DIYs
  • ugaexploder
    A fellow man of genius I see, I also use it.
    šŸ˜… I only found out about it not too long ago. Not sure how long it's been around, but would have loved to known about it in the past
  • Stilt
    Not sure if anyone on the forums has used this before.
    But you can get service manuals for free for cars manufactured from 1982-2014 via "charm.li" in your browser.
  • ugaexploder
  • Teemmy
    Thank you for this sticky! New to the forum and this saved my hours of searching. Just bought a 206k mile m3 that needs a lot of love šŸ˜…
  • Projecte46m3
    Great info in here!
  • WOLFN8TR
    BMW S54 WPC Treated Rod Bearing Kit Installation Instructions.
    http://bd8ba3c866c8cbc330ab-7b26c6f3...n_-_Turner.pdf
    Is it just me or does the link for every DIY from ā€œReplacing e46 side view mirror glassā€ down take you to this specific post? (Note that this is only in Tapatalk, so I suspect it’s something weird for just me, but pretty odd)
    I’m getting the same thing trying several DIY links using the Tapatalk App.
  • bmwfnatic
    As suggested by Casa de Mesa
    My guide how to order genuine special tools based on the numbers in TIS.
    Hello everyone, Occasionally I order some genuine BMW special tools as described in TIS. I find them to be of far better quality than some aftermarket replicas available, and it makes for easy repairs. At times, I have had issues finding the right part number to order the tools, since BMW decided to obfuscate this with their
  • karter16
    Is it just me or does the link for every DIY from ā€œReplacing e46 side view mirror glassā€ down take you to this specific post??
  • Obioban
    Added
  • WOLFN8TR
    S54 Vanos Info Thread
    http://uploads.tapatalk-cdn.com/20170709/b427cc1ecdc0899673ce51539b3394e1.jpg http://web.archive.org/web/20180214064458im_/http://uploads.tapatalk-cdn.com/20170709/a40017b090c94ffa891574d94069c3c0.jpg Disclaimer: ( Most of the M3Forum links below do not work anymore ) Please read and completely understand the timing
  • M3Bob
    Could we add links to a valve adjustment DIY?
    Thanks!
  • cobra
    Just fyi, looks like they did the timing incorrectly. You're supposed to torque the hub bolts with the VANOS fully seated against the head, not with it off. Follow TIS or the Beisan procedure and you'll be good.
    That's my video. Car's been running fine for 30k miles
    If you put it back together the same way you took it off it's perfectly fine. If you're swapping parts and don't have a reference then the Beisan way is the way to go for sure.
  • heinzboehmer
    VANOS bolts replacement and oil pump disk replacement
    https://www.youtube.com/watch?v=9SkT2j3jsU0
  • cobra
  • duracellttu
    Highly recommend the Bavarian Autosport Viton OFHG. I do believe ECS carries it now.
    Also saw this post on torquing the housing.
    This is the exact gasket I purchased from ECS! No brained to go with viton for this. Didn’t even know about it until I saw it referenced in a build journal post about the oil pressure valve.
    Excellent point on the torque method. I’ll hand tighten top 4 evenly, then do a Star pattern torque on the top 4 , and finish with the bottom 2.
