Where's your IAT? (CSL guys)
I was using the IAT that came with the turner box (this was back in 2021 at Autoclub Speedway here in SoCal in the early summer) when we started noticing idle hunting, lights on dash, and the motor running lean. If I recall, it was reading temps super high, was chatting with Hassan and the suggestion was that the IAT was heat soaking. Came back, used the current IAT and relocated to the duct, had Hassan make some changes, and it's been smooth ever since (including sessions at Buttonwillow etc). Mind you, this is my own story so I'm just sharing my experience.
Exactly. BMW Did loads of developement with the IAT sensor in the airbox. Heatsoak or not, allowances in the original CSL tune must have been made to account for the IAT's position.
I'm curious what other symptoms people experience from the heat soaked sensor other than reporting of higher temps. I seem to have only read about higher temp readings and not so much lower performance and the like.
INPA or Testo
Also, I'm not sure why the tuner is suggesting putting the Beru (E34) sensor down in the lower brake duct intake tract. The air going into the intake manifold won't be nearly as cold as that area. The engine will be reading a colder air temp and my guess is throwing more fuel into the engine.
On the other BMW engines using this Beru sensor, it is mounted either in the intake manifold or after the air filter. I think that the CSL snorkel or better yet the unfiltered section might be a better location to mount this air temp sensor.Last edited by ac427; 03-06-2024, 11:57 AM.
Originally posted by elbert View PostHow are you guys checking the IAT values? INPA or a "hidden" OBC function?
Sorry for the noob level question
On the other BMW engines using this Beru sensor, it is mounted either in the intake manifold or after the air filter. I think that the CSL snorkel or better yet the unfiltered section might be a better location to mount this air temp sensor.Last edited by Slideways; 03-05-2024, 08:45 PM.
to me the CSL sensor looks better as it would probably have a faster response time than the threaded brass one
Originally posted by beyondm3 View Post
Okay, I want to move mine to the area below the snorkel too. Looks like I will get the E34 or E36 sensor and rescale the sensor calibration using ECUWorx.
What is the point of this instead of using the CSL IAT? Why not just relocate the original?
Originally posted by marksae View Post
Sorry, I should have worded my question a little better. I am currently running a CSL tune with the stock CSL IAT in its original location. I want to relocate the sensor using an e34 or e36 sensor. Will I need to recalibrate my ECU?
