SMG to 6MT Conversion
  • gheorghe
    Originally posted by pawelgawel View Post
    found this today for anyone having same questions
    https://www.mforum.net/forum/e90-m3-...n-revised-2020
    Does anyone have a picture of the Original Manual trans torsion spring?
    Reading the guide, there seems to be a difference in shape between the Mcmaster spring and the OEM one (pictures from post are gone):
    Short Leg of the Torsion Spring
    Here is what the guides get wrong. Notice in the Original BMW manual spring that the short leg is 90 degrees from the direction of the long leg. You have to unwind this side of the spring 45 degrees to match this angle. This is a bit difficult to do and will require a vice. Clamp the spring in the vice by the short leg. Take a long 3/8 extension and pass it through the spring inner diameter. Use the extension as a handle to pull up the spring to unwind 45 degrees out. You will have to straighten that leg out once done as it will still have some of wound arc to it. You are matching the 7 windings that the original BMW spring has by doing this. You are not adding any more or less pressure than the OE part. You are modifying the McMaster part to match it.
    After you have corrected the short leg, you can visualize where to cut it and then add the small bend that the original had. Eyeball this, it isn't super critical.
  • ATB88
    Sorry guys haven't driven the car in a while, and forgot about this. Will get a pic for you today!
    Build date Jan 23, 2002. Soon to be Canadian legal drinking age
  • lemoose
    Nope, ashtray wiring still intact. I'll take a pic next time I'm in the car
    It's been a couple of years so I'm fuzzy on the details, but I think it was tucked away from the other wires down there and I had to look for it, but it was there waiting to be plugged in. I was kind of amazed, myself.
    interested myself as there doesnt seem to be any wiring in mine (03/02)
  • George Hill
    What is the production date of your car?
  • SQ13
    Originally posted by S3diment View Post
    Including clutch and flywheel?
    Sorry, $4300. Excludes clutch and flywheel (replaced ~10k miles ago).
  • ATB88
    I have not seen that, do you have a pic?
    Maybe you stole the wiring from the ashtray?
  • George Hill
    Not true. The connector's there. It was on mine. IIRC it was taped off, but definitely there. My knob is illuminated and I did no wiring in the gear shifter area.
  • ATB88
    Has to be wired in.
  • S3diment
    Decided to have a shop do the work instead of DIYing. $3300 + provided AS SSK and OE shift lever. $230 for a new shift lever hurts my soul. Car should be a 6MT by the end of the month.
    Is there a connector for the illuminated shift knob in the shifter area, or will it need to be wired in?
  • George Hill
    Has to be wired in.
  • SQ13
  • CSLManual
    Originally posted by Zack View Post
    How much we talking?!?
    details here: https://nam3forum.com/forums/forum/c...lugs#post79080
  • Zack
    Originally posted by CSLManual View Post
    Anyone doing this, I now sell custom plugs to fit in the steering wheel where the paddles used to be. You may have seen them on Facebook briefly, I'm just waiting until I have enough posts to be able to post them for sale on here.
  • 0-60motorsports
    That’s excellent
  • CSLManual
