MSS54 DS2 Tool: FREE - DME tune, program, flash counter, codes, adaptions, etc
  • Cubieman
    Also tried the ebox fan and got this:
  • karter16
    I tried the CSL flap test with and without the engine running.
    Makes a somewhat loud buzzing sound for less than a second and produces this error message.
    Click image for larger version Name:	20260530_150251.jpg Views:	0 Size:	36.4 KB ID:	356962
    thank you! Investigating this now!
  • Cubieman
  • Slideways
    Yeah that's what I thought mate. My cousin has a windows tablet, told him to bring it over and I'll download the tablet and give it a shot once the car is back.
    The beauty of this is you do not need a dedicated Windows laptop anymore. Plus newer laptops are way faster and have proper battery life.
  • ac427
    Here are some DIS VANOS test reference results i got back in December 2024:
    Click image for larger version  Name:	DIS v57 Revtor-2024-11-25-15-04-31.png Views:	0 Size:	23.9 KB ID:	356954​
  • ac427
    You know what - I had the same issue, but that my thermostat is old and so opens slightly colder than designed. Couple of options: 1 is to do exactly as you say and have an override in settings. Could make it a select for people with 70, 75, 80 thermostats, and default to 80. Alternative would be to use oil temp as the pre-req not coolant temp. It's not exactly what the original test procedure calls for, but tbh if the oil is warmed up I don't really see how a small variance in TMOT would affect the test in any way?
    Stop the presses. The DIS VANOS test prerequisites are:
    Engine running at idle
    Coolant temp > 75°C
    Oil temp > 40°C.
    No errors in the DME - I don't think that is very useful. Perhaps an override for that, for those of us who do not want to clear the fault memory to run the VANOS test?
Name:	DIS ScreenShot 01.jpg
  • karter16
    Would it be possible to display TMOT in the Engine Fan Test?
    Great idea! will add this.
    Are the test results recorded in any of the logs?
    They currently are not, nor are they recorded in History. That's a good point though. Probably for the tests that generate resultant information that info should be both exportable and recorded in History. Thanks for this, will have a think about how to best do this.
  • karter16
    I am running one of Anri's 70°C thermostats. So even after some spirited driving, the motor temperature once i had parked on the driveway was an annoying 79°C, just below the VANOS test's 80°C threshold. So i turned the A/C on and performed an engine fan test at 10% for a little while to raise the engine temperature.
    I did think about requesting a temp override for the VANOS test but that would skew the community's VANOS test results.
  • karter16
    karter16 there was a thread on M3F where a few people posted their VANOS test results. On healthy units, a fast response was around 190-225ms. Between 250-300ms was considered average to slower and over 300ms was considered slow. IIRC, almost all VANOS tests in that thread were below 300ms.
    Thanks for this I knew that we'd collectively arrived at some conclusions but couldn't remember what they were!
  • karter16
    If you have an Apple Silicon MacBook Pro you can run VMware and Windows 11 for ARM. Microsoft don't seem to enforce a trial period or activation period for Windows for ARM if used in a VM so you can currently just use the free install for forever.
  • 0-60motorsports
    You could but you would need a Windows licence for the Windows VM.
    Just get a cheap Windows laptop mate.
  • ac427
    Since I'm not an expert are you saying I install that on my MacBook Pro and then this application should work?
  • 0-60motorsports
    VMware for Mac is free - https://www.vmware.com/products/desk...ion-and-fusion
    M3dragon has a working CSL flap and might be able to test it.
  • Slideways
    Unfortunately I don't have vm and no windows laptop right now. I'm sorry I could not be of immediate help.
    I am planning to get a windows laptop soon though.
  • 0-60motorsports
    No worries mate. I just remembered you had the flap wired in. All good 👍
    Thanks mate. I am really excited for this thanks to Karter. So many headaches are going to be gone for me once I can find the right windows laptop to use this with.
