Ok just restarted the car and the SES light came up.
Also was able to run the test that was posted by karter16
The results are below. thoughts?
Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
Start : 29.04.2024 19:15:36.2
Nr 1( 1) : 29.04.2024 19:15:36.3
apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
JOB_STATUS = OKAY
EVAN_ISTWERT = 59 00 3B .;
EVAN_SOLLWERT = 52 00 34 .4
EVAN_ISTWERT_EINH = Grad KW
EVAN_SOLLWERT_EINH = Grad KW
Nr 2( 1) : 29.04.2024 19:15:41.7
apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
JOB_STATUS = OKAY
Nr 3( 1) : 29.04.2024 19:15:47.0
apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
JOB_STATUS = OKAY
EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
EVAN_VERSTELLZEIT_FRUEH_EINH = ms
EVAN_VERSTELLZEIT_SPAET_EINH = ms
Nr 4( 1) : 29.04.2024 19:15:53.3
apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
JOB_STATUS = OKAY
EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
Nr 5( 1) : 29.04.2024 19:16:07.7
apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
JOB_STATUS = OKAY
AVAN_ISTWERT = 48 00 30 .0
AVAN_SOLLWERT = 20 00 14 ..
AVAN_ISTWERT_EINH = Grad KW
AVAN_SOLLWERT_EINH = Grad KW
Nr 6( 1) : 29.04.2024 19:16:13.0
apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
JOB_STATUS = OKAY
AVAN_ISTWERT = 49 00 31 .1
Nr 7( 1) : 29.04.2024 19:16:18.3
apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
JOB_STATUS = OKAY
AVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
AVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
AVAN_VERSTELLZEIT_FRUEH_EINH = ms
AVAN_VERSTELLZEIT_SPAET_EINH = ms
Nr 8( 1) : 29.04.2024 19:16:24.6
apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
JOB_STATUS = OKAY
AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
Stop : 29.04.2024 19:16:39.7
Dauer : 63.5 s
β
Went for a drive, lost power and now car exhaust sounds like it has cams
cleared the codes and went for a drive and it still is pretty rough. no lights on the dash but here were my new error codes:
E R R O R M E M O R Y R E P O R T ------------------------------------- Date: 04/29/24 19:12:48 ECU: MSS54DS0 JobStatus: OKAY Variant: MSS54DS0 ------------------------------------------------------------- RESULT: 8 errors in error memory ! ------------------------------------------------------------- 205 Aussetzer Zyl.1 Abgas Error frequency : 2 Logistic counter: 80 Error occured 1. times at: Motordrehzahl 1080.00 1/min relative Fuellung 29.60 % Kuehlwassertemp. 33.00 Grad C Versorgungsspannung HR 14.00 V aufgetreten vor (rel. BZ) 0.00 h Error occured 2. times at: Motordrehzahl 880.00 1/min relative Fuellung 28.00 % Kuehlwassertemp. 78.00 Grad C Versorgungsspannung HR 14.10 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden sporadischer Fehler ------------------------------------------------------------- 206 Aussetzer Zyl.2 Abgas Error frequency : 2 Logistic counter: 80 Error occured 1. times at: Motordrehzahl 1080.00 1/min relative Fuellung 29.60 % Kuehlwassertemp. 33.00 Grad C Versorgungsspannung HR 14.00 V aufgetreten vor (rel. BZ) 0.00 h Error occured 2. times at: Motordrehzahl 880.00 1/min relative Fuellung 28.00 % Kuehlwassertemp. 78.00 Grad C Versorgungsspannung HR 14.10 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden sporadischer Fehler ------------------------------------------------------------- 207 Aussetzer Zyl.3 Abgas Error frequency : 2 Logistic counter: 80 Error occured 1. times at: Motordrehzahl 1080.00 1/min relative Fuellung 29.60 % Kuehlwassertemp. 33.00 Grad C Versorgungsspannung HR 14.00 V aufgetreten vor (rel. BZ) 0.00 h Error occured 2. times at: Motordrehzahl 880.00 1/min relative Fuellung 28.00 % Kuehlwassertemp. 78.00 Grad C Versorgungsspannung HR 14.10 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden sporadischer Fehler ------------------------------------------------------------- 208 Aussetzer Zyl.4 Abgas Error frequency : 2 Logistic counter: 80 Error occured 1. times at: Motordrehzahl 1080.00 1/min relative Fuellung 29.60 % Kuehlwassertemp. 33.00 Grad C Versorgungsspannung HR 14.00 V aufgetreten vor (rel. BZ) 0.00 h Error occured 2. times at: Motordrehzahl 880.00 1/min relative Fuellung 28.00 % Kuehlwassertemp. 78.00 Grad C Versorgungsspannung HR 14.10 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden sporadischer Fehler ------------------------------------------------------------- 209 Aussetzer Zyl.5 Abgas Error frequency : 2 Logistic counter: 80 Error occured 1. times at: Motordrehzahl 1080.00 1/min relative Fuellung 29.60 % Kuehlwassertemp. 33.00 Grad C Versorgungsspannung HR 14.00 V aufgetreten vor (rel. BZ) 0.00 h Error occured 2. times at: Motordrehzahl 880.00 1/min relative Fuellung 28.00 % Kuehlwassertemp. 78.00 Grad C Versorgungsspannung HR 14.10 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden sporadischer Fehler ------------------------------------------------------------- 210 Aussetzer Zyl.6 Abgas Error frequency : 2 Logistic counter: 80 Error occured 1. times at: Motordrehzahl 1080.00 1/min relative Fuellung 29.60 % Kuehlwassertemp. 33.00 Grad C Versorgungsspannung HR 14.00 V aufgetreten vor (rel. BZ) 0.00 h Error occured 2. times at: Motordrehzahl 880.00 1/min relative Fuellung 28.00 % Kuehlwassertemp. 78.00 Grad C Versorgungsspannung HR 14.10 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden sporadischer Fehler ------------------------------------------------------------- 213 Aussetzer mehr Zylinder Abgas Error frequency : 1 Logistic counter: 80 Motordrehzahl 1080.00 1/min relative Fuellung 29.60 % Kuehlwassertemp. 33.00 Grad C Versorgungsspannung HR 14.00 V aufgetreten vor (rel. BZ) 0.00 h im 1. Messintervall Fehler momentan vorhanden statischer Fehler ------------------------------------------------------------- 184 EVANOS1-Regelung Error frequency : 1 Logistic counter: 40 Motordrehzahl 960.00 1/min Oeltemperatur TOG 27.00 Grad C Kuehlwassertemp. 38.00 Grad C Versorgungsspannung HR 14.00 V aufgetreten vor (rel. BZ) 0.00 h kein Druck Fehler momentan vorhanden statischer Fehler ================================================== ===========
I'll get working on the test a little later today. I pulled theses codes via INPA and now I will try and clear it so I can go for a quick drive to get the car up to temp.
its crazy how much more detailed this is compared to the codes I pulled off of my iphone. only if i understood it all haha.
E R R O R M E M O R Y R E P O R T ------------------------------------- Date: 04/29/24 18:48:33 ECU: MSS54DS0 JobStatus: OKAY Variant: MSS54DS0 ------------------------------------------------------------- RESULT: 10 errors in error memory ! -------------------------------------------------------------
139 Tempomatsystem Error frequency : 6 Logistic counter: 38 Error occured 1. times at: Motordrehzahl 1920.00 1/min relative Fuellung 32.80 % Umgebungstemp. CAN 18.00 Grad C Versorgungsspannung HR 13.90 V aufgetreten vor (rel. BZ) 1.20 h Error occured 2. times at: Motordrehzahl 1880.00 1/min relative Fuellung 33.60 % Umgebungstemp. CAN 18.00 Grad C Versorgungsspannung HR 13.30 V aufgetreten vor (rel. BZ) 1.10 h Error occured 3. times at: Motordrehzahl 1920.00 1/min relative Fuellung 25.60 % Umgebungstemp. CAN 19.00 Grad C Versorgungsspannung HR 13.80 V aufgetreten vor (rel. BZ) 1.10 h v-Signal unplausibel Fehler momentan nicht vorhanden sporadischer Fehler -------------------------------------------------------------
185 AVANOS1-Regelung Error frequency : 1 Logistic counter: 40 Motordrehzahl 880.00 1/min Oeltemperatur TOG 102.00 Grad C Kuehlwassertemp. 85.00 Grad C Versorgungsspannung HR 13.80 V aufgetreten vor (rel. BZ) 0.10 h Istwert zu gross Fehler momentan vorhanden statischer Fehler -------------------------------------------------------------
184 EVANOS1-Regelung Error frequency : 2 Logistic counter: 40 Error occured 1. times at: Motordrehzahl 3880.00 1/min Oeltemperatur TOG 101.00 Grad C Kuehlwassertemp. 87.00 Grad C Versorgungsspannung HR 13.70 V aufgetreten vor (rel. BZ) 0.10 h Error occured 2. times at: Motordrehzahl 2040.00 1/min Oeltemperatur TOG 100.00 Grad C Kuehlwassertemp. 83.00 Grad C Versorgungsspannung HR 13.80 V aufgetreten vor (rel. BZ) 0.00 h Istwert zu gross Fehler momentan nicht vorhanden sporadischer Fehler -------------------------------------------------------------
205 Aussetzer Zyl.1 Abgas Error frequency : 1 Logistic counter: 80 Motordrehzahl 880.00 1/min relative Fuellung 27.20 % Kuehlwassertemp. 82.00 Grad C Versorgungsspannung HR 13.90 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden statischer Fehler -------------------------------------------------------------
206 Aussetzer Zyl.2 Abgas Error frequency : 1 Logistic counter: 80 Motordrehzahl 880.00 1/min relative Fuellung 27.20 % Kuehlwassertemp. 82.00 Grad C Versorgungsspannung HR 13.90 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden statischer Fehler -------------------------------------------------------------
207 Aussetzer Zyl.3 Abgas Error frequency : 1 Logistic counter: 80 Motordrehzahl 880.00 1/min relative Fuellung 27.20 % Kuehlwassertemp. 82.00 Grad C Versorgungsspannung HR 13.90 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden statischer Fehler -------------------------------------------------------------
208 Aussetzer Zyl.4 Abgas Error frequency : 1 Logistic counter: 80 Motordrehzahl 880.00 1/min relative Fuellung 27.20 % Kuehlwassertemp. 82.00 Grad C Versorgungsspannung HR 13.90 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden statischer Fehler -------------------------------------------------------------
209 Aussetzer Zyl.5 Abgas Error frequency : 1 Logistic counter: 80 Motordrehzahl 880.00 1/min relative Fuellung 27.20 % Kuehlwassertemp. 82.00 Grad C Versorgungsspannung HR 13.90 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden statischer Fehler -------------------------------------------------------------
210 Aussetzer Zyl.6 Abgas Error frequency : 1 Logistic counter: 80 Motordrehzahl 880.00 1/min relative Fuellung 27.20 % Kuehlwassertemp. 82.00 Grad C Versorgungsspannung HR 13.90 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden statischer Fehler -------------------------------------------------------------
213 Aussetzer mehr Zylinder Abgas Error frequency : 1 Logistic counter: 80 Motordrehzahl 880.00 1/min relative Fuellung 27.20 % Kuehlwassertemp. 82.00 Grad C Versorgungsspannung HR 13.90 V aufgetreten vor (rel. BZ) 0.00 h im Betriebsintervall Fehler momentan vorhanden statischer Fehler ================================================== ===========
I have no idea what these mean but it seems to have to do with the VANOS
Only you can decide based on what you're hearing and what you think the risk is. If it was me in your position I'd try to rule out serious causes first, and also check things like the connectors others have mentioned first.Originally posted by jpy1980 View PostThanks guys. Question. Should I clear the codes and try driving around in order to get my car up to temp? It was running pretty rough last night and I haven't started it back up again.
Thanks guys. Question. Should I clear the codes and try driving around in order to get my car up to temp? It was running pretty rough last night and I havenβt started it back up again.
Ah good call! Yes that's right. I'll amend my post as well for anyone in the future reading this.Originally posted by elrichmeister View PostFor the Tool32 VANOS test i think the car needs to be at operating temp. When i tested mine i did some spirited driving then, let it idle and ran the test.
Yes the car needs to be running (Vanos system relies on oil pressure to operate) and computer connected. Use INPA first to verify connectivity. This is just a different way of running the same series of tests DIS does, so read up on the DIS VANOS test process and that will give you your list of pre-reqs. (As far as I can remember it's just that the car is running and the interface is connected. Edit: as elrichmeister notes in their post below the engine also needs to be up to operating temperature - e.g. oil up to temp). You'll know it's working because the sound of the idle will change as it advances and retards the cams.Originally posted by jpy1980 View Post
Tried to do it but not sure if it worked properly? Does the car need to be on when running this? Not sure if the computer is really connected to the car. See the results:
Start : 29.04.2024 17:33:10.5
Nr 1( 1) : 29.04.2024 17:33:10.8
EDIABAS Fehler 28 : IFH-0018: INITIALIZATION ERROR
Nr 2( 1) : 29.04.2024 17:33:11.0
Nr 3( 1) : 29.04.2024 17:33:11.2
Nr 4( 1) : 29.04.2024 17:33:11.4
Nr 5( 1) : 29.04.2024 17:33:11.7
Nr 6( 1) : 29.04.2024 17:33:11.9
Nr 7( 1) : 29.04.2024 17:33:12.1
Nr 8( 1) : 29.04.2024 17:33:12.3
Stop : 29.04.2024 17:33:13.7
Dauer : 3.2 s
β
Sent from my iPhone using TapatalkLast edited by karter16; 04-29-2024, 05:54 PM.
Tried to do it but not sure if it worked properly? Does the car need to be on when running this? Not sure if the computer is really connected to the car. See the results:Originally posted by karter16 View Post
OP - if you don't have DIS you can do a full VANOS test by using the tst file and instructions on this post: https://nam3forum.com/forums/forum/s...5697#post35697 to do it with Tool32.
Dauer : 3.2 s
β
I had a similar issue after doing work on some of the relays in the ECU box. I had loosened one of the main ground wires and the VANOS solenoid pack had a floating ground.
See:
UPDATE: Fixed the issue. It was loose ground connector in the e-box. If you experience sudden VANOS codes along with oil level sensor failure check your grounds! Specifically X6053. Went out to move the car today. The last few cold starts it was hard to start, would have to crank it twice. Today the SES light came on and it
Definitely do the VANOS test as others are suggesting.
Make sure nothing is interfering with throttle body opening/closing. Will go into limp mode, but it doesn't seem like I had those codes when that happened to me. I had removed and re-installed my intake and after one of my intake clamps was interfering with the mechanism to open/close.
OP - if you don't have DIS you can do a full VANOS test by using the tst file and instructions on this post: https://nam3forum.com/forums/forum/s...5697#post35697 to do it with Tool32.Originally posted by S54B32 View Postif you have dis, make vanos test. If only inpa, check at least target and actual cam position.
Unlikely that both cam sensors fail. I would guess 9/10 this is not your problem. Check if vanos solenoid plug is still attached (connector clips break very often, secure it with a zip tie). Also possible that solenoid pack has broken soldering joints inside or both broken vanos tabs can also cause same faults.
I bet it's the VANOS solenoid pack. The rebuilt ones seem to fail more often than the CPSs.
Run the VANOS test if you have DIS.
If not, unplug the solenoid pack to see if the sound changes.
This forum thread actually is exactly what my symptoms are: https://www.e46fanatics.com/threads/...e-pics.358494/
i hope itβs just the two CPS.
