Originally posted by OldRanger
E46 M3 highway shutdown: tach/speedo drop, DME unreachable afterward
If I needed to rule out a DME issue, I'd swap the DME from a friend's M3 and test.
In spite of what Gemini gave me as a good story, I still think there’s a DME issue as well, but I can’t figure out why it takes an hour to fail, and the thought of going out for an hour or more to make it fail again on the side of a highway doesn’t appeal to me.Originally posted by sapote View Post
My bet on the power supply to the DME:
* from the ignition sw to DME
* from DME to main relay
* from main relay to DME fuse pack
* from fuse pack back to DME power input pins.
To keep key facts fresh: Between the first occurrence and the second, I replaced the ignition switch (w/new) and the DME relay (w/new), as well as checked the Ebox and main (engine) ground point . I did not check the individual wires for continuity. I took out the fuse pack, the terminals are tight and the wire connections are as well, but I didn’t disassemble it to replace the fuses. (Couldn’t figure out how)
I have a couple options for next step:
1) Get it to fail again. After I put the new fuel pump relay in, take a proper test run and assume the car will fail again at the hour mark. Take everything I need to diagnose the failure and set the conditions, from daylight and warm weather to all the tools and a plan for the first few minutes after it shuts down
2) Pull DME out and send it off for a bench test at ECU Pro. check all the wires in the DME power circuit, and figure out how to replace the fuses in the fuse pack. In parallel use this time to get my GM five repaired at a local repair shop with new relays cause I have problems there too with door locking.
what would you do?
So, I told Gemini the whole story…remembering some minor details in the process. Including that I had a fuel pump relay code present before the dyno session, that I assumed was somehow related to the new fuel pump installation process.
That code has been present on both occasions of the car shutting down.
Gemini got very creative…speculative, and suggested:
The new high-draw OEM fuel pump and performance tune are overtaxing your 20-year-old "used" relay, causing it to thermally saturate and arc internally at the one-hour mark. This arcing creates a massive voltage drop that starves the pump of power, causing the engine to stutter and die from a total collapse of fuel pressure. Even with an ignition cycle, the car won't start because the relay contacts remain physically separated by heat, while the resulting electrical noise "jams" the DME’s communication chip into a protective hardware latch-up that takes 45 minutes to thermally reset.
so I ordered a fuel pump relay.
A bit of history here: on my other high mileage M3 a couple years ago I was getting a fuel pump relay code. So I replaced it. A week later, the fuel pump died. My assumption at that time was that the code on the relay was wrong and that it was actually the fuel pump going bad.
I’ll follow up next week after I get the new relay and take a test drive.
Does anyone want a really long, hypothetical, AI explanation on how that fuel pump relay failure sets off this avalanche?Last edited by OldRanger; 04-02-2026, 07:06 AM.
$122.99 on FCP https://www.fcpeuro.com/products/bmw...46-12907571019Originally posted by Cubieman View PostHoly shit, a new ebox fan is $360..
My bet on the power supply to the DME:Originally posted by OldRanger View PostSo…does anyone know of a MSS54 DME failure? What caused it?
The absence of error codes (edit: actually just noticed you're using a scan tool. Ideally check for codes with INPA, most of the DME low-level operation codes don't have external P-Codes linked to them) related to supply power, OS integrity, memory integrity, etc. make this seem like a very sudden event that is killing the DME immediately with no opportunity for it to log codes. It might be that the issue is happening fast enough that the thresholds aren't met for storage ofr the codes into the EEPROM before it fails completely. What doesn't align with that thinking though is your observation of several minutes of rough running before it fails completely.
I agree with Terra though that it would be worth replacing the DME with a known good unit and retesting, that will for sure tell you whether the issue is inside the DME or out.
You can swap just the motor: https://www.e46fanatics.com/threads/...71019.1285892/Originally posted by Cubieman View PostHoly shit, a new ebox fan is $360..
Seems like a fair assessment. Mine didn't get to the point of failure as I replaced due to chirps, which means I likely wasted my time and money.Originally posted by OldRanger View PostInteresting input from the tuner, when I asked if a DME could/would shut down from excessive (external) temperatures in the Ebox: "It shouldn’t. (Their) Race cars never have the ECU fans and we never see them have overheating issues."
I could see over prolonged mileage/time then maybe the lack of one comes into play.
I never had to delve that far since mine was audibly failing with the typical chirping noises. I have seen other reports the fan simply dies, or perhaps it wasn't making enough noise to be noticeable.Originally posted by OldRanger View Post
I didn't check that, I will figure out how to do that. (I didn't have a code for it). I see there is an Ebox temperature switch that relies on.
I didn't check that, I will figure out how to do that. (I didn't have a code for it). I see there is an Ebox temperature switch that relies on.Originally posted by oceansize View PostThinking along the lines of heat, perhaps the DME fan has quit?
I haven't seen such a thing, but sounds like potentially like something is overheating. Perhaps some component with an internal short leading to such.Originally posted by OldRanger View Post\
- Has anyone seen an MSS54 go offline for 30–45 minutes and then recover, especially after about an hour of highway driving?
Too bad MSS54s are so expensive these days, I think it'd definitely be worth a shot to replace
