Apologies if this was answered elsewhere, I'm trying to understand a key piece before pulling the trigger: Break in time? I saw a mileage minimum and staying under 4k rpm for said mileage but if that's the case, how does one dyno tune for full potential i.e. have Hassan do a pull to 8k+ RPM?
Or is this a misconception and there's no need or what's the best practice for installing upgraded cams?
288/280 vs 280/272 cams.
I got the last 2 sets that I could find anywhere for retail price. The back order is still ridiculous and Im sure the retail price will increase again.Originally posted by bmw m3 s50 View Post
Are the rocker arms now available at retail? Where did you get them?
Are the rocker arms now available at retail? Where did you get them?Originally posted by Projecte46m3 View Post
I have 2 brand new sets that I recently purchased. Only need 1 set for an engine build project coming up.
I have 2 brand new sets that I recently purchased. Only need 1 set for an engine build project coming up.Originally posted by bmw m3 s50 View Post
Why does your friend have a set for sale?
I have something that is currently panning out at the moment that might not need this. If it falls through I will let you know.
Also, I received an email from Schrick that the rocker arms are in production but they have a 1200 unit backlog. They mentioned that the rockers should be available at retail early next year.
Why does your friend have a set for sale?Originally posted by Projecte46m3 View Post
Is this offer still on the table? Asking for a friend…lol
Is this offer still on the table? Asking for a friend…lolOriginally posted by bmw m3 s50 View Post
Well I am glad you feel so confident about Turner/ECS. Let’s put that confidence to the test.
Since Turner/ECS has them in stock or can get them in 4 days, how about you place an order for 24 DLC followers. Since they are in stock you should get them right away. If you can get them within 3 weeks. I will buy them from you and pay you $250 extra on top of the cost of the followers.
Easiest $250 you will make. Just post a screenshot of your order to confirm you placed the order so we can start to clock.
Anyone have updates on the Schrick rockers being available?Originally posted by ugaexploder View Post
They would if we had a minimum of 10 paid orders. Not like I looked into this a while back LOL. The main advantage of the CSL cam profile was the low-end balance to keep the power band linear. Schrik makes a touch more power but moves the power band up.Originally posted by 0-60motorsports View Post
I wonder if a cam company would do a run of the CSL cams for us. I wouldn't know who to ask other than shrick or cat cams but I doubt they will.
CSL valves are also the wild card as the concave design does help scavenge the exhaust from what I remember. Again helping that low-end "bog" with the BIG OLD INTAKE lol.Last edited by M3dragon; 05-17-2024, 11:52 AM.
Not yet unfortunately. I kept meaning to, but now I'm doing something really stupid to the car involving Karbonius' carbon side panels 🤦. I also have new 996 turbo injectors I would like to install, then get a dyno tune.Originally posted by George Hill View Post
Have you dyno'd this setup? How many miles on the shortblock?
Prior to head rebuild, bottom had 114k ish (did treated rod bearings at same time as head). Engine now at 117k. It doesn't get a ton of use. I'm building a wheel-to-wheel car now too so it's going to get even less use unfortunately.
Sorry for the misunderstanding, the S62 relief valves are identical to the S54 valves, but you can't buy the S54 ones separately and the CatCams don't come with them. I forget which M3s come with the valves in the cams, so if your stock cams have them, you just swap them over. My 2004 did not have the cam versions with the relief valves.Originally posted by enjoy_m3 View Post
Mind me asking what's the advantage for s62 pressure relief valve? Those rocker arms mustve cost a pretty penny! lol
If I recall correctly, the motorsport rocker arms were actually less expensive than the schrick versions at the time. I think I paid right around $1k. The CSL exhaust valves... Now those were expensive. Aftermarket titanium would have been a bit more than half.
Sent from my Pixel 8 Pro using Tapatalk
Mind me asking what's the advantage for s62 pressure relief valve? Those rocker arms mustve cost a pretty penny! lolOriginally posted by C///M View PostI'm another member from the CatCams GB with no issues, an 8500rpm redline, track usage, and good oil analyses.
Full Engine Specs (for posterity's sake):
Head:
- Ported Intake/Exhaust ports (mostly exhaust, stock intake couldn't be improved much)
- Head decked
- 288/280 cams
- S62 pressure relief valves
- Brand new OE S54 valve springs/retainers/etc
- OE CSL exhaust valves ($$$)
- BMW Motorsport P45 / P54 DLC rocker arms (NLA unfortunately)
NO CatCams Oil Bridge
Bottom:
- Stock with WPC Treated OE S54 rod bearings
LiquiMoly 10-60 (moved from Castrol)
I will update if i see any concerns in a future oil analysis.
Have you dyno'd this setup? How many miles on the shortblock?Originally posted by C///M View PostI'm another member from the CatCams GB with no issues, an 8500rpm redline, track usage, and good oil analyses.
Head:
- Head decked
- 288/280 cams
Bottom:
