Good bumper for Aero?
  • Arith2
    Originally posted by SandeepM3 View Post
    What kind of car is this for? Track, Street, Heavy dual duty?
    If you have a wider track due to spacers and want a bumper to fit that, that doesn't look funny, its kind of impossible. It has to meet body panels that were designed for a smaller track width. If its a track car, then you take the funny/odd/over the top look for priorities. If its a street car, then dont bother, it will make such an insignificant difference.
    Someone did mention just putting blocking plates in. I found some free software the may be able to test the CFD. I don't track it currently but I will use aero on rallies. There's a Porsche ralley my dad and I are going to next year at the tail of the dragon. I'm going to need some good setting up for that. Sometimes I rip it in Mexico when no one's around also... and better aero equals more safety. Looking at all the Le Mans GT1 cars, they block the front tire yet you make a valid point about the body. It won't be perfect but there's a lot of room to improve.
  • Arith2
    You could try the carbon GT4 splitter that all the Nurburgring regulars put on their Ringtool M3s. It's rare to see Nurburgring M3s utilizing canards, most of them strap on this splitter and call it a day.
    http://www.mk-motorsportteile.de/M3-...ter-BMW-M3-e46
    Pic:
    Click image for larger version  Name:	e46 m3 aero.jpg Views:	54 Size:	102.8 KB ID:	39666​
    I'm going to create it in some software and test it out if I can. It doesn't do the job fully but I really like where I think the vorticies will come off of that one. It's a compromise between looks and function.
  • SandeepM3
  • shibui
    Pic:
  • Arith2
    [QUOTE=Sharocks;n39574]OP puts on spacers now wants a bumper to go with his spacers. Ok.
    /QUOTE]
    Let me be clear. I DO NOT want spacers. I need them. Look at a stock bumper, it's a bad areo design already. The E46 has an aweful friction coefficient as well. Canards are not good at what they do and they look bad on our cars
  • Onefastsicilian
    A lot of track guys in Europe are running the Matty Evans front bumper that has a built in belly splitter so it's more sturdy than two CF flippers on a CSL bumper. After which you can add canards etc. make it look like a ZL1 1LE etc.
    Too bad Matt won't ship to the US. I've tried many times lol.
    I wanted to buy his rear bumper but he wouldnt even respond.. i feel like because I mentioned in my email shipping to the USA he was like F that lol I'd love both of his bumpers actually.
  • Obioban
    ... or the track, which is where my car spends its time.
    Most people end up with different wheel/tire setups for track use, and high speed stability isn’t really a consideration there.
  • Sharocks
  • Slideways
    That's good. I was mainly referring to cars driven on the street with freeways and imperfect roads.
  • elbert
    It's the standard thing to do these days. Take a street car designed to run a front 8-8.5" wheel with a 225-235 tire and 1-1.5 degrees neg. camber and change all that out for a 9.5" wheel with a 265 tire and 2.5-3 degrees neg. camber. That will feel great on every road that is not perfectly paved twisties
  • Slideways
    Why not address the underlying issue, instead (tires poking out)? Stock, the e46 m3 is super stable-- more stable than my M5 (which is a car known for high speed stability) or former e9X.
  • Obioban
  • Arith2
    I found the DIY below for fender flares. There was a Racecar Engineering article about a while back about this type of fender flare, and it was pretty effective reducing drag from a rotating front tire.
    You would also need a full width (and then some) front splitter that would spill into the flares. IIRC, small fences (being z-plane if the splitter were x-plane, and the tangent of the flare at the junction were y-plane) where the components intersect helped as well.
    I have wanted to try this out for quite a few years, but even with the Covid shutdown I haven't had time.
    https://www.corvetteforum.com/forums...y-version.html
    This is an amazing idea! Seems quite cheap and I definitely have the tools to do it. It won't look as good on an E46 because that angle really helps the ugly factor. I think this will actually reduce drag which seems ridiculous considering it's flat. I may attempt to taper it and prevent a break up while also creating some sealing vortices along the bottom. This will definitely reduce drag as I'm sure the rear underneath cause a lot of break up. It makes me wonder if a CSL diffuser even has enough decent flow to work.
    Originally posted by Ruley View Post
    So you’re looking for more aero at high speeds instead of adding grip at high speeds? I feel everything out there is pretty well track oriented. Not sure what to tell ya. Maybe someone else will chime in.
    What I'm trying to combat is the tire slamming into the wind and smashing it into the ground as it rolls forward. This creates a high pressure zone right where the tire contacts the road. At the top is the equal and opposite reaction of a low pressure zone. High pressure moves towards low pressure, which in this case is up. This lift can cause instability and definitely hurts everything. There is nothing good about a tire being exposed to the wind. F1 cars have to be that way due to platform regulations but even their front wings are designed to negate this effect.
  • Ruley
  • elbert
    I was wondering if anybody found a good bumper that doesn't direct air straight into the tires but also doesn't look kinda funny like the gtr bumper. I know on stock and CSL this is done for looks but at high speeds, it really can cause problems. I had to add some wheel spacers so now my tires stick out into the wind even more.
