Originally posted by dukeofchen
Making the throttle reliable...and how quickly can you kill a TPS?
Thanks for including those resistance test results. I'm not knowledgeable in the realm of multi-meter testing, but I do have one - so I'll give it a try.
Note on test results: The used TPS is the top one, I just pulled it off my car for this test. I'm not suggesting it's the cause of the EML, it's just the easiest one to get to. On this occasion the EML error was not accompanied by a limp mode. The sensor is a VNE, it's a few months old including 7 track days some with very high ambient temperature (over 100F) moderate oil temp and high coolant temperatures.
P.S.: A resistance test is certainly easier than creating a 5V power source and testing voltage to compare to spec. Would someone with more knowledge on this help me understand if the resistance test is valid for determining if a sensor is bad?
There does exist another failure mode on these TPS sensors, where you'll see the resistance zero out at some point while sweeping through the range. My understanding is this is caused by some corrosion of the contacts inside.
I'd be curious to know if the VNE's FCP discontinued were actually OE on our cars, or if they were indeed Hella or some other manufacturer as Altaran suggested despite VNE units clearly having logos ground off. Having gone through so many VNE units myself, it wouldn't surprise me if FCP dropped it from their catalog because of high warranty replacement rates, in which case maybe OE is the best guarantee of reliability on this one.
Originally posted by dukeofchen View Post
Took some multimeter measurements last time I had one go kaput. Can see how the resistance ranges have drifted on the failed ones, which I'm guessing would be a linear-ish process as the sensors age.
P.S.: A resistance test is certainly easier than creating a 5V power source and testing voltage to compare to spec. Would someone with more knowledge on this help me understand if the resistance test is valid for determining if a sensor is bad?Last edited by OldRanger; 08-13-2024, 09:33 AM.
Originally posted by OldRanger View PostAnother track event, another EML on the way home (Driving from West Virginia Hillfest at Snowshoe Mountain; code occurred about 1 hour after leaving venue after some miles of partial throttle behind slow traffic). Codes 76 and 78 again.
Today, I noticed that FCP Euro does not sell the VNE aftermarket BMW Throttle Position Sensor, VNE-4166000 any longer.
I ordered a Genuine BMW part so I can try the heinzboehmer approach. It would be nice to have the tools to bench test these sensors, so I could be smarter about solving the problem.​
I'd imagine you can bench test the sensors by checking resistance.
Have gone through a couple VNE's over the years at the top position, while the OE sensor in the lower position is still kicking (I'm guessing it's original).
I wonder if the top one is just more prone to failure since it's exposed to way more heat than the lower one?
Edit: realized the range calc in my original table was wrong
- Likes 3
As far as I know Hella is the T1 supplier for these parts.
I have replaced the front unit twice with aftermarket and failed within 5k kilometers. Last time I used Hella and no issue since 30k kilometers.
Originally posted by Arehman View PostThe aftermarket ones are only good for 10k miles max. Go genuine bmw on the TPs sensors.
Originally posted by OldRanger View PostIt would be nice to have the tools to bench test these sensors, so I could be smarter about solving the problem.​
However, the hard part would be getting the ambient conditions correct so you can replicate the failure mode. I've had success putting parts in the oven when trying to reproduce a thermal related electrical failure, but it's far from an exact science.
Originally posted by lemoose View PostWhat am I doing wrong if none of these sensors have failed on me in over 100k miles? lol
TPS sensors were replaced with VNE, no issues in years. Pedal was replaced with new current BMW.
Linkage fine and never replaced.
I replaced all 3 at the same time and then cleared the adaptations.
Perhaps they were replaced before my ownership- but I live in TX and it is exceptionally hot here, and I flog the car on a daily basis.Last edited by PetrolM3; 05-14-2024, 10:54 AM.
