Questions About Recaro Sportster CS Seats
  • zaharias
    Do I need anything else to fit them?
  • zaharias
    Thanks usdmej & BBB!!
    I also bought BK mounts with OEM sliders from manual non M E46 and want to fit them when i have some free time.
  • BBB
    Really great to hear that you like them so much. Curious if you had AMX integrate the heated seat option that work with OEM console controls.
    Also, which mounts did you end up using?
    Used BK mounts with OEM sliders - I'm shorter so I wanted to sit a bit higher (common reviews say Recaro sliders sit low).
    I never use heated seats - my car is garaged and SF doesn't get too cold. I had them install OEM seat sensors and omit the heated seats.
    Also fixed the previous post since the images were broken!
  • duracellttu
    Originally posted by BBB View Post
    Echoing what usdmej is saying above - Sportster CS' have superior comfort especially on long drives in my experience.
    For context, my car came with manual seats. I had chronic butt/lower back pain due to too much lumbar support (had a couple 3-4 hour drives).
    When I upgraded to Sportster CS in 2021, I made 4x trips which were reach well over 4.5 hour drives each way (so 8x 4.5-5.5 hour sessions in the Sportster CS). Zero lower back or butt pain. To be honest I wasn't expecting them to be so comfortable on long drives.
    Haven't shared any pictures but just for shits and giggles - got custom ones upholstered from AMX. Highly recommend AMX and hope to use them again for future custom Recaros. First pics were the ones they took before they shipped them from Germany, second one is after I installed them. My E46 M3 is my only car - I use these seats for DD duty:
  • BBB
    Originally posted by zaharias View Post
    I remember reading somewhere that oem seats without the lumbar support on long drives are responsible for low back ache and i feel so,since mine doesnt have. Also somtimes i slip on the seat. Ive got a pair of sportsters CS retrimmed in cinnamon, i ve got BK mounts, oem manual sliders and an occupancy sensor bypass and want to fit them.
    They look and feel comfy, i fit nice, i feel they support me better than my oem ones, but i just wanted to ask those that went from stock to sportsters CS, how is the back on long drives..
  • usdmej
    i acutally felt the stock seats had too much lumbar support and it contributed to my back being wrecked on long drives (3+hours). the sportsters i don't have that issue with.
  • zaharias
  • Obioban
    Yeah. I don’t particularly find the CS’s more supportive or more comfortable than stock— try before you buy and make sure they’re good for your body type. And unless you’re a midget, don’t expect to use the harness holes on the CS.
  • usdmej
    Are these more comfortable than oem seats or not?
    I can understand they hold you better especially when oem seats don't have lumbar support.
    i've personally never found the OE front seats to be anywhere near comfortable. switching to the sportsters solved that for me. they are great DD seats. not sure what lumbar support has to do with holding you in a seat, but the lateral support of the sportsters is similar to OE.
    particularly with seats, you should try before you buy
  • zaharias
  • usdmej
    So if I used the BK adapters either OEM sliders, how do I adjust the fixed height setting? Some sort of spacers?
    if you go with BK/oe sliders i'd start with no spacers at first. at 5'10 running this setup it sits a little on the high side to me
    when i ran my sportsters with the swiss cheese plates and recaro sliders i felt it was a little too low. ultimately decided to stick with the BK setup
  • Obioban
    Yeah, they come with spacers to set the height.
  • duracellttu
    I don’t believe there’s any way to retain adjustable height.
  • Obioban
  • duracellttu
    Bumping this, as I’m getting closer to pulling the trigger on the CS seats.
    What is the best option for seat mounts if I want to retain height adjustment with the CS? Will the OEM adapter work with the CS seat? Or is there a way to keep the OEM 3-way adjustment mechanism?
