptacle that works with your setup under their house brand Macht Schnell. I have an extra set laying around, pm if you want itOriginally posted by Gt4 View PostWhat bracket do you guys used to bolts the OEM belt buckle with sensor when using VAC Motorsport floor mounts and Recaro sliders with Sportster CS?
Just wanted to follow up and see if your were able to get the heated seat function to work with the OEM controls. I'm considering the AMX seats and wanted to make sure there wouldn't be any issues with that heated seat setup.Originally posted by Checkabs View PostSo it looks like AMX is saying that the heating pads have resistors in them for the e46 M3.
ahh that explains it. i ended up popping in every time my local junk yard got a new car until one came in that had it's seat right in the middle
I bought a tiny 12v battery at the hardware store for just this purpose.Originally posted by usdmej View Post
how are you guys extracting these seats from junk yard cars? for powered seats, you have to move the seat fore and aft to access the bolts but the cars at the junk yard don't have any power on them
how are you guys extracting these seats from junk yard cars? for powered seats, you have to move the seat fore and aft to access the bolts but the cars at the junk yard don't have any power on themOriginally posted by Obioban View Post$25 per seat at my local junk yard.
I really feel like it's worth buying a used non M seat. They're dirt cheap and have all the donor parts needed-- seat heater pads, sliders, seat side plug, etc. $25 per seat at my local junk yard.
- Likes 3
Yeah, one of each of those in each seat. Pretty sure they will plug right into the harness but I have not installed my seats yet. All information I could find beforehand indicated that they will.Originally posted by su45 View Post
Are these the E39 pads that were installed in yours: https://www.bmwpartsdeal.com/parts-l...t_heating.html ?
Are they plug and play with the OE harness or did they have to make any modifications? I'm looking to use the E39 pads with some Pole Position ABEs.
Those are decent prices too, only a few bucks more than I paid from Schmiedmann last year.
Are these the E39 pads that were installed in yours: https://www.bmwpartsdeal.com/parts-l...t_heating.html ?Originally posted by repoman89 View Post
The E39 pads are compatible. Some local guys have used them in their Nogaros successfully (or at least that’s what HMS told me). I just got my seats in finally with integrated E39 pads. They’re not cheap though.
Iam still looking into it.. But i think i will use stock runners from manual non M E46 seats with.. i have not decided yet what mounts.. bottom mounts for sure but don't know which one yet..Originally posted by Obioban View Post
You haven't really described any complete mounting solution. That said, it should not be a problem to get the seat 1-2cm lower than stock with most solutions on the market. I suspect if you only want it to be that much lower, you're going to have more issues with the seat being too low than too high.
No, it's not my aim being low, just lower a bit than stock seats, so that i will be ok when i wear a helmet.
You can get 1-2cm by changing from power to manual adjust seat basesOriginally posted by zaharias View Post
Hahaha
1meter and 83cm (I wrote it as we say it in Greek) 183cm.
What mounting solutions do I have?
I have power oem seats right now.
So one solutions is oem sliders with bk mounts and the other one is bk mounts and sliders?
Thanks Obioban
HahahaOriginally posted by Obioban View Post
1.83cm tall... do you drive a remote control car M3?
Thanks Obioban
1.83cm tall... do you drive a remote control car M3?Originally posted by zaharias View PostRecaro mounts and sliders for Recaro sportsters, sit at the same height as stock E46 M3 seats?
I want 1-2cm lower than stock.
My car has sunroof and when I went for a track day I had to remove the foam from the inside of the helmet to avoid touching the roof lining.
Iam 1.83cm tall.
I see obioban recommends some brands above.
