V2 Diff rebuild + Gear Ratio Swap (4.10)
  • bigjae46
    I think a little bit of whine is normal.
    A buddy has a Turner built 4.10 (assuming it is a diffsonline) whines...has been whining for 14 years. Long story but we swapped in a V2 unit and then a ZF...ring gear and pinion looked immaculate. Drove another car with a Dinan 3.91 which whined. I'm pretty sure both cars have OEM bushings.
    I've had a 3.73 and a 3.91, both REM polished. I can't detect a whine even from in-car footage but my car is quite loud too.
  • Cubieman
    I have a stock diff currently being rebuilt, when I pull the 4.10 out I'll take some photos. May be a few weeks however. FWIW is hear no whine with my diff and I have removed all sound deading from under the rear seat/soild SF bushes.
  • fattycharged
    When I get some time, I'll take some photos of the pattern of my used 4.1 v1, but it wont be anytime soon
  • maupineda
    Posting updates here for future DIY'ers.
    I put the diff back on, again thanks Slideways for the help for the second time. I have driven about 140miles with the new setup, basically went back to the original pinion shim thickness, and that alone move the backlash from 0.07mm to 0.12, so I left it at that. Now, the diff is 100% silent from 0-50mph, from there, and up to 70mph, there is a faint whine that happens while traveling at steady state speed, so not entirely coasting, just sustained speeds which means very little load, if I let it coast in gear, whine is gone, and there is no whine on deceleration at any speed I have tested, which is from 90 down to 0. When accelerating, is also whine free up to 90, at which there is a faint whine that I suppose will increase with speed, but I did not want to loose my license LOL
    so the whine is only on very light load to maintain speed. So it may be this level of whine is what I can consider normal, but if I can get my hands on a diff tool, I would like to check for sure.
    The OE pinion does not have any scribe indicating deviation from nominal, if it did, it would be tremendously helpful as that would be all needed to know what shim adjustments are needed. My 4.1 pinion had a "-1" scribed.
    Cubieman / fattycharged , as 4.1 users, what has been your experience? any pics of your gear patterns?
  • fattycharged
    I have gotten the real marking compound and checked the pattern, I think is better with the original pinion shim, the reality is that without the factory tool there will be some guessing, however I can now see this hamburger bun shapes on both, coast and drive.
    the one thing I am not happy about is that coast and drive are not centered along the tooth, but neither are on the original diff from my car, so that maybe a design nuance.
    the prior setup was ok on the drive side but a bit off (deep) on coast where I could only see one “bun” and a flatter line on the root side.
    For reference this is how the original diff reads
    So much easier to see now 😎
  • maupineda
    it does, and surely would of saved me from reopening the diff lol.
    Back lash is between 0.0045 / 0.0048. or ~0.12mm.
    Pre-load was set to what it was at the time I took the pinion off as the bearings have had some break-in time.
  • bigjae46
    Doesn't real gear marking compound work a lot better?
    I learned the same lesson.
  • maupineda
  • bigjae46
    Yeah, shorter hearing has fewer teeth on the pinion and the head is smaller - very noticeable when comparing a 3.15 to a 3.91. I'm sure there is more heat and wear with a shorter diff - the wheels are spinning faster at any given RPM.
    Agreed, want to get closer to the middle of the spec.
    Here are the specs I use:
    Carrier Preload - 9 to 11 in/lbs
    Backlash - .003" to .0035"
    Pinion Preload - 14 to 16 in/lbs
    Here are the BMW specs I got from Bimmerforums
    Carrier Preload - 11 to 23 in/lbs
    Backlash - .0024" to .0055"
    Pinion Preload - 12 to 23 in/lbs
  • maupineda
    I've never gone below .003". I feel like the shorter the gearing, the closer you need to be at .003 to .0035 to get the gear pattern right which I believe is Diffsonline's spec. A 4.10 has a small pinion gear so I would guess that you need to be more precise to get the proper gear pattern.
    I have heard of failures with 4.44 gears related to pinion gear damage. Wonder if they were within the wider BMW spec or the tighter alleged Diffsonline spec.
    Have been looking at this a bit more, the BMW 4.1 has 41 teeth in the crown, which means pinion is 10 for a 4.1 ratio.
    The stock gears have 47 teeth crown, and the pinion has 13 (3.615 which rounds to 3.62)
    So there are more teeth in the 3.62 OE setup, but relatively speaking, the 4.1 setup has more teeth on the crown in relation to the pinion and due to the higher velocity difference between the two they would generate more heat and potentially higher thermal expansion. I wish I had a way to measure all this. all I can say at this point, is that my diff is just too tight and need to go to the higher end of the spec. I asked Dan from diffsononline and he said the patter is not bad, and racing diffs said they pinion preload was set too tight, so their feedback is not cristal clear.
  • bigjae46
  • maupineda
    Here is another data point. This is what I measured in my original diff, this has 90k kms or 55k miles. 100% stock and original to the car.
    P.S. If you read my first posts you will see the spare diff measured 0.0025, but this was a used unit which had color marks on the side caps and a bad front threaded hole, so who knows if it had been messed with at some point. Still in spec though, so could be the spare unit was on the tight side.
  • bigjae46
    IIRC, I targeted .0035” for the backlash. Me no so
    peak metric.
    So you swapped ratios? It is not uncommon to have some whine with shorter gearing. I’d leave it alone unless you’re not confident that your backlash reading is spot on.
  • maupineda
    Small update, or more like a small review on my work.
    I completed the install of the diff (thanks Slideways) last weekend, and since then I have driven the car about 300 miles. and I will start with things that are relevant for forum readers that are thinking about this type of job as a DIY.
    Below are the specs I setup the diff to.
    2.2NM pinion preload (20in-lb)
    2.0NM for carrier preload (18in-lb)
    0.06mm of backlash
    Driving the car up to 75mph is perfect, however, from that speed on a whine starts to be noticeable and the faster the car goes, the higher the pitch and more noticeable. is not terrible, but for a car with stock diff bushings it should be quite.
    After reading online, and revisiting the RD videos, seems I made a bad decision by sticking to the lower end of the spec for backlash.
    From E36 TIS data, we have that the preload, or frictional torque varies by bearing brand and for the Koyo items the spec goes from 2.4 to 4.8, which seems a lot. RD in their videos aim for 1NM, and when I was setting my diff I know 1NM felt loose and would allow for the bearing to make some noise. so I sticked to a value that is withing the range of the BMW spec as well as other builders. So I have no concern with the preloads I used. However, the backlash is bit less clear on the BMW files.
    Per TIS it is:
    Backlash - 0.06 to 0.14 (0.0024 to 0.0055) - assumes this is for EVERTHING but:
    Vehicles with M60B40 - 0.04 to 0.1mm (V8 cars would have taller gears and thus less sensitive to a tight diff)
    It seems that the higher ratio gearsets need more tolerance as they become more sensitive to thermal expansion due to the larger number of teeth and so the backlash is best to be set on the higher end. RD recommends 0.1 - 0.12, which is still within the BMW spec.
    The sad part of this is that it means another round of diff off/on.
    So sharing this experience here for future DIY'ers as very few share data on their setups and save others from the iterative process this can be.
    Lastly, after reviewing my many photos of the gear pattern, seems it was best with the OE pinion shim, although it looked a bit high on the tooth, it also had the best contact area, so I will remove the 0.1mm shim I added to the pinion and roll with the original shim thickness only and aim for 0.1 - 0.12 backlash.
    As for the shorter gears... well yes, it is very much noticeable and the car does feel way peppier, all gears remain very usable including 1st gear. In 2nd gear it can flash the traction control light as it wants to spin the tires a bit. On the road the car does feel stronger and no longer needs a downshift going uphill. The car is a bit busier at 75mph and you have now 3.4k rpms v 3k on the stock gearing. 400rpm is not much, but it is something that can annoy others, particularly with loud exhausts, I will say this, a 3.91 would be a mid point as it is 8% shorter so it is 80% of the 4.1 with a bit more flexibility for highway users. I personally don't bother it, and I love the feel of large engine in a small car it gives. and with the CSL airbox, the experience is just awesome! What it is refraining me from full happiness is the whine, but I think it will be fine once I fixed the setup with the correct backlash
    Final setup (with 0.1mm shim under the pinion bearing)
    This is the contact patch with just the OE shim
  • maupineda
    I think it is over kill the replace those every time. I know BMW spec is to replace but my guess is it goes beyond the fastener wearing out. When BMW repairs a vehicle there is absolutely an expectation of appearance. Rusty or marred bolt heads are a no-go. And I think BMW wants to do everything within reason to avoid a repeat of the symptom. Customer satisfaction. Again, just my opinion.
    100% agree, in my case is just to maintain it rust free so in year to come I don't struggle to remove seized bolts. if left as shown above, they are raw, and would rust by just touching them LOL, I will post a pic of how they look with black oxide.
