Car will not start, not getting power to fuel pump
  • dukeofchen
    Is the fuel pump relay in the trunk? I'm troubleshooting a potential fuel pump issue myself right now, and at least on non-Ms it seems that the relay is in the panel behind the glove box.
  • NaM3
    Nevermind, I got it to start and all I had to do is to clear the faults on the DME using INPA.
  • NaM3
    started a topic Car will not start, not getting power to fuel pump
    I have been having a problem with starting my car and after running the codes, I get fuel pump relay code. I replaced the relay located in the trunk with a brand new relay purchased from the dealer but no dice. My next step was to use a test pen to see if there is any power going to the fuel pump (larger red/white wire) and I got no power going to it. Also checked the fuse in the glove box and that fuse is good. Opened the fuel pump up and everything looked normal and still have half a tank of gas. What else can cause the no power to the fuel pump? I have heard the crank position sensor, is that true? If so, how do I check that?
    Does anyone have the wiring diagram, particular to the area where the relay is? Under the relay there are two red/white wires and one red/blue. The red/blue I get power to but the red/white I can only get one wire on when I turn on the ignition however no power going to the other red/white wire which I believe is the one that is being sent to the fuel pump.
