Has anyone here actually weighed their vehicle?
We also plan to do those parts in CF this year to save some weight. Super easy mold so not as complex as the CSL trunk...1 Photo
Please educate me on pros and cons of ZF transmission swap.Originally posted by tr3flip View PostHave you removed all the air bags and sound deadening sheets on the floor? I got mine down to 3050 with half tank of gas at its skinniest. This included no radio, no speakers, no front or rear carpet and a ZF 5 speed trans swap.
Sound deadnening is like 30lbs, I prefer to remove it and keep more interior parts insteadOriginally posted by bmw m3 s50 View Post
I did read that and am getting ideas from it. Thank you for posting it.
Complete audio with wiring harness can be removed and just get a Bluetooth speakers and put it on passanger seat for longer ride!
Door airbags can be removed and coded like CSL.
You can drill holes into trunk hinges, cut some sheet metal and drill holes into dash bar. On the lower steering wheel cover, you can drill plastic rivets and remove the foam and metal plate. Remove the foam from dash bar, remove some foam under floor carpet.
Can also use titanium hardware!
That sounds weak...lol Making the car track only makes weight loss decisions easy but quite difficult for a street car especially if it can't be undone.Originally posted by bmw m3 s50 View Post
Yeah, I am coming to that realization as well. This will not be a full blown race car and will be driven on the street so it's walking a fine line between tolerating a combination of noise, rattles, and discomfort and weight savings. I have not pulled the stereo nor plan on it. I will want to listen to music while driving. Also windows and door locks are staying.
So, it will depend on the change. I am willing to sacrifice some but not everything.
The carbon cabin filter housing would be a good weight loss opportunity. You could remove all of the rear speakers and use a nice neo mag midbass in the front doors which doesn't cost a lot and will cut some weight.
The one good thing about carbon panels - no door dings!Last edited by bigjae46; 02-07-2025, 09:16 AM.
Would work with stock alu rebar. But the alu rebar itself is super heavy. Our CSL bumper has CF rebar integrated to bumper.Originally posted by bmw m3 s50 View Post
I am definitely going to be contacting you about that CF cabin filter housings and rear carbon shelf. Both of those interest me. Just need to gather the funds, LOL.
Will the lightweight shock mounts alternative, work with the stock bumper? I am not a fan of the CSL front bumper.
I also prefer the look of non CSL bumper, trunk, diffuser honestly cause look like a better evolution of the E36 but doing the CSL theme on my LSB to make it different vs my Estoril M3. But I am working also working on a wider front end (bumper and front fenders) that will look similar to this:
2 Photos
LOL, sure we will have develop a drone mode so the car could be driven but to defeat the fun factor of the car.Originally posted by M3dragon View Postsimple way to lose weight. Don't be in the car =P
Agreed, with this car I plan on using this mindset.Originally posted by Obioban View Post
100% this. Consider weight every time you do something to the car. Everything matters.
Same as above, I unfortunately do not have unlimited fund to drop $11k for an aluminum block.Originally posted by Bry5on View Post$11k for an aluminum block. 40-50lbs off the front axle
Honestly, if that aluminum block was closer to $5k, I would actually consider it.
Yeah, I know about that but cost for the carbon quarter panels do not make it feasible. I unfortunately do not have unlimited funds.Originally posted by dHam_Slow.46M View PostSince we're on the topic of composites, we shouldn't forget that Karb makes some CF body panels. $10k for ~11kg(24lb) shaving🤪
Additionally not a fan of CF quarters as carbon will shatter rather than deform and costs of repair should something happen.
I am definitely going to be contacting you about that CF cabin filter housings and rear carbon shelf. Both of those interest me. Just need to gather the funds, LOL.Originally posted by Gt4 View PostI also sell CF cabin filter housings 7.5lbs lighter
And I am working on a lighyweight shock mounts alternative for our CSL bumper with aluminum rebar version. Total assembly will be lighter than the kevlar rebar option
I did read that and am getting ideas from it. Thank you for posting it.Originally posted by Gt4 View Post
Yeah, I am coming to that realization as well. This will not be a full blown race car and will be driven on the street so it's walking a fine line between tolerating a combination of noise, rattles, and discomfort and weight savings. I have not pulled the stereo nor plan on it. I will want to listen to music while driving. Also windows and door locks are staying.Originally posted by bigjae46 View PostI don't think getting close to 3000lbs with a half cage is feasible unless you add a combination of noise, rattles, and discomfort. But did you pull the stereo harness out? That's a couple of lbs.
And that's the key, you have to look for a lb here and there. Then you're looking for ounces. People say that 8oz won't make a difference. Yeah, but find 20 of them...that's 10lbs.
To get under 3000lbs, you need to give up comforts like windows that work, power door locks, and heat. Does that thing need 4 bolts holding it? Will 2 work? The rear bumper reinforcement has 3 nuts on each side...I removed 1 from each side. If you really want to make the car light - need to dust off the sawzall and remove sheet metal. I got the car to 2610lbs with a full cage and no fuel without a strand of carbon.
Composites...it is also a compromise. A carbon part with OEM like function is not going to save a lot of weight especially if the part is aluminum. A carbon hood will only be a couple of lbs lighter. You can pull off more weight but it could flutter at higher speeds.
