STOPTECH ST60 & ST40 Parts Info
  • fattycharged
    Ah, that's a bummer. Those boots were the factory originals, and I got the kit about 3 or 4 years ago.
    This setup was a takeoff from a recently acquired "racecar" I picked up off a shop last fall on my way back from CO. Assuming they replaced them with something they could more readily get parts for from multiple outlets. I likely won't even run them, more likely to just keep the DB9 kit and even run it with a 325mm rotor
  • elbert
    My boots definitely do not have their measurements displayed and the part # on the boot did not lead to any results via leGoogle.
  • fattycharged
    Ok, so my findings on what I have from last night inner piston/outer boot measurements. My boots definitely do not have their measurements displayed and the part # on the boot did not lead to any results via leGoogle. Front boots are trash, Rear boots still good, not super surprising, but I need to do a full teardown and repaint/powder as well.
    Rotors are 355mm F&R
    F - 34 34 30
    R- 28 28
  • OPS
    Mike,
    Will have to contact you once i know the sizes for the boots needed for both ST60and ST40 E46 M3 applications. Thank you.
    If the community figures out the application sizes, I can request Frenkit to manufacture those specific kits if they are a unique combo!
    Mike
  • 0-60motorsports
    Originally posted by PenguinScotty View Post
    Zeckhausen is a phenomenal source regarding stoptech, especially since they've become less than stellar to deal with directly and parts supply has become extremely difficult.
    For replacement seals and boots, i'd recommend looking at Girodisc, they also supply replacement rings for stoptech kits which are fantastic.
    Yeah it is an awesome source for sure. Thanks to them we some good info, Girodisc are definitely what I am going for but First need to sort out the calipers and pads too.
  • 0-60motorsports
    Originally posted by OPS View Post
    Ive got dust boots should you need them. I haven't rebuilt stoptech calipers in a long time but they use the brembo dust boots..
    Mike
    OPS
    Mike,
  • PenguinScotty
  • OPS
    Mike
    OPS
  • eacmen
    I wish i had dust boots…
  • 0-60motorsports
    In the off-chance that your boots are still intact, it will have the piston size on them:
    Oh perfect! Yea they are / should be intact. Thanks.
  • elbert
  • fattycharged
    Good looking out, I would have just measured the tapered portion.
  • eacmen
    I'll figure out a way to measure them if no one here has the info as I can't disassemble them and wait two weeks for parts to arrive and then another week to get the PC done etc.
    Email David Zeckhausen. I think its [email protected]. He might be able to ID the piston sizes without measuring them.
  • 0-60motorsports
  • 0-60motorsports
    Weissgold is nice and would look subtle behind the LM's.
    I've got a set of non trophy in the garage I should be able to measure the pistons for you tonight.
    That color sounds good! I'll go check the samples one of these days and post up pics.
    Thanks that would be great.
