Originally posted by Obioban
Questions About Recaro Sportster CS Seats
Originally posted by Albino09 View PostDo the CS's have a quick release forward tilt similar to the stock seat mechanism? Or are you forced to crank the knob at the base 1/8" of tilt at a time? If so, hardly seems worth it versus a fixed back because in practice they are no more useful. Currently I use my back seat to transport my track wheels when I autocross, so I really use the quick release tilt (also for kiddos riding in the back as well).
… it’s only 4 bolts and one plug to remove a seat. I just pull a seat to load/unload tires for the track. Takes 2-3 minutes, and much reduced odds of scuffing up the interior.
Much easier with a 25 lb seat assembly than the stock 60 lb seat assembly 🤣
Better? Yes. Similar to pole positions? No.
I've always thought sportsters were a bit meh in terms of performance. Look nice though.
If you want zero compromises, the CS's are that. But, if the stock seats aren't supportive enough for you, or if you're looking for real weight savings, or if you want to be able to use harnesses properly... they're not that.
Originally posted by rkneeshaw View PostI need a seat that holds me better on track days. But I still daily the car in the summer. Will these sportsters hold me in better than oem seats? Similar to pole positions maybe? Or no?
I've always thought sportsters were a bit meh in terms of performance. Look nice though.Last edited by Thoglan; 04-18-2022, 04:01 AM.
Hard to tell from a photo but looks like they got it pretty good. Rarely does a full retrimmed seat look right, but yours do.
see here the color match
Has anyone successfully used these on a cabrio? Any other seat on a cabrio for that matter ? I understand the cab seat’s seatbelt is attached to the seat itself hidden behind a plastic panel but couldn’t one attach that to a fabricated bracket behind the seat ? Replicating a similar setup and going through the seatbelt opening? Is it a technical issue or a legal one ? Just curious - never saw any setup for a cab. Thanks !
Originally posted by Ramps View Post
Wow! Perfect interior…maybe i missed it earlier in the thread but did you order them in that colour or have them recovered?? If they’re recovered, where’d you source the leather from?
Retrimed here in Greece.
Found same leather as oem.
