Diff rebuild in Los Angeles?
  • Irhase46m3
    +1.
    V1 has more plays on the right side with shorter flange.
    I posted before that there is different markings on the output flanges concave surface.
    I thought you could tell from the production year, anything 2005, 2006 has V2 and 2001 - 2004 would have the V1? Do i have this wrong? When i originally placed my order with the guys from racingdiffs, they established it was the V1 based on the production year, Im 04/04 as well.
  • Irhase46m3
    Originally posted by Chanman1029 View Post
    I bought the rebuild kit from RacingDiffs and then took it to Oceanside driveline for them to rebuild it. They have been known to do other very quality work, according to some of my friends who are in the automotive repair industry. I think he charge me like $375 for the labor to rebuild it, I supplied all the parts to him.
    I certainly trust Oceanside driveline for any of my drivetrain work.
    I've ordered a rebuild kit from them as well, i've had it sitting for a few years now. How is it holding up? I might consider taking it to them to do the rebuilding as i understand it is an art to get it properly rebuilt.
  • sapote
    You can pull the output hubs and based on which side has the longer shaft you can discern V1 from V2. You can also tell V1 from V2 based on which output flange has play in it.
    +1.
  • jayjaya29
  • LSB4Me
    No real way to tell that I know up other than pulling the rear diff cover.
    Thanks, Bigjae. My car has a build date of 04/04. Assume that means I have the V2 unit in the later cars, correct?
  • bigjae46
    Hey Everyone:
    Is there a diff shop in the Los Angeles (or SoCal) area that can be trusted with a diff rebuild? I'm aware of diffsonline but would prefer to have a local shop do the work if there's one we trust. Thanks in advance.
    Also, one question: I have an 04 and am looking at a spare diff to use for the rebuild. Am I able to use an early diff in my car? If not, what is the quick/easy way to tell if its one of the later units?
    Are you looking to swap in a different LSD unit or pull the entire diff apart and replace all the bearings?
    If it's just the LSD unit you can just pull the rear cover and side covers off, swap the ring gear over, press on bearings and reinstall. Just check the gear pattern as a double check.
    Bearings, seal and stuff will be about $300-$400. Figure about 2-3 hours of actual labor time. If you are keeping the same R&P...a DIY isn't too bad as long as you have access to a press.
  • EthanolTurbo
    I got my Drexler 3.91 build done in San Diego. Cost $900 for everything including labor and rebuild parts.
  • LSB4Me
    Awesome--appreciate the recommendation. I'll give them a call tomorrow.
  • LSB4Me
    You can ask Anri
    Thanks, I sent him a PM.
  • Chanman1029
  • Slideways
    Hey Everyone:
    Thanks in advance.
    You can ask Anri
  • LSB4Me
    started a topic Diff rebuild in Los Angeles?
    Hey Everyone:
