Originally posted by terra
SMG to 6MT Conversion
No, the Z3m coding lets you eliminate the gear recognition sensor and wire the clutch switch directly to the dme. The dme still expects the signal to be pulled high (the non-M pulls it low).
terra I thought I recalled awhile back you or someone else mentioned coding the DME as if it was a Z3M and then not using a GPS, that would allow the non-m switch to work? Is that a possibility or am I completing off?
Well in the absence of the proper switch, I think the only real options are to retrofit the old style switches (+/- start lock delete), use the euro switch and delete the start lock, or do a hybrid setup with the euro switch for cruise and the old switch for start lock. I suppose one could also use the non-M switch for the start lock and the old switch for cruise.
I think they are pretty well sealedOriginally posted by terra View PostAnyone know how to open these switches up and expose the board? I imagine it would be as simple as moving a bridge to change the output from ground to +12v
I‘m pretty sure you can use a non m e46 clutch switch with interlock circuit that goes originally to the ews and use this interlock output to feed +12V clutch signal to ECU. And code out clutch interlock in EWS.
Sadly in Euro E46s we don‘t have Start interlock..
so did eEuroparts have the right switch on the shelf? I just made an order with them after ordering what was advertised as the correct 61319122700 part on eBay for too much money, only to get the 35426876898 switch.Originally posted by wsybert View Post
I just bought one from eEuroparts. Had to call to make sure, but it got the 61319122700 part. Sales guy had to look it up to make sure it was what was on the shelf.
Anyone need a 35426876898 clutch switch? Make you a hell of a deal!Last edited by M3llowM3; 03-12-2021, 04:30 PM.
You give me hope haha, I changed the vehicle order, coded all relevant modules and used Martyn's tool for that part of the coding. My car is an early one so I have a non hp ecu, whenever I have time I'll go to the car and check the hexs manually to make sure the changes were correct.Originally posted by liam821 View Post
For what it's worth, I have the 61318363710 cruise/clutch switch wired to DME pin 20 at connector x60002, no clutch start switch, no gps, and my cruise works normally. What coding did you do?
I have a mss54hp dme, and did the following coding:
Assuming you're on the latest software (probably are if it was flashed with a manual tune relatively recently), then 01 to 02 at 0x802a, FFFF at 0x5952, and A0 at 0x88A2.
For what it's worth, I have the 61318363710 cruise/clutch switch wired to DME pin 20 at connector x60002, no clutch start switch, no gps, and my cruise works normally. What coding did you do?Originally posted by PipeUy View PostI have the 701 euro clutch switch installed in my car without a GPS and wired and coded correctly but cruise control doesn't work. The green light does light up but after that it won't work. The car itself works flawlessly with no stalling issues but no cruise control.
can anyone tell me where on this switch I can find the Part#? I see # on a used one I have but when I google, nothing shows up
Re: the 700 clutch switch.
I just contacted my dealer and there are none in the US and the number cannot be ordered anymore. I then reached out to Schmeidmann and they show that the pn# is on back order with no confirmed eta.
Note: The black 898 will work for starting, you just won't have cruise control if wired like a OE M3.
I ordered the Euro switch with p/n xxx701. I read somewhere (maybe in this thread or elsewhere online) that this will work for our swap but we won't have cruise control. It is on order for a few weeks so time will tell for me
