What happened to injector prices?
  • terra
    One of the reasons I choose not to daily an old BMW as much as I love them.
    At least things like fuel injectors can usually be worked around by using a similar fuel injector and minor tune tweaks. Suspension pieces going NLA is a problem though.
  • Obioban
    Originally posted by JakeM346 View Post
    Well just to provide some information Bosch and also ZF (Most known for Lemförder) have laid of significant workforce here in Germany and also in other places. In addition to that they have closed a lot of lines producing old parts. The S54 injectors for one but also the ride components. So 911 pre 2000 suspension parts are completely out of production and bmw e46 m3 suspension parts are going out to. The at least had a new run 2023 so parts places still have good stock. In general it’s recommendable to now do all your refreshes because I don’t expect most of these parts being produced again for the next 5-10 years and bmw increases the price of their stock tremendously as not to have nla shown in the parts Departement (something aloung the line of you could buy but… do you realllyyy need it)
    This is about the worst news I've read on this forum. So many OE parts, made by Lemforder, that will just go away.
    Also awful news for e39.
    Time to figure out what to stockpile...
  • samthejam
    I wonder how they deal with selling tools to make the parts.
    For instance, on E28s they had a common upgrade to use E31 Lower Control Arms which were a factory spherical piece. These were availalbe from Lemforder for many years. Now any Lemforders left on the market will be used or is held by BMW. I'm, sure there is a set or two NOS floating around but nothing available from retailers.
    Mevotech now supplies them and I can get them from Rockauto, I have seen good reviews from lemons teams, shops and other users with daily drivers now after a couple of years. But I just wonder if tooling, molds etc get sold to some of these other lower end companies we'd have avoided. Now even if they are using the same tooling, is the manufacturing process the same.... for heat treatment, material sourcing etc who knows.
    I have found used parts are the best ways to stretch my dollar further with all these increasing problems. However it is scary that things like this will become a concern as modern tire grip increases. Spec3 has this stated in their build list for their cars due to on track failures.
    E34 M5 Front rotors are a similar debacle.
  • Altaran
    When it comes to replacing injector o-rings, is there a favored/more reliable brand?
    For the lower ring I bought Elring 135.500. The specs are slightly different, so the fit is a bit tight, but they work.
  • JakeM346
  • ljmartyre
    Originally posted by lukasss View Post
    I’m going to pressure test this weekend. After some new info from the PO, it seems like the fuel filter and the pressure regulator were replaced but not the actual pump/ sending unit itself. Turns out the issue started immediately after that…go figure.
    Ordered a new Hella fuel pump either way. $700+ for the BMW one is absurd.
    Pulled some sort of bastardized Hella/??? fuel pump out. Put the new Hella one in, and it runs beautifully.
    Idle is smoothed, fires up first try no issues.
  • PSUEng
  • ljmartyre
  • samthejam
    Every single start. 90% of the time I can crank it for a 2 seconds, immediately of/on again and it’ll start fine. Hardly ever hesitation on the second crank.
    The longer it sits, the more cycles it’ll take to start.
    Can you test the fuel pressure during both cases? If aftermarket fuel pump might not have a check valve and leaking down. OE one I would assume could fail in this way as well. So when it sits you're rebuilding 5 bar of fuel pressure.
  • Flow
    Leaking injector that partially floods a cylinder ?
  • ljmartyre
  • ATB88
    I have these in my car currently. I’ve been trying to track down a no start issue. Well rather it requires one attempted start and then usually fires up on the second crank. Rich codes. Sometimes finicky idle. Once’s it’s driving its butter and fuel economy is very good.
    Replaced MAF, fuel pump and associated parts, etc.
    Has an HTE tune. Hassan seems to think it’s potentially a latency difference, or vacuum leak from the injector o-rings not sealing properly.
    Another member stated it seems that the injectors linked are not exact but very close. 263.8 cc per minute where as the factory injectors are 268.4 cc per minute. Could that make a genuine difference like this but only on startup or idle?
    https://www.ebay.com/itm/28356536326...EAAOSwEExdQJ~-
    Is your no-start every time? I have an intermittent no-start I've been chasing for years, with every possible fuel component and sensor replaced. But it's more of a once in a while issue rather than a daily one.
  • ljmartyre
    I’ve noticed that in other threads and such. Based on the paperwork I have they are Bosch Part # 0280156065.
    I inherited this when I bought the car a few weeks ago so I’ve not yet pulled them out to look for myself but I will in a day or two.
  • Flow
    Well, what is the exact BOSCH SKU that you have ?
    As those vendors seem to just ship to you whatever they have in stock.
  • ljmartyre
