Originally posted by zaharias
Questions About Recaro Sportster CS Seats
Originally posted by BBB View Post
Nice color for the Sportsters, looks great.
I did find that my kit was missing 8x bolts that were required to bolt the BK mounts to the OEM Sliders. Additionally, since I bought my Sportsters from a custom upholsterer, the main "triple square torx" bolt that attaches at the hinge point for the seat back/seat bottoms for my CSs was not the same size (one of them was not a "riple square torx). So my recommendations are- Double check the hinge torx/bolts for both seats first (2x/seat so 4x total) before complete assembly. Be sure you have the correct socket head/tool in case you need to detach/reattach (my seat came completely disassembled). Looks like you should be okay, but would be helpful to know if you wanted to eventually add the passenger occupancy seat pad to the seat.
- Mock up 1) the OEM sliders to 2) the BK seat mounts and count your bolts to make sure you have enough. They do provide the correct sized bolt, so you can bring that one to the store to double check the thread size.
Other than that, take your time! It may help to have an extra set of hands for one part of the reassembly.
Do you remember the bolt specs so that i can go buy and have some? You mean these bolts that the size depends on the spacer you use? (i read that in the BK instructions).
Many thanks for the info & tips!!
Originally posted by zaharias View Post
Thanks.
I will.
Yes it’s occupancy sensor until I code the airbag.
I don’t have heated seats.
Other than that, take your time! It may help to have an extra set of hands for one part of the reassembly.Last edited by BBB; 01-13-2022, 01:00 PM.
Originally posted by duracellttu View PostNice! Please report back with your thoughts on this setup. I’m planning to use the BK mounts as well.
Why is that connector? OEM controls for heated seats? Occupancy sensor?
I will.
Really great to hear that you like them so much. Curious if you had AMX integrate the heated seat option that work with OEM console controls.
Also, which mounts did you end up using?
I never use heated seats - my car is garaged and SF doesn't get too cold. I had them install OEM seat sensors and omit the heated seats.
Also fixed the previous post since the images were broken!
Echoing what usdmej is saying above - Sportster CS' have superior comfort especially on long drives in my experience.
For context, my car came with manual seats. I had chronic butt/lower back pain due to too much lumbar support (had a couple 3-4 hour drives).
When I upgraded to Sportster CS in 2021, I made 4x trips which were reach well over 4.5 hour drives each way (so 8x 4.5-5.5 hour sessions in the Sportster CS). Zero lower back or butt pain. To be honest I wasn't expecting them to be so comfortable on long drives.
Haven't shared any pictures but just for shits and giggles - got custom ones upholstered from AMX. Highly recommend AMX and hope to use them again for future custom Recaros. First pics were the ones they took before they shipped them from Germany, second one is after I installed them. My E46 M3 is my only car - I use these seats for DD duty:
Originally posted by zaharias View PostI remember reading somewhere that oem seats without the lumbar support on long drives are responsible for low back ache and i feel so,since mine doesnt have. Also somtimes i slip on the seat. Ive got a pair of sportsters CS retrimmed in cinnamon, i ve got BK mounts, oem manual sliders and an occupancy sensor bypass and want to fit them.
They look and feel comfy, i fit nice, i feel they support me better than my oem ones, but i just wanted to ask those that went from stock to sportsters CS, how is the back on long drives..
Originally posted by zaharias View Posti just wanted to ask those that went from stock to sportsters CS, how is the back on long drives..
i acutally felt the stock seats had too much lumbar support and it contributed to my back being wrecked on long drives (3+hours). the sportsters i don't have that issue with.
Yeah. I don’t particularly find the CS’s more supportive or more comfortable than stock— try before you buy and make sure they’re good for your body type. And unless you’re a midget, don’t expect to use the harness holes on the CS.
Originally posted by zaharias View PostAre these more comfortable than oem seats or not?
I can understand they hold you better especially when oem seats don't have lumbar support.
particularly with seats, you should try before you buy
