E46 M3 highway shutdown: tach/speedo drop, DME unreachable afterward
  • BRiley
    I think I've blown up the EWS at this point trying to crank it so many times. Working on trying to clear this ECU_NOT_RECOGNIZED error now before I can log any data.
  • sapote
    Originally posted by BRiley View Post
    I have INPA, but I don't know how to log data with it. How do I capture the log?
    inpa cannot log the file. I suggest to get OBDFusion app for phone, and the OBD reader VeePeak
  • BRiley
    Thank you all. So I replaced fuse 54 with a new one. It will crank and drive fine for a while. When I turn it off after, it takes 3 tries to crank. I have INPA, but I don't know how to log data with it. How do I capture the log? I know how to view these numbers in real time.
    Also, FWIW I can activate the pump reliably with INPA. I cleaned the pump contacts last night. There is no burned wiring or anything.
    I do hear the pump priming when I turn the key to position 2 for the first time. If I turn it off, and then back on to position 2, no prime. Tried this 3x, and it only primes once. I can hear it running when I try to start the car. But no start.
    Pin 7 to ground is .1-.2 mV.
    Thank you so much!
  • sapote
    Where do I go next? I checked the fuses in the DME relay, and they test fine. Ground wires look fine to me. I cleaned the contacts.
    When engine failed to run, remove the back seat and feel if the pump is running during pump priming-time with key turned to ON (it hard to hear or feel during cranking but you can try that).
    Btw, with key turned ON, measure the voltage from relay pin7 to batt negative post and it should be close to 0v, if higher than 2v then it has a bad gnd. This is a better way to check for bad GND compared to using Ohmmeter and measure the resistance from pin7 to GND.
  • terra
    I would suspect it was used during the development phase and might possibly still be connected to one of the unused relay pins
  • sapote
    Take that with a grain of salt, the DME doesn't have a good way to tell if the relay has a ground fault.
    Truth.
    I remember the pump driver chip has some limited diagnosis capability, but obviously the wiring of the relay I posted above shows no pin for the DME to read the chip status.
    I wonder why pin5, the load current sensing status that DME can't read, was connected on the pcb that the OP posted, shows below:
    Click image for larger version  Name:	image.png Views:	0 Size:	983.9 KB ID:	354441​
    Click image for larger version  Name:	image.png Views:	0 Size:	129.6 KB ID:	354440​
  • terra
    The error code says the relay gnd is not good. I would add a gnd wire from the relay pin7 to a good chassis GND (find a bolt or nut, or directly on the batt negative cable).
  • sapote
    First symptom is the car started running incredibly rough when warm the other day. It turned off, and would not crank for quite some time. Once it cools down, it starts, and runs for a few. Then turns off. If I completely cool the whole car down, I can drive for a while.
    The fuel pump is a few months old. Filter is also a few months old. Got the EKP tonight. Car drove fine for a while, then no start a few times. The code is a ground fault on the EKP.
    It's better to get a log file with these data when engine T reached 80C or higher: MAF in g/s, rpm, coolant temp, both fuel system status, all O2 sensors, 4 fuel trims, intake are temp. Upload the file to Datazap.me site for graphing the data, then post the site link here so we can review.
  • BRiley
    What is the problem or its symptoms?
    If the measured fuel pressure is about 5 bar or 72.5psi then there is no question on the pump nor the relay.
  • sapote
    Great question. No idea if the new one will solve my problem, but it's a start to the troubleshooting process.
  • BRiley
    Why you needed to replace the old one?
  • sapote
    I just bought a new relay. If anyone has electronics skills and wants mine for testing, I'm happy to send it. Maybe we should start a Fuel EKP specific thread, so it'll be easy to find.
  • BRiley
  • sapote
    This will be difficult for the large pad without preheating the board and/or using hot air.
    You're right about the large heat-sink tab, and do not try to cut it off. Remove all the small pins as suggested, then heat the tab and add more solder to it to help transfer the heat from iron to the pad. This will take some time as I expect the tab heat-sink extended to the area under majority of the device. Use the largest soldering tip you can find.
  • terra
    Just cut the pins off near the device and away from the pads, then melt the solder at the pad and lift the cut pin off.
